Computers & Internet Logo
A
Anonymous Posted on Sep 09, 2014
How to connect star logic monitor to my lap top ?
Thomas Lesch
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Sep 14, 2014
Thomas Lesch
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1037
Points
1 Related Answer
robertmagnan
robertmagnan
  • Posted on Apr 12, 2013
SOURCE: How do you connect an LCD monitor to lap top
u cant close the lap top all the way because they have a shut of botton so u cant close it all the wat
I have a 17inch star logic flat screen monitor and every time i turn it on the monitor will come on but then it will go black i have tried to shut it off and the same thing happens
Try to connect it externally to a laptop...
and also check the vga cable that is try to connect it first with vga port and then try with dmi port if you have...
No power indications
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, check the main AC fuse, look for burnt parts, bad solder connection. You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
2answers
19" star logic MJ9BBK suddenly changed color
First check the connections to make sure they are tight,next go to desktop settings and make sure the external monitor has the same color configuration.
Star logic monitor settings
I typically do capacitor replacement on lcds all the time insde, the board for power will most likely have 1 - 4 blown capacitors, replace these and the monitor should be good as new, btw 1 is a 10 v smallish size you can replace it with a 16 volt same MF.
Star logic 19inch computer monitor power adapter STD-1205
You can use a power supply for a CCTV system. Here is a website that has one, it is for a DVR4220, code STD-1205
Info on Star Logic manufacturer
HI ,
IM HAVING APROBLEM WITH MY STARLOGIC MONITOR ALSO.....
I HAVE LOCATED THE BOOKLET THAT CAME WITH MY MONITOR AND HERE IS THE FOLLOWING ADDRESS....
SERVICE FACILITY NUMBER..508-435-4830 OR
800-639-3803
FOUR STAR GROUP
26840 FARGO AVE.
SUITE C
BEDFORD HEIGHTS, OHIO 44146
EMAIL SUPPORT: [email protected]
hope this helps you
sandie
2answers
Star Logic 17 in LCD Monitor
May be your video in the computer that trouble you.
Try changing the video card and see the result.If it is still the same that mean your video card in the LCD is the problem.
Star logis 15 inch monitor
Try connecting the monitor to another computer and see if it has the same problem. If so, sounds like part of the display has gone bad. If it is still under warranty, try to get it repaired/replaced. If it's not under warranty, you might be better off getting a new monitor rather than trying to get it fixed, but it doesn't hurt to ask.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
