Question about Lexmark Office Equipment & Supplies
Mod no 4423 002 cart. n0 2 color works but no 3 black reply unsuported cart. install correct print cart. what am i doing wrong amaysing@insightbb.com
SOURCE: My Epson RX620 black cart absolutely will not print
Problem Solved!!!!
I bought the special cleaning cartridge as suggested and it worked very well. My RX620 is working like new!
Thanks!
Posted on Jul 11, 2008
Adi_Taticu
  • 71 Answers
SOURCE: hp 2605dn Black cartridge is printing 1/8" LEFT of other colors.
That problem is frequently on HP 2600 series.
You must try to change all remanufactured toner cartridges with HP OEM with no exception, the best alignment it is when you change the black cartridge and the printer make a cleaning page process. Cartridge HP OEM should be almoust empty. It Is not necesarry to be a new one. After the alignment process, you can put the remanufacturated cartridges back on.
This was work for me. 100%
Posted on Oct 06, 2009
  • 217 Answers
SOURCE: HP 2605dn Black prints 1/8" offset to left. Colors do register
Missalignment problems ae not uncommon with this series of printer.
The cause is one of the sensors (which are used for calibration and alignment) on the transfer belt, is faulty.
These sensors are NOT availale, and replacement of the transfer belt is the solution.
Transfer belt replacement on these printers requires quite a bit of dismantling, its not considered to be a user replacable consumable.
Posted on Feb 09, 2010
  • 670 Answers
SOURCE: I have a Samsung CLX-3160FN multi-function color
If the black toner prints like the image below with alternating bands of light and dark printing, the problem lies with your imaging unit.13911cf.jpg Specifically the developer blades in the imaging unit has toner build up on the blades. The more you use a particular color, the more it builds up to the point that it exhibits itself as faded images on the paper.
It can be fixed by replacing the imaging unit for $100+, but it will reappear again after sometime. Or you can fix the problem yourself and save yourself $100. You will need to open the imaging unit and clean the blades. I have a description on how to do this in my tips section. Or your can click on this link, http://www.fixya.com/support/r4120906-clean_developer_blades_samsung_clp_300. Hopes this helps you.
Posted on Jul 08, 2010
Testimonial: "I followed the easy to understand instructions and it now works LIKE NEW! THANK YOU!"
wrinaldo
  • 185 Answers
SOURCE: Xerox 6130, prints black very light. Replaced two
I think your Image Unit is going bad. Order this PN 675K69244...That should solve it.
Whit
Item, Inc.
Posted on Aug 10, 2010
I want to print with only black cartidge
make sure color cartridge is installed correctly...even if empty...then ignore empty cart. warning...u can print with only black if installed correctly:)
Dec 24, 2011 | Canon PIXMA iP1600 Printer
My printer only prints color..have installed new black cartridge but still only prints color so installed another new black cartridge and still only prints color
Unlike most printers where the print cartridge and printheads are attached and sold together, the ESP 3 has a separate printhead from the cartridges.
Remoe both cartridges. Then look at the place where the cartridges sit. There is a latch you push down in the back. This will release the printhead to allow it to be removed.
Remove the print head
Take a cotton swap and a little alcohol and clean the printhead of all ink. Repeat this until it is totally clean.
Make sure the printhead is dry and clean of all ink and alcohol.
Replace the printhead.
Place cartridges in and test.
If this does not work, then you need a new printhead for this printer.
here is an example of how to remove and replace printheads for thsi unit.
http://faqs.kodak.com/atg/faq/attachments/AUR1780-2.pdf
to gt a new printhead you must contact kodak
http://www.kodak.com/go/contact
probably as expensive or almost as expensive as a new printer.
The seperate printhead from the carts are why kodak can have their ink so cheap. Those other brands cost that extra 15-20$ for the attached new head with each cart.
Jun 12, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printer printing out wrong color. i have cleaned the cartridges several times, checked to make certain tape is off. How do I configure the printer to allow me to have access to the printer service to...
Print a test page. if that is ok, then it could be the color profile you have selected. Also, you can make your own test pattern of Yellow, magenta, and cyan. (use mspaint and make 3 colored bars, a black bar, and a white background). Print that, and see if all 3 colors and black are printing. If one color is not printing (ie, yellow for example) then there is an issue with that printer head on that cartridge. If you are recycling the carts, then that cart needs replaced.
Aug 28, 2009 | HP Photosmart C3180 All-In-One InkJet...
Printer cartridge missing
Make sure ur using the correct cartridge.....
for X2580 the cart number is 2 and 3
1.Cleaning the copper contacts on the carts as well as the copper contacts inside the cartridge carrier......
2. Remove the carts....and install the carts thru the solution center...(Start-programs-lexmark-solution center-maintenence -install carts
Clean the ink nozzel using a wet paper towel.....do not whip it ..just press and hold the nozzel....do this 3 or 4 times....
then
Install the carts...
open solution center.....click maintence tab...click on "clean to fix horizontal streaks"...
-----XXXX----
Apr 09, 2008 | Lexmark All-in-One Printer with PictBridge
Printing Problem
Is printing black >>yes printer is fine..
Open the printer properties. You will find the Print Color images in Black and White option uncheck it and apply ok..
if this does not solve the problem please the below pro""""
If the colour cart is kept for long time unused it may dry and result no print.
Try cleaning the cart nozzels(at bottom of thr cart i.e ink comes out ) use this link to follow the clean and wick:http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:549:0:0&framed=&docid=ENUS0&relevance=0
Mar 15, 2008 | Lexmark X75 All-In-One InkJet Printer
Print black w/o color ink cartridges loaded
No, in general all current inkjet printers require the installation of a color cartridge even if you want only black printing.
(If you had an old cartridge "Empty", you might be able to purchase a resetter (Epson) and set you printer to print in black only.)
You can, set up your computer to print in black only by selecting Mono printout in your print set-up.
There are a few Canon printers (Older) that used to print in Black or Color only printing....but no longer available......
Feb 09, 2008 | Office Equipment & Supplies
Color prints too dark
1. Took out the color ink cart and clean the copper contacts of the ink cart with cotton swab, make sure that you do not touch the silver nozzle .
2. Try new ink color ink carts as someime this issue came up when the ink carts are about to finish up.
3. Replace the ink carts and do not us a refill ink.
Dec 26, 2007 | HP OfficeJet D135 All-In-One InkJet...
Printer jamming when printing in color
make sure the color cart. are installed correctly
Nov 22, 2007 | Canon Pixma iP6000D InkJet Photo Printer
Cannot print
It seems that another cart is empty. Check all cartridges when printer is off. And yes, you do need the color ones to print in bk.
Sep 24, 2007 | Brother MFC 420CN All-In-One InkJet...
Printer won't work
Did you use original carts? In case your carts are third party ones, this is a common problem due to diffrent construction of the carts. Disconnect mfc from power (unplug!). Open cover, take carts out. Wait two minutes. Reconnect (plug in) mfc to power. mfc demands carts. Place the carts right back. mfc should start cleaning. In case you are asked if carts are replaced push yes (1). Set date and hour again (and faxnr. etc)... http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_list.html?reg=us&c=us&lang=en&prod=mfc420cn_us&Cat=16
Sep 11, 2007 | Brother MFC 420CN All-In-One InkJet...
169 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
