Question about SanDisk 2GB microSD Memory Card
Error I put my sd card in my blackberry and it says that there are errors and to correct them use a disk error checking utility? what do i do?
    Scholar:
  • 191 Answers
Use it. the card likely has some data or (corrupt data) on it that the phone dosnt like.
the card might also be physically bad or going bad or damaged. FLASH cards die over time just from using them.
Posted on Aug 07, 2009
I have an 8GB micro sd card for my blackberry storm when i put it in. It says media card has inserted contains errors. to correct the errors use a disk error-checking utility on a computer. what do i need...
The chances on any micro sd card showing errors can be either the files stored in it are corrupted or the card is simply bad already. You may try to identify the problem by performing the following steps.
1· Access micro sd card through a card reader. May it be built-in in a computer or an accessory that needs to be plugged-in to a computer.
2· Wait for a few seconds for the computer to read the micro sd card.
a· If it asked you to "open the folder to view files", do so then copy all contents in a new folder on your desktop. This is to make a backup copy of your files. Then, format the micro sd card with FAT32 format. Copy all files back to your micro sd card.
b· If it asked you to format the micro sd card, most likely all files are corrupted. Try to format the card for re-use. If not successful, your micro sd card is bad already and needs replacement.
I hope this works for you. Good Luck!
Mongkey
"Understanding explains better..."
Jan 30, 2011 | SanDisk 2GB microSD Memory Card
I have a 2GB micro sd card for my blackberry when i put it in. It says media card has inserted contains errors. yo correctthe errors use a disk error-checking utility on a computer. what do i need to do?
if this card working on yours phone then this problem related with window operating system if card have problem with phone then this is relsted with card , formatt this card with phone and restore it by system restore s/w.
Aug 02, 2010 | SanDisk 2GB microSD Memory Card
Memory Card Error on New T-Mobile Blackberry Curve
use the computer to save what u have on it and then format the card and then u can copy everything back to the card and see if it will work then
Aug 11, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Blackberry Disk no longer works. need disk error checking utiliy
your best bet is to format the media card. just insert it into a computer and then right click the drive that is assigned to it and format it. be forewarned that this will erase all of the data on your card!
Jul 11, 2009 | RIM BlackBerry Pearl 8100
Micro sd My card worked to save a video then shows an error now. I have a tmobile blackberry pearl smart phone. Please help me. It now says: “a media card has been inserted that containserrors. To...
if you have a USB cable that came with your hanset attach it to your pc or laptop, then wait for it to install the drivers ect.. if it come with a CD-ROM then insert it a dn install the blackberry software, then goto "My Computer, there should be a removable disk drive called MICROSD or something like that, right click on that icon then goto "properties" then click on the tab called "tools" then click on the button called "Check Now" under "Error-Checking"
this should fix your issue.
any problems please comment
Sep 27, 2008 | Cell Phones
Media card
jus put ur card in card reader and format it it will start working
Jun 19, 2008 | RIM BlackBerry Pearl 8100
Error 50
The "E50" error code indicates formatting a SD card has failed. Solution To clear the "E50" error, try performing the following procedure. 1. Try using another SD card. If you have another SD card, try loading it in the camera. If the error code is not displayed when the other SD card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the SD card for errors. Use ScanDisk to check the SD card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the SD card on the computer before you check the SD card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the SD card. Follow ScanDisk's on-screen instructions to solve the problem.
Aug 29, 2005 | Canon PowerShot SD100 / IXUS II Digital...
Error 30
The "E30" error code indicates reading/writing data on a SD card has failed. Especially, the error code "E30" may appears when you tried to remove a SD card while the camera was processing data. Solution To clear the "E30" error, try performing the following procedure. 1. Try using another SD card. If you have another SD card, try loading it in the camera. If the error code is not displayed when the other SD card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the SD card for errors. Use ScanDisk to check the SD card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the SD card on the computer before you check the SD card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the SD card. Follow ScanDisk's on-screen instructions to solve the problem. 3. Format the SD card with your camera Try to format the SD card with your camera. Please refer to the "Camera User Guide" for your camera for instructions on formatting SD cards. Also, please note that formatting a SD card will erase all data on the card. Once the SD card is formatted, follow the procedure described in step 2 above and use your computer's ScanDisk on your computer to check the SD card for errors. If a card error or card failure occurs when you are using computer's ScanDisk, there is something wrong with the SD card.
SanDisk 2GB microSD Memory Card Logo
236 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Carlos Calvo
Level 1 Expert
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
