Question about GE Spectra JBP78 Electric Kitchen Range
Steam is coming off of the back right burner when oven is on
I noticed that steam was coming off of the back right burner when the oven was on (appx 400, it had been on about 20 minutes). I wiped the water off of the top and new water condensated there and more steam... I shut the oven off. It's a GE Spectra Range
  • 999 Answers
In order for the oven to work air must circulate. You may have noticed the door seal does not meet at the bottom. Air enters there and exits the chimney located in the console area. Hot air meets cooler surfaces equals condensation. Some foods have more moisture than others.
Eric
Posted on Jul 03, 2009
  • photothia Feb 17, 2011
    i have the same problem but it has gotten worse. it is no longer a little bit of heat but full steam that could burn you. i have had this stove for ten years. this problem is about six months old now. how can it be fixed?
    i understand the meeting of cold and hot will cause condensation but if that were true why is it only on one burner? that sort of contradicts the cold meets hot theory.
I have a Belling DB4 90Ei Cooker and I have noticed a hole in the back of each oven. Why is this ( top left hand corner of photo/oven)
Oh that one. It is the vent to the warming section of the hob, or a vent to the top under a burner. It releases steam from the oven cavity.
You could have clicked COMMENT to my last reply :>)
Sep 14, 2016 | Belling Ovens
I had a pot of water bowling on the right burner. Steam came up while the microwave was running. I heard some popping noise and now the microwave will not heat. What do I need to do?
Call a repairman. Seriously, it may be a thermal fuse located on the bottom of the microwave oven, or the steam and moisture may have gotten into and damaged the control board. You MIGHT try unpluggin the microwave oven for a day, (for the moisture to dry out), and then plug it back in and try it again, but if that fails, then you've got problems.
Oct 18, 2014 | Microwave Ovens
RATIONAL CPC GAS
Hi, does the oven work okay on hot air? Steam function uses the steam burner and hot air burner so there is alot of possible causes.
Mar 21, 2014 | Combi Ovens
I have a Miele h5080bm microwave oven. How can I clean the grease of the roof and sides of the microwave?
You can put a microwave safe bowl of water in the oven and heat it to boiling, stop the microwave, then leave the bowl of water in the oven for about 10 to 15 minutes. The steam will loosen the dirt and grease and then it can be wiped with a damp sponge. More stubborn grease my need dish soap on the sponge and a little more elbow grease. Rinse it well with a clean sponge or dish cloth and warm water.
Feb 15, 2013 | Microwave Ovens
Water coming out oven no steam and it will not get to tempeture
If your oven isn't reaching temperature you will not get steam. Turn the oven on and verify that the oven is calling for heat by looking in the temperature window next to the arrow that says "heat" or "on," if the set temperature is 5 degrees higher than the actual temperature there should be a small red dot next to the arrow. Then observe the burner, does the exhaust fan come on, can you see the ignitor glowing, does the burner light, does it stay lit or go out after 4 seconds? You could have a dirty flame sensor, the small rod with a wire attached to it at the top of the burner, remove the flame sensor and clean it with a cloth, wire brush, or emory cloth.
Jan 02, 2011 | Baxter OV300E Stainless Steel Electric...
SET DIGITAL THERMOSTAT TO SAY 350 DEGREES WILL NOT TURN ON OVEN,,, ? IF I SET TO BROIL BROIL WORKS BUT OVEN WILL NOT TURN ON ?
Possibly the ignitor for the main oven burner has failed--
An observation question:
When the Broiler 'lights' and comes on, do you notice the ignitor glowing bright, before the gas valve (to the Broiler) opens, and you get the Broiler lighting---
Now-- for the main burner to come on, -- there has to be a similar bright glow from the MAIN BURNER ignitor, before its main burner gas valve can open-- No Ignitor?-- No ignition, and not Main Oven burner!
Let me know what you need from this point on --
Mack B
Dec 30, 2010 | Maytag CWG3100A Gas Single Oven
We had the oven on, and steam came from area behind the back right burner. Food burned a little bit.
Hello- Oven vent exits this area. Very hot exhaust - you will see smoke and or steam when sumpthin burns. Scrape and clean spills w/water. Avoid 'self-clean' function- NOT healthy for ANY range-no matter what the salesman said. - Hope this helps- ED
Feb 28, 2010 | GE Spectra JBP78 Electric Kitchen Range
Oven and coil burners work one time then the next time neither one warms up, try again later and it works again. started last week when the oven preheated put in food to cook and half hour later noticed...
If this is an electric range, it sounds like you are not geting 220v all the time. check were your cord or house power hooks up to range. You may find one side of the 220 line burnt. Shut off power and repair conections. or call a qulified tech.
Nov 22, 2009 | Ovens
Microwave oven H-4020 BM...... How to clean inside????? I am unable to get the stains off and inside looks terrible.
First, wipe out any excess crumbs. Then fill a microwave-safe bowl with about 1-2 cups of water. Add some lemon juice, or put in half a piece of fresh cut lemon (squeezing some juice out first) into the bowl... Microwave until the water is boiling. Then let it sit for a few minutes to let the steam penetrate the interior. Carefully remove the bowl and interior tray. Wipe down the interior with a damp cloth. Wash the tray in the sink with dish soap, dry, and then return to microwave. For the outside, spray with a kitchen cleaner and wipe with paper towels. The main idea is that the steam from the water will loosen food particles, and the lemon will add a fresh smell.
Jun 23, 2009 | Miele H187MBALU Convection/Microwave Oven
GE Spectra JBP78 Electric Kitchen Range Logo
932 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
