Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
15 gal sears compressor keeps running an wont go over 40 lbs
  • 6,927 Answers
Check for leaks and check valve(oneway valve)
Posted on Jul 03, 2009
A/C will only pump 30-40 lbs, but keeps running.
Maybe your unloader valve is stuck or damaged. This is found in the switch assembly and if it is faulty you should be able to hear a constant hissing noise from the switch .
Jun 05, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
Air pressure goes to 40 lbs motor continues to run and no air pressure gain
Are you sure the gauge is relaible??
If so then a valve in the compressor is allowing leakage.
Jan 03, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 3 gal., 1.5 hp air compressor: won't auto shut off, builds only 40 lbs pressure, air leaks from the 2 holes in oil filler cap?
The compressor will not auto shut off until it reaches the preset pressure which is usually around 100-130 psi - your problem is leakage of air from the oil filler cap suggesting that you have a failed internal valve.
Sep 24, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Coleman 8hp-26 gal will not develop more than 40
could be piston rings gone check to see if you have crank case pressure a blown gasket can you feel air leaking out off gaskets valves sticking or not closing non return valve gone get back to me
Sep 23, 2009 | Air Tools & Compressors
Craftsman 30 Gal. 150 PSI Not building air over 45lbs
The compressor valve may have a faulty gasket or seal, and maybe leaking air internally. Or the compressor might be going downhill. You can try to replace the valve seal and see if that makes a difference, otherwise you need to replace the compressor.
Aug 27, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
My 5hp 22gal craftsman compressor wont go above 30lbs pressure
your presure guage sensor has gone a miss you can try adjusting it but I would replace it. if you get it wrong you can over pressure you tank and it can explode
Jun 10, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Lack of pressure
My air compressor builds up to 40 psi and just keeps running, i have a craftsman 5 GAL, 1HP, 125 PSI and pressure goes up to 40 psi and dose not go any higher and on the other hand engine keeps running and dose not stop. Please advise?
Thanks.
Kia
Oct 25, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
153 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
