Question about iRiver Audio Players & Recorders
Shuffle mode i have the iriver clix [first generation] and i cant turn off shuffle mode.
Cut and modified from Douglas E. Levy at Amazon forum:
When you're in the Now Playing screen press and hold the Play/Pause button (right edge of screen). At the top of the slide-in menu you'll see Play Mode. Click Pause button again and scroll to "Normal" and choose it.
Posted on Sep 01, 2009
NEED INSTRUCTION FOR Apple iPod shuffle 3rd Generation Silver
Connect the iPod shuffle USB cable connector into a high-power USB port on your computer.
Note: To charge an iPod shuffle battery, connect the device to a high-power USB port.
Please be aware that USB keyboards and non-powered USB hubs generally do not have high-power USB ports.
If you connect to a low or non-powered port, iPod shuffle will not charge.
The computer must be turned on and set to not go to sleep.
Plug the other end of the iPod shuffle USB Cable into the headphone port on the iPod shuffle.
Verify the iPod shuffle is connected securely.
Once the iPod shuffle is plugged in, it will take about 2 hours to charge the battery to 80% capacity and about 3 hours to charge it to 100%.
Find out how to check the battery charge here
hope this helps
Sep 18, 2012 | Apple iPod shuffle 3rd Generation MP3...
I was given an i pod shuffle as a gift from a friend but when i went to apple support the i pod had been disabled. how do i fix it so that i can put my own apple itunes on. thanks anne marie
To reset iPod shuffle:
  1. Disconnect iPod shuffle from the computer (if connected).
  2. Move the switch on the iPod shuffle to the OFF position. Note that when iPod shuffle is off, the green stripe by the switch is not visible. ht1655_1.gif ht1655_2.gif ht1655b_3.gif ht1655--4th_shuffle-001-en.png
    1st generation 2nd generation 3rd generation 4th generation
  3. Wait five seconds. For iPod shuffle (3rd and 4th generation), wait ten seconds.
  4. Move the switch to the play in order or the shuffle position. The green stripe will be visible in either position. For iPod shuffle (2nd and 4th generation), slide the power switch on (and you can see the green stripe).
Feb 24, 2011 | Apple iPod touch
How do i set iriver s100 to shuffle songs if it can
You can shuffle music with Iriver S100.
It's quite tricky, took me for a while to figure out.
1. Go to music page and then play any music.
2. Prees and hold the right arrow > the sub menu will popup.
3. Go to 'Play Mode' and then volla !!!! choose whatever you want.
Feb 09, 2011 | iRiver X20 MP3 Player
IRiver E150 Shuffle
Starting from the main menu.
Select Music.
In Music mode: Press and hold the > button to view the Options screen.
Select Play Mode.
Under Play Mode: select Shuffle or Shuffle + Repeat.
You can also look this up in the E150 manual. Download the English.zip file from next page:
http://www.iriverinc.com/lounge/loungeView.asp?selectPart=03&findWord=&sno=985&page=1&cateCode=03
Unzip the zip file, with WinZip or WinRar, to view the manual in pdf format, that can be opened with Adobe Reader.
Jul 24, 2010 | iRiver E150 (4 GB) MP3 Player
How do I turn the shuffle feature off?
On the iRiver Clix
  1. while playing music press and hold [Right] for displaying the additional features.
  2. select Play Mode with up / down for going into the playing mode
  3. press right for entering the Play Mode menu
  4. change Play Mode with up / down
note
The Smart Key on the right side of the player can also be assigned as
Play Mode switch for shuffle on / off. The Smart Key can be set in the Settings of the player.
for going into settings press right on the display
for selecting an item in settings, e.g. Smart Key, use the screen's edges up / down
press right in the screen, when Smart Key selected, for going into changing Smart Key function
press up / down for changing the Smart Key function
repeatedly press left in the screen for going back to the top menu
Jan 15, 2010 | iRiver Clix Digital Media Player
E100 Shuffle Setting
While playing the iriver hold down the > for a few seconds and you will enter into another menu of options such as play mode, equalizer, etc.
Jan 01, 2009 | iRiver E100 Digital Media Player
Formatting
You should try to upload the newest firmware for your device. Simply go to irivers site, look under Iriver Clix Generation 1 support (I'm guessing you have the generation one... if not, just click generation two). Simple as that!
Sep 21, 2008 | iRiver Clix Digital Media Player
Iriver clix2
If you have a song up just click and hold to the right and a bunch of options should show up. The first option should be "play mode" and in there you can choose whether your playlist (or album, depending on how to navigated to the song) will shuffle and repeat.
Feb 01, 2008 | iRiver Clix Digital Media Player
Cant get shuffle to work when not conected to pc
How long have you had the unit? If it's been a year and a half or 2 years your battery needs to be replaced. They loose their ability to retain a charge in that time frame, and when you test a good battery or a bad battery they will both read 3.6v as a tester does not put a load on the battery, meaning you have 3.6v when the unit is off but when it turns on (load) it drops to zero. You could also try resseting the unit, to do so follow these instructions. To reset iPod shuffle: Disconnect iPod shuffle from the computer (if connected). Move the switch on the back of iPod shuffle to the off position. Tip: When iPod shuffle is off, the green stripe by the switch is not visible. Wait 5 seconds. Move the switch on the back to the play in order or the shuffle position. The green stripe will be visible in either position. iPod shuffle is now reset. If after resetting iPod shuffle you are going to attach it to your computer, be sure to place the switch in the off position. If you were resetting as part of some troubleshooting steps, continue with those steps now. For general troubleshooting steps see the iPod shuffle troubleshooting and service FAQ. To reset iPod shuffle: Disconnect iPod shuffle from the computer (if connected). Move the switch on the back of iPod shuffle to the off position. Tip: When iPod shuffle is off, the green stripe by the switch is not visible. 1st generation 2nd generation Wait 5 seconds. Move the switch on the back to the play in order or the shuffle position. The green stripe will be visible in either position. iPod shuffle is now reset. If after resetting iPod shuffle you are going to attach it to your computer, be sure to place the switch in the off position. If you were resetting as part of some troubleshooting steps, continue with those steps now. For general troubleshooting steps see the iPod shuffle troubleshooting and service FAQ. http://docs.info.apple.com/article.html?artnum=302110 Hope this helps.
Sep 15, 2007 | Apple iPod shuffle MP3 Player
235 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
