Question about Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402
I have a Rheem 50 Gal. Power Vent 2 hot water tank (Model PVS50) and it just stopped working. It is probably about six or so years old. There is a "steady red light" on that indicates that the "control" must be replaced. Is the "control" a module? Is a replacement easy to find and install? Any advice for the DIYer, or should I call in an expert? Thx, Don
    Problem Solver:
  • 17 Answers
I would recommend calling a pro. the power vented units can be difficult to work on. And parts usually have to be ordered.
Posted on Jul 29, 2012
  • 297 Answers
Don, if you have done this before go for it. If not call a pro,you will thank yourself later!
Posted on Jul 15, 2009
Works for 2 or 3 min then burner kicks out
www.rheem.com/products/tank_water_heaters/contact_support
Jul 03, 2014 | Rheem Richmond 50 Gal LP Gas 6 Year Tall...
I put a new top thermastate, bottom thermastate, new top element, bottom element, on my electric 50 gal tank and didn't get hot water. Only 4years old. Bought a new GE 50 gal. tank and installed, even a...
The next thing you need to do is find out whether you have 240v to the bottom element....the top will not heat till the bottom is satisfied...
An electric meter is critical when working with these units....trace the power and see where it stops....
here also are some tips that will help you...
Electric Water Heater Wiring Diagram
Electric Water Heater not Working
heatman101
Dec 04, 2010 | Rheem Water Heaters
Rheem Power Vent PVS50-36FV..Constantly goes to lock out..Unplug it turn it off . wait and turn on but sometimes in a day or a week again goes out .\r\nWhat to do??
Call the manufacturer phone # that is printed on the water heater. You probably have the model that requires a retrofit burner with reset button to be installed to fix this issue. You will also have to clean out the bottom screen filter below the burner when you change it out. They will need the model # & serial # to check if yours needs this. Douglas
Oct 04, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Rheem RHEEM 50 GAL ELEC TALL Water Heater 1.5 yrs old, power at the elements, new elements installed new thermostat installed, still no hot water.
Hello Check the red overtemp reset button at the temp control.Check for contintuity at the elements with a volt meter (pull one wire off first) they should have a reading otherwise they are open & shot.Last is overdrawing (busted pipe) shut off the cold water supply for a 1/2 hour and open it back up and feel the hot water supply pipe.Is it hot?The tank can't keep up with the demand.
Sep 16, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Rheem power vent motor doesn't shut off
There could be blockage in your water heaters venting on the outside of the home. It sound like the high limit switch has been tripped. Try unplugging the tank and plugging it back in. this will reset the tank. if the problem persists you will want to call your provider for service.
Oct 07, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Power vent 50 gal tank flashing code 2-3
1. Turn off power vent blower and set water heater temp to vacation (lowest temp)
2. Turn on power vent blower
3. Turn the water heater temp from vacation (lowest temp) to hot (highest temp) four times.
4. Set the water heater temp to normal
Aug 21, 2009 | Rheem Water Heaters
PVS50 rheem power vent water heater do not reignite/restart/kick
I actually just installed one of these the other day, I found that the ignitor wires were straped to the gas inlet and they were shorting out,, I wraped them with electric tape and the unit came on and stayed as for the thermostat make sure your flue is clear of all obstuctions even outside, make sure on the vent on the top back of the unit is clean and no lint or dust has built up on it, you can take a small soft brush and just sweep it across it
Jun 17, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Rheem 50 Gal Hot Water Heater will not stay lit
On the back of the gas valve (where you turn the temp up) there is a stem that actually goes into the tank that senses the temprature of the water it could be dirty or buried in sediment depending on how old the tank is, or just bad. if the tank is over 10 years old i wouldn't bother replacing the gas valve, the tank is probably not far behind. A new valve will run around $100.00 maybe a little less. You wont find it at menards or home depot in stock but they may be able to order it for you. Menards sells rheem products or try you local plumbing supply house. REMEMBER TO RELIEVE THE PRESSURE ON THE TANK BEFORE YOU WORK ON IT. IF YOU CHANGE THE VALVE DRAIN IT FIRST!
Feb 10, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402 Logo
1,202 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
