Question about Kirby G6 Bagged Upright Vacuum
Used the G6 to blow out to inflate a swimming pool. After turning off and it cooled down, the power will not come on.
  • 75 Answers
Make sure you have put the bag and the front head on right.they each have sensors and the vacuum
will not turn on.
Posted on Jul 03, 2009
Polaris p93 shuts off after a few minutes
Best bet would be return as defective and get a new one
May 27, 2014 | Polaris New P93 Premium Robotic Automatic...
My Kirby seems to be putting more dirt on the floor than what it is picking up? The brush roller is turning but it leaves dust streaks . It also shoots particles out the side instead of vacuuming it up....
Hi there. It sounds like you belt may be stretched. Simple turn vac upside down, start it up and carefully press your hand on the brush. If the belt is stretched the rollewr will stop turning. If this does not help, you probably have a clog in the power head area. Hope this helps, Chris
Feb 09, 2011 | Kirby Ultimate G Bagged Upright Vacuum
Want to blow air out to inflate mattress
You need to remove the main head with the brushes from the front and install the safety cup. The remove the bag by unclipping from the top and disconnecting the boot end from the bottom with an outwards twist. Now attach the hose to the exposed outlet; attached the thin nozzel designed for inflating to the hose and switch on - you will feel air being expelled from the hose.
Air, which normally contains dirt and dust because you're hoovering is blown into the bag, but now with the bag removed; the air is blown into your hose, through the attachment and into what ever needs inflating.
For a good visual set of instructions click on the following link and scroll down to the second set of instructions :
How to change hoover to a blower
Sep 25, 2010 | Kirby G5 Bagged Upright Vacuum
How do I inflate a plastic matress with my kirby vacuum
You will need to disengage the MINI Emptor...by rotating the bag cuff where the bag connects to the body. Then engage the hose at that port where the dirt would blow into the bag. Then put a reducer on the hose end if required.
Remember the hose is dirty inside ... do not blow inside the house and clear the hose first before inflating...
Oct 15, 2009 | Vacuums
Kirby g4 problem
1. Take the brush roll and belt off the vacuum. Put the head back on the vac.
2. Turn it on and see if the bag inflates with good power. Does it sound normal? This will tell you if the problem is with the motor. If you have a good inflation of the bag and a bad noise in the motor, you need to take it in for service. If the motor is fine, you need a new spinning brush assembly.
The screw heads of the brush roll face towards the floor so you can adjust them while the brush is in the vacuum. When you turn them clockwise the brush comes down and gets closer to the floor for better carpet cleaning. You should also change the belt on that vac once a year. Just because the belt isn't broken doesn't mean it's o.k. Once they stretch out the power from the motor is lost and the brush won't clean anything.
Oct 05, 2009 | Vacuums
Kirby g6 making loud whining noise
That Is a common annoyance with Kirby's. They whine like that in hose mode. I have a g6 and it does it to. And they also get hotter.
You can hear the whining in this video.
Mar 19, 2009 | Vacuums
How to connect the vacuum system in the swwiming pool
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=564116
Generic problem for all Vacuums
Posted by herpor on May 02, 2008
How to connect the vacuum system in the swimming pool
This is not a problem that I can help you with, you need to contact someone in your area that deals with swimming pools and they have vacuums that are specially designed to do the swimming pools and they can better direct you in what to do.
Don – The Vac Man
Go Ahead. Use Us.
May 02, 2008 | Vacuums
Kirby g6
Could be the bearings, especially if the machine is old or the dust filters have not been replaced regularly.
Check to see if the noise is still present after the machine winds down when the power is turned off. A rattling sounds means bearings.
Dec 31, 2007 | Kirby G6 Bagged Upright Vacuum
Can you reverse the vax 2000 vacuum cleaner to pump up a pool
Some vacuums come with a blow part as well as a suction port. You will just have to find one of those, Rexair and electrolux is a couple of them that have both ports, but even those, not all models come that way.
Dec 07, 2007 | Vacuums
Kirby G6 Bagged Upright Vacuum Logo
60 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
