Question about Kenmore 63942 Dryer
Electric dryer has no heat
Checked coil. It is good. Replaced themistor. No voltage to coil when running on any cycle
    President:
  • 1,136 Answers
Hi, Check the fuse and the 2 thermostats on the element housing. One of them is most likely bad.
Please let me know if I can assist you further.
Vic
Posted on Jul 03, 2009
Kenmore elite electric dryer runs but then gets hot and then shuts off, replaced thermal fuse, dryer vent and tubing not plugged, dryer runs gets hot blows thermal fuse again.
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!!
Apr 28, 2015 | Kenmore Dryers
I have a Roper Electric dryer that will not heat up and will run through the cycles somtimes. I have ordered and replaced the heating element, thermal fuse, high limit and cycling thermostats. I have
First check the thermal fuse on the back of the filter housing.
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/8-6-539031-/Kenmore-Dryer-doesn-t-heat-11060832990
Attached is a good troubleshooting video. I think that you will find that the Roper is the same as the Whirlpool and Kenmore
Note that the first thing that he does is to test the incoming voltage.
I suggest that you do this with the dryer running. I have seen breakers that will pass voltage without a load and as soon as a load is applied there is no voltage showing. As he says in the video the dryer can run on 110V as the motor is 110V however if it is missing the other leg of the 220V it can't heat. Another way that you could test this is to reverse the two incoming hot wires.
Whirlpool Kenmore Dryer Heater and Thermostat Test
Good Luck.
Sep 19, 2014 | Dryers
Why does my Whirlpool electric dryer - model SEDS800JQ0, shut off after 2 minutes?
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
Aug 09, 2014 | Whirlpool Dryers
Frigidaire Affinity AEQ6700FSO electric dryer does not heat, then shuts off within 10 minutes.
Hello Scott Joseph Brandt - Since you have already replaced the thermal limiter check your breaker or fuses. Some dryers are run by two separate fuses, one for power and one for heat-ours is. If it is not the power source more than likely the issue lies with your heating coil.
Feb 05, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
DOESN'T HEAT
Could be bad heat element. Lift top of dyer, or look from back side with access panel removed, or look thru door if glass door while dryer is running on a heat cycle. You should be able to see red glow of heat element coming on. If not then you will need to open up dyer and remove drum. Inspect heat element for break in coil or coils touching each other or metal frame of dryer. You can also use an ohm meter and read the restence of the coil ...should be just a couple of ohms.
If it is a bad coil you should be able to replace fairly easy. If it is not coil than you will need to check themistor or cycle control switch. Hope this helps.
Nov 10, 2012 | General Electric DHDSR46EGWW Dryer
Moved to new house, changed electrical cord, dryer ran fine for two days, now runs but no heat?
Need to check if the heating coils/cartridge has failed. All what is required is to check the output to the coils or check the conitinuity of the coils. If open the coils must be replaced. If voltage is not present at the time of cycle, then the output relay is faulty or there is no trigger from the program controller switch.
Sometimes it can b e a wire break to the heater but unless the circuit is tested, it cannot be confirmed.
Oct 06, 2011 | Kenmore 67082 Electric Dryer
Amana Dryer 's vent was restricted and stopped running. Now it is running but not heating and the heat elememt is testing good.What else can I check.
There is likely a high limit switch at the front near the blower. Unplug the unit and check continuity across it. Or start a cycle with it powered and check for voltage across the switch. If you read voltage, the limit is popped.
Jan 20, 2011 | Amana NDE2330AY Electric Dryer
Electric dryer heat coil off mid cycle
You have 3 thermostats. By the description of the problem it sounds like it needs a new high limit thermostat. All 3 thermostats and the heating coil can be checked with an ohm meter. Also check the ground on the heating coil. It could be grounding it's self out.
Jan 16, 2009 | Kenmore 62602 Electric Dryer
Run but want heat up
the heating coil is faulty so even though the machine starts it does not heat up.heating coil needs to be replaced compulsory to get ur machine back to work . its a very common problem in dryers.
thanks.
Sep 16, 2008 | Kenmore 62602 Electric Dryer
GE Dryer Mod DDE8040l heater coils
Check your voltage to the dryer, make sure you have the required 220 volts. If you are only getting 110 volts the dryer would run but not heat. So check the breaker or fuse box first,, then check the plug for proper voltage, then the terminal block to make sure you do not have a wired burned off.. after that it would most likely a high limit thermostat. Good luck. I hope this will fixYa. and dont forget to rate me. Thanks
Mike
Sep 06, 2008 | GE DBSR453EBWW Electric Dryer
Kenmore 63942 Dryer Logo
143 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
