Question about Samsung Televison & Video
My Samsung LN-S2341W LCD TV will not power on. The power display light is slowly and constantly blinking.
  • 5 more comments
  • kdiamond675 Jul 03, 2009
    Hi! It is 2 blinks, with about 2 seconds inbetween the first and the second, and then a 10-12 second pause. Then it goes back to the two blinks again.
    Did you get this? It is 2 blinks, with about 2 seconds inbetween the first and the second, and then a 10-12 second pause. Then it goes back to the two blinks again.
  • kdiamond675 Jul 07, 2009
    I get 2 blinks and then a long pause with 1-2 seconds between the first and second blink and 10-12 seconds until it starts over again.
    I tried going to your website to see the pictures, but the page is unavailable. Would you be willing to email my pictures? Thanks!!!
    I am happy to try to do the repair myself, but can't see your pictures. If I can't see your pictures, I don't know what I'm looking for. Please explain.
  • kdiamond675 Jul 08, 2009
    I unplugged the tv for 24 hours and there was no change. What now? I am looking for someone to help me troubleshoot and walk me through the steps to fix it.
    I checked what I thought to be the capacitors and I did not find anything bad about them. No bulging, burn marks, etc.
  • 1,959 Answers
Apart from a "power reset" (unplug the unit for an hour and replug it in) there's most likely a burned out component on the circuit board.
Posted on Jul 07, 2009
  • Greg Margossian
    Greg Margossian Jul 08, 2009
    If you're comfortable getting inside the television, go in and check the main board, (you may need to remove it so pay careful attention to any plugs you remove). What you're looking for would be a broken solder connection. All the chips are solderd and a bad/broken solder joint could very definitely cause the symptoms you now have.
  • 355 Answers
The problem is caused by parts calledcapacitors overheating in the confined space of he monitor. If you aregood at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htmYou can take the back cover off your monitor and look for the bad parts,replace any that look like the pictues and your monitor should workfine. The capacitors do need to be installed with the correct + and -connections, note the stripe on the old one and insert the new one thesame way. If you don't want to try the repairyourself we offer a repair service for $35 plus shipping. If themonitor does not have any bad caps then I would be that when the videocard died it sent a spike to the monitor and killed the driver board. Ihope this helps,
  • 15,935 Answers
Please reply with the number of blinks you are experiencing.
Example... 3 blinks pause 2 blinks
6 blinks pause - repeating
etc...
Thanks!!
Posted on Jul 03, 2009
Why is my Samsung ln-t1953h takes 5-10 minutes to power on. During boot the red light is blinking and clicking.
How old is the tv set also do you have it plugged up to a power cord? Can you tell me how many times does the light blink thank you.
Aug 19, 2014 | Samsung LN-T1953H 19 in. LCD HDTV
Samsung LN-S2341W Picture Is Black and White
color circuit is out, try banging the set on the frame with the palm of your hand to see if color comes on or fluctuates, if so you have a loose component which is only fixable by you if you are really knowledgeable about the inside of a TV
Apr 28, 2017 | Samsung LN-S2341W 23 in. HDTV-Ready LCD...
Samsung LCD TV will not turn on or off. Red light
hi,
your lcd ip board (power board) capacitor had already exhusted.
got to replace the ip board.
Jan 25, 2010 | Samsung LN-T4065F Television
46" LCD Samsung TV Model# LN-S4692D I have no picture
The back light inverter board may have gone out or it is not getting the 24vdc from the power supply module. Start checking for voltage feeding the inverter board.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Samsung+LN-S4692D+
Jan 07, 2010 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung hdtv wont turn on
try to turn on pusshing the power on button, if it works then your remote is bad. if it doesn't then you have a power supply problem . fuse, .....But know that some times, you don't have power in your outlet, your power cable is bad. check all that
Sep 12, 2009 | Samsung LN-S2341W 23 in. HDTV-Ready LCD...
LN-T405H Samsung LCD TV
yes you are right it is the power supply, look for bad capacitors.
Jun 14, 2009 | Samsung LN-T405H LCD TV
We had a power outage and the next day all I could get on my TV was the blinking power light. Can you hellp me? I have a Samsung 42" LCD Flat Panel HDTV Model No. LN T4042N edit
Hi, the power surge has destroyed the power supply board that is located inside your lcd cabinet. this board works in conjunction with an inverter board that regulates the raw ac current that is used for many different functions in your set. Normally, this type of damage will be isolated within the power supply but, it could have spread to the main control board as well, depending on how well the surge protector preformed during the surge.
The good news is that, this is a repairable situation. you can replace the power supply circuit board and inverter board as well. these replacements will fix this issue.
please rate and god bless:)
Apr 18, 2009 | Televison & Video
Constant channel display
Press Info " i " or may be Display button on Tv remote, on-screen display will disappear.
Jan 03, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
Black end "stripes" on non-HD images on LN-2341W
Arte you using a cable provider? if so you should be able to adjust it to a wide screen or stretch, most cable providers are supposed to apply the settings when installing the box, so that the screen will auto fit your set, otherwise you will get image retention
Apr 02, 2007 | Samsung LN-S2341W 23 in. HDTV-Ready LCD...
Televison & Video Logo
150 people viewed this question
Jerry Greenberg
Jerry Greenberg
