Question about Hoover F5906-900 Upright Steam Vacuum
Hoover F5906-900 motor sounds very loud.
Imagine hearing a diesel engine run at idle from inside a home, then hearing it right next to the motor. That is the way this SteamVac sounds, we went a month or so without using it and it sounds alot louder.
Any thoughts?
  • 1,673 Answers
Bearings in the motor are bad, you will have to replace the motor.
Posted on Jan 06, 2008
Hello my Hoover works well except it is has gotten very, very loud it wasn't this loud before any suggestions?
Not knowing what the loud sound is, try to determine if it's coming from the spinning brushes or the motor. Those are the most likely problems.
Mar 25, 2016 | Hoover H3030 FloorMate SpinScrub 500...
Samsung vcu366 making loud noise but picks up
what does the really loud noise sound like? Is it a loud, whining sound? if so, the motor may be getting ready to go out. Also check that the belt isn't stuck-though you would smell burning rubber if that were the case.
Mar 08, 2014 | Samsung Vacuums
Hoover H3030-006 240 V Motor making a loud sound and burning smell
If you have little to no suction, that sound is happening because you most likely have a clog some were in the vacuum.
smell is probably your motor over working itself do to the clog.
also double check your belts on your brushes that they are moving with the motor. smell and sound could come from the brushes being jammed which would cause the belt to freeze and heat up and could burn the belt and or your motor.
if it is still running though your not in the red yetm so triple check that the machine is cleared off all clogs and jams in the belts and brushes.
Jul 02, 2011 | Hoover H3030 FloorMate SpinScrub 500...
Burning smell and loud noise from hoover steamvac f5897-900
Perform general maintenance - cleaning filters,etc. If it still exists, take it apart and check the motor... If the motor is sooty on the copper coils inside, then it's had it's day. You could try and buy a replacement motor, but typically, its cheaper just to get a new hoover.
Jan 12, 2011 | Hoover F5897-900 SteamVac Upright Vacuum
LOUD hoover
if this sounds like an airplane taking off, then for your hoover U5288-900 it will have to be the fan that is inside the motor compartment. i have looked at and cannot find the part num. to the fan, but i know that you can replace it. you can also get one from your local vac shop. if you do get a fan for this and need help in changing it. write me back if you get stuck. hope this helps
Jul 31, 2009 | Hoover U5288-900 Upright Vacuum
I own a Hoover Steam Vac Plus w/ Rotating Brushes (model#F5871-900), when I turn on the power I hear a medium-loud hum coming from the motor area and nothing works. What could be the issue?
the motor sounds locked up. Water gets in there and rusts the pieces together. The motor could be replaced, but probably not repaired.
Jul 04, 2009 | Vacuums
Hoover floormate 500 making super loud noise when
You have a bad motor in the unit. It time for a new machine
May 07, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover started to make loud noise
It sounds like a bad motor. Take it to a local vac shop and they should be able to order the motor for you.
Apr 13, 2009 | Vacuums
Really loud noise.
Really loud noise.
Posted by Theresa626 on July 20, 2008
The belt inside my Hoover broke and so we replaced it. But when we did, it now makes an extremely loud noise when turned on. We think it’s the roller to the vacuum because it doesn't make a noise when the roller is not in there. The roller sounds like its hitting something. However, we have pushed and pulled and done everything and all seems to be right. Everything is clicked in and the belt is on correctly and we've followed the manual. How can I fix this problem?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me that it is a bad brushroll and could need new bearings or a complete new brushroll depending on if id is metal word or plastic. Some brushrolls are rebuildable and some are not, you can check your owner’s manual to see if it is or is not; or it could be the start of a broken fan blade or bearing in the motor section. But that is the only thing that I can think of that might be wrong. Feel free to contact your local vacuum cleaner dealer in your area or you can also contact the Hoover website or cust serv phone # listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 20, 2008 | Hoover U5018-900 Bagged Upright Vacuum
Loud noise when running.
Bad bearing or fan in the motor is most likely the problem. You would have to replace the motor.
Mar 02, 2008 | Hoover 5416-900 WindTunnel Bagged Upright...
Hoover F5906-900 Upright Steam Vacuum Logo
158 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
