Question about Polaroid FLM-323B Television
FLM-323B HD blue screen, no signal.
I used to be able to get the chanels, but when selecting HDTV on the input menu, I get a loud popping repeated from the speakers. If I select Menu and try and get to the HDTV section, as I get to the tab, the screen clears and locks up. No remote buttons work except the power button to turn off the TV. I know HD is there because off the same Antenna, I have used a HD CD recorder and its picks up the channels without issue..
Have tried to boost the signal thinking the ATSC tuner had gone "deaf" but no joy there either, Anyone any ideas?; Global reset key combination, Firmware upgrade available? Diagnostic key sequence ? Anyone got a service manual?
  • Brett Nov 13, 2012
    I have the same exact problem and found more on here with the same problem. So far there is no answer for this. No the connector is not sticking half way out and no it did not get wet - and yes all the proper input selections are made. So does anyone have a REAL answer for this problem?? Looks like more than a few of us are looking. Let's get past the simple basic 101 answers and "make sure the set up is correct" stuff. Gotta be the tuner huh? I get the popping in my speakers as well so is there a line voltage problem or maybe some bad solder joints in the tuner? I don't know but I would love to find out!!
  • 28 Answers
For the remote change battery or get new remote, For the TV make sure that your cable is plugged in properly and not half out. or has it previously been wet. Reason because it sounds like your TV has had a static charge.
Posted on Jul 03, 2009
    No - none of this helped.
  • Pete Franchi Nov 13, 2012
    The fix for this is to replace the ATSC tuner module.. there are several on Ebay but it looks like static from a nearby lighting strike was the the cause. Not enough to physically fry anything but enough to zap. I replaced the module.
Polaroid lcd HDTV FLM-323B can not receive stations with external indoor antenna
INDOOR ARIEL MAY BE TO WEAK LO FOR TV APLIFIER ARIEL ON EBAY OR GET OUTSIDE ONE FITTED
Sep 28, 2017 | Polaroid FLM-323B Television
Tip
Polaroid FLM-323B Service Manual Download
Download Polaroid FLM-323B LCD HDTV Service Manual
Models: FLM-2632 / FLM-2632M / FLM-2634B / FLM-3232 / FLM-3232M
Models: FLM-323B / FLM-3234B / FLM-3732 / FLM-3732M / FLM-373B
Models: FLM-3734B / FLX-374
Have you misplaced your Polaroid FLM-323B LCD HDTV Service Manual?
Would you like a digital, searchable, pdf version of the Polaroid FLM-323B LCD HDTV Service Manual?
Follow this link (& click FREE) to download a pdf version of the operations manual.
I hope that helps.
____________________________________
Polaroid FLM-323B Manual Download
on May 01, 2010 | Televison & Video
Tip
Download Polaroid FLM-323B LCD HDTV Manual
Have you misplaced your Polaroid FLM-323B LCD HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Polaroid FLM-323B LCD HDTV Users Guide?
Follow this link
I hope that helps.
_____________________________________________
Can turn my polaroid tv on but cant get the hdtv input to come in....there is a slight buzz even without the antenna cable connected....when i bring up the menu and go to select hdtv the menu automatically...
The tv Tuner signal board is the causes and the problems.That the board,where the antenna signal wire plug into it to receive the incomming broadcasting tv signal channels stations.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Apr 04, 2011 | Polaroid FLM-323B Television
Tip
I hope that helps.
on May 01, 2010 | Polaroid FLM-323B Television
Tip
Follow this link
I hope that helps.
323b - hdtv attached to hd antenna will not work anymore
If you have had a cable or dish connected previously, Check in your menu and make sure it is set up for antenna and not cable.
May 29, 2009 | Polaroid FLM-323B Television
Cannot get digital OTA with antenna to work
Hi hindsite97, I will be happy to help.
  1. Press the menu button
  2. Use the up/down arrows to select Menu setup
  3. Press the right arrow button and then the up/down arrow button to select Auto Program
  4. Press the right arrow button to select Auto Search
  5. Press the right arrow button to begin Auto Search
This should FixYa as long as the Tv is operating correctly. Here is a link to the users manual in case you don't have it. http://www.polaroid.com/service/userguides/ce/lcd_tvs/fla3232b_fla3732b_ug.pdf
Let me know if this helps and please rate this solution. lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Jan 13, 2009 | Polaroid FLM-323B Television
Polaroid FLM-323B HDTV Loud Buzzing
Hi.
If your happy to remove the back casing of the the TV set.
Lay set face down on table with several towells laid out flat under it.
Undo all screws holding back on & lift it off you may need to remove tv stand to remove back.
Once back is off either locate speakers & unplug the leads from them remember to insulate the loose wires & tie them up out of the way.
Or trace wires from speakers to there plugs & sockets on main Pcb & unplug them & thats it.
Screw rear of set back on & ensure volume is set low or at zero.
http://dysonmanuals.llc.nu/
Jul 13, 2008 | Polaroid FLM-323B Television
Polaroid FLM-323B Television Logo
405 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
