If belt is ok, then likely the rear wheel dogs have seized. Review the following PartsTree diagram, what they call ratchet key item 3.
https://www.partstree.com/parts/honda/mowers-walk-behind-lawn-mower/hrb216-tda-honda-walk-behind-mower-made-in-usa-sn-maaa-1000001/rear-wheel .
When the mower is off, you would normally hear the dogs click as you pushed the mower. These get dirty from debris and then rust up and seize (no longer click). Once seized, the transmission drive shaft just spins inside the drive gear.
Remove bolt wheel and wheel to access and clean out all the dirt and debris. Inspect inside side of rear wheel and verify wheel gear is in good condition. If all looks good then onto the drive gear.
You could try penetrating oil, but if dogs are seized you'll likely need to remove the gear... the key is spring loaded so take not to loose the key and spring. They're small pieces and once they launch they may be lost forever.
I don't remember if the "cover" has to be removed. If it does, there are a lot of small parts, be careful not to loose and keep in correct order. Consult diagram frequently.
Not sure but check and see if the propeller that throws the seed turns, I feel the gears that the wheels are hooked into are seized. Try turning the propeller
by hand and see if you can free it. If its too bad you may have to get a new spreader.
i would guess that the belt is'nt tight enough when engaged. when you press the drive bar on the handle it should make the belt really tight if not it will need replaced. sometimes the gears in the wheels will mess up. there are videos on you tube that describe that and also the belt.
Toro 20016 self propelled walk behind when the wheels are engaged it moves, when the wheels are not engaged, the wheels look up. What should I do to fix the problem
The indentations that the Hoover U6311-930 self propelled leaves are from the two large wheels of the self propelled system under the bottom of the vacuum. There are two main reasions for this the weight of the vacuum cleaner and that the carpet fiber has worn, do to age, and now shows the tracks. There is no sollution for this problem.
Try taking the back wheels off and lubricating the joint cogs and wheels with ,say, 3 in 1 oil . The dealer recommended doing this once every couple of years as preventative maintenance when I bought mine , and it has solved sticking problems for me .
