Question about Jandy Lite2 LJ125 Ceramic Gas Heater
The burner runs for eight seconds and shuts down
Just installed the heater and the unit starts and burns nicely for 8 seconds and shuts down. No flame icon appears just a flat line. Does this 3 times and throws the FL2 error.  It is an electronic start model.  110 volts.
  • troutfish001 Jul 23, 2009
    This problem is solved. A serviceman cleaned the flame sensor with emery cloth and it worked.
    Flame sensor needed a cleaning with emery cloth.
    Works fine now.
    President:
  • 1,723 Answers
Is the burner actually on? If so, the flame sensor is not working or out of flame.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 03, 2009
  • Craig Butler
    Craig Butler Jul 23, 2009
    I said it is the flame sensor, could you give me a rating?
Slant fin boiler galaxy natural gas, pump starts and runs. Igniter comes on . Pilot lights. Burner lights. Runs for seconds. Burn shuts down. Igniter starts pilot light, pilot goes out and on and on
The flame sensor, which is located in front of one of the burner flames is probably oxidized and needs cleaning or replacement. If the unit can't "sense" the flame, it will continue to cycle.
Jan 22, 2017 | Slant Fin Heating & Cooling
Won't stay lit
check gas pressure to unit with other devices running may have to turn up regulator pressure to feed unit
Dec 21, 2013 | Girard Tankless RV Water Heater 1GWHM
Pentair MasterTemp 400 Stack Flu Sensor Reading Stuck
check gas pressure and for clogged burn tubes unit is overheating
May 12, 2012 | Pentair Mastertemp Pool & Spa Heater Dual...
Ravenheat he85aaa combi boiler running fault
sounds like low water pressure, check pressure guage, get unit serviced
Nov 27, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
H400FDN... Lights... burns for 5 secs... turns off... repeats...
Pull your heat tray and clean burners and check for rat nests. A common cause of this is spider webs in the gas orfaces on the supply pipe. If you remove the brass orfaces they may have small,small,small tiny webs inside them oyu can blow out or clear with a toothpic. they dirvet the gas from the main burner (the one with the ignitor) as the gas builds it will poof and start but then the other burners that have gas flow won't be close enough to let the ignitor read flame so it will cycle just like you describe. My kingdom for a toothpic. I have made a tool to do this out of a stripped wire bent just so with the end roughed up to catch the webs so I didn't have to pull the tray on heaters with this proble. You should pull the tray and see the whole problem to understand it better.. I hope this helps and good luck.
Oct 02, 2009 | Hayward H Series Pool & Spa Heater 400k...
The igniter glows and the burner starts but shuts down after abou
one of two things it could be the flame sensor or the control board for the entire unit
Oct 02, 2009 | Goodman GMS90703BXA Heater
Furnace starts properly, then shuts down, led flashes 8 times
The first thing to look at is the flame sense rod.
Shut off power to the furnace, remove, clean sensor with steel wool or sandpaper then reinstall the sensor. Reapply power and it should run properly.
Jan 10, 2009 | Goodman GMS90703BXA Heater
I have the williams wall mount & it shuts down after awhile..
Probably needs to have the burners blown out. The yellow is a sure sign of rust and stuff inside the burners disrupting the formula of air to gas ratio. Just needs a good blowing out.more
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 10, 2009 | Williams 2509612 Ceramic Mid-Size Heater
3 year old Beckett AFG with Clean-Cut system. New inline filter new strainer, new nozzle, flame looks correct in pattern always. Flame does not sputter prior to shut-off. I did notice that when it shut off...
Called Beckett at 1-800-OIL-BURN and explained the problem. They told me that the solenoid on the oil pump (Clean Cut) was the cause. I purchased a new pump for $50 at the local plumbing supply and installed it. Problem solved.
Nov 20, 2008 | Heating & Cooling
Jandy Lite2 LJ125 Ceramic Gas Heater Logo
398 people viewed this question
Top Jandy Heating & Cooling Experts
Craig Butler
Craig Butler
Willie Burks
Willie Burks
Level 1 Expert
David Spradling
David Spradling
Are you a Jandy Heating and Cooling Expert? Answer questions, earn points and help others
