Question about Sony VAIO VGN-UX280P Notebook
ADMINISTRATOR PASSWORD -HELP!!!!!
IT WONT LET ME RESTORE MY COMP WITH OUT ADMINISTRATOR PASS. I DONT KNOW THE PASSWORD ? HOW CAN I GET IT
  • 1 more comment
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    What color screen is it coming up on? Can you get into the BIOS and if you let the hard drive run will it get to a windows screen or another password screen? Is it a situation where no matter what everything is a password screen?
  • Doly LJ May 05, 2014
    Windows admin password forgotten is a normal thing nowadays and many ways you can choose to unlock. If you have a reset disk you can use it crack directly; if don't have, you can create one by yourself with blank DVD/CD or formatted USB flash drive. To create one you can download Ophcrack or Anmosoft Windows Password Reset. But personally, I strongly recommend Anmosoft, which is more effective and safer and you can learn more from:http://www.resetwindowspassword.com
  • Toby123 Jul 10, 2014
    To reset Windows admin password you can use four ways. The first one is using safe mode to unlock. The second one is to create a reset disk through downloading free reset program, like Ophcrack or Offline NT Password & Registry Editor. The third one is to reinstall the system. The last one is Windows Login Recovery, which can help you reset in 5 minutes. And personally recommend Windows Login Recovery and more details you can visit:http://www.windowsloginrecovery.com
  • 25 Answers
At one time , I had the experience with forgetting Windows password. Finally I use Windows Password Reset .The program is easy to use.
Here I just list the simple steps:
Step 1: Download Windows Password Reset from http://www.windowspasswordreset.net
Step 2: Burn bootable CD/DVD or USB flash drive
Step 3: BIOS setting
Step 4: Reset Windows password
It's worth a try! Good luck~
Posted on Jul 26, 2012
    Problem Solver:
  • 6 Answers
As far as I know, you can use free software or paid software to recover an Administrator password. Free one not only wasting you a lot of time, but also losing data sometimes. Paid one will be more safe and stable. I recommend this website: http://www.passwordseeker.com Hope it helps you. Good luck!
Posted on Nov 29, 2011
    Novelist:
    Scholar:
  • 175 Answers
You can use Windows Login Recovery to reset windows 7 administrator password as soon as possible.
Posted on Nov 28, 2011
  • 28 Answers
The administrator password in Windows XP is the password used to access the "Administrator" account.
This account usually doesn't show up on the logon screen and most people don't know it exists. Usually that's okay because you won't need to use your computer under this account very often.
There are a few times when you will need this password! When you're accessing the Windows XP Recovery Console or you're trying to boot into Windows XP Safe Mode, you'll need this password before you can continue.
Follow the steps below to quickly find the administrator password on your computer!
Difficulty: Average Time Required: Retrieving the Administrator password may take a few minutes up to hours depending on the situation Here's How:
  1. Try leaving the password blank. More often than not, the Administrator password doesn't exist at all! Just press Enter without typing anything when asked for it.
  2. Enter the password to your account. Often times, depending on how Windows XP was setup on your computer, the primary user account will also be the administrator user account.
  3. Try to remember your administrator password. If you installed Windows XP on your computer yourself, you probably set the administrator password during the Windows XP installation process. If that's true, you might be able to make really good guesses at what the password might be.
  4. Have another user enter his or her password. If there are other users that have accounts on your Windows XP computer, one of them may be setup with administrator access.
  5. Recover the administrator password using a password recovery tool. Password recovery tools are software programs that work by making super-fast guess after super-fast guess until the password is discovered.
    Note: Some password recovery tools is the list I linked to above also have the ability to transform regular user passwords into administrator passwords. This could be valuable if you know your account's password but it's not an administrator account.
  6. Perform a clean installation of Windows XP. This is a last resort option. This type of installation will completely remove Windows XP from your PC and install it again from scratch.
    If you're just curious about your administrator password, I wouldn't suggest this extreme solution. However, if you're needing the administrator password to access diagnostic tools and this is your last effort to save your PC, performing a clean install will work. Keep in mind that it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
Posted on Jul 03, 2009
    Problem Solver:
  • 13 Answers
If you can not remember the windows admin password, try to reset it
with a reset disk. Free download windows password unlocker from
http://www.passwordunlocker.com and there is a .iso file included.
Burn the .ISO file onto a blank CD which is so-called windows
password reset disk. With this disk, you can reset the unknown
password without erasing anything
Posted on Jul 08, 2009
Windows 7 command disable passwords
Make sure cmos battery is fresh, then reinstall restore disk and write down password if any. Administrator password is stored in bios.
Feb 09, 2012 | Dell Inspiron N4020
I have a latitude D620. and i just bought it and had to transfer ownership with dell just to get passed the bio password. now there is a windows log in that needs a password and i dont know the original...
Hi
please try this
press the power up key and keep pressing the F8 key until
the safemode box comes up
then choose safemode with networking
then click the name administrator if its there
or any other name that is a administrator without a password
if and when you are on the desktop and everything is loaded
go to
start
settings/control panel
user accounts
change an account or create an account as an administrator
click on the account name which is causing the problem
click on remove password
now you can either leave the account without a password
or create a new password or delete the other account completely
your choice
please let us know if this has helped you
so that we may be able to help others
many thanks
Jun 15, 2011 | Dell Latitude D620 Notebook
What do I do if I forgot my login password?
try booting into safe mode by pressing F8 when you turn your computer on, before windows starts
try to login as administrator leave the password blank
if you successfully log in go to "control panel" then "user accounts"
select your account and change your password.
If you are unable to login as administrator in safe mode you can try a password recovery tool
http://pogostick.net/~pnh/ntpasswd/
Apr 06, 2011 | Computers & Internet
Lost administrator pass and i have only access to my system my wife and i share the same computer. i dont know how but one of us or our grand daughter lost the administrator pass word and we only have...
so im guessing that your problem is that you want the Administrator password back?
in this case, there is one thing you could do. It's called "Offline NT Password and Registry editor" and you can download it here. You can use this program to change administrator passwords, elevate privilege levels and create new accounts with administrator settings. Read up on it, give it a go. Let me know how it works for you.
Oct 09, 2010 | Microsoft Windows XP Home Edition
I dont know the pass code...?
the simplest way is by restoring the default configuration and then reconfigure the passcode.
You can erase the
current configuration and restore factory defaults in two ways:
• Use the Erase function of the router (see “Erasing the Configuration” on page 6-7).
• Use the Default Reset button on the rear panel of the router. Use this method for cases when
the administration password or IP address is not known.
To restore the factory default configuration settings without knowing the administration password
or IP address, you must use the Default Reset button on the rear panel of the router.
1. Press and hold the Default Reset button until the power light blinks on (about 10 seconds).
2. Release the Default Reset button and wait for the router to reboot.
If the wireless router fails to restart or the power light continues to blink or turns solid amber,
the unit may be defective. If the error persists, you might have a hardware problem and should
contact technical support.
Dec 25, 2009 | NetGear WGR614 Wireless Router
I changed the account user pasword on my pc and now i forgot what it is how can i get passed it?
Can you go in as another user?
You dont have a "hint"?
Can you get in as administrator (safe boot)?
I think if you are in XP and you dont have the password ... you are up the creek with no GPS
I think id try the safe boot option first. Otherwise, it is reformat, reload, loose your will and your novel.
In the future, you migh want to consider at least two accounts for yourself - one as user and the other as administrator. Use the user for daily stuff and the administrator when you have to and for emergencies. That way, your private stuff will be password protected and if you forget your password, you can go in as unprotected (no password) administrator and fix it.
Let me know if this helps
a
Sep 23, 2009 | Dell Latitude D600 Notebook
I put in a new administrative pass word and i dont remember it
use a hiren"s disk to remove the administrator password.let me know if u have the disk then i can guide u .
Sep 11, 2009 | Acer Aspire 5920 Notebook PC
Dont know how to use restore cd for emachine w3609
open disc drive (cd rom) place restore disc in . turn off computer and turn it back on. follow instructions on screen. on re-boot you might have to hit the f8, f10 or f12 key to get started if you can, go to e-machine.com to get tech advice.
Jul 08, 2009 | Computers & Internet
Administrative password by pass
Operating system, please? Is this your laptop? Did you set it up? You need to be an administrator to install software. If you set it up you should have created an admin password or left it blank. Try logging in as administrator without a password and then go into user accounts to change your login to have administrator rights.
May 06, 2009 | Computers & Internet
Sony VAIO VGN-UX280P Notebook Logo
1,164 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
