Question about Garden
Chainsaw wont fire
Chainsaw has had about 2 hours work,it was going then stalled cant get it going again, there is spark i pulled the fuel line of the carby and fuel was coming out any help
    Brigadier General:
  • 4,088 Answers
Is the spark plug wet (inside after trying to start it)? If dry, the carburetor isn't delivering fuel into the engine. Check the muffler to see if it is plugged. Is the carburetor firmly attached to the engine? Fuel and spark at the right time makes it go! Try squirting a little fuel into the carburetor throat. Might be loose screws on carburetor assembly.
Posted on Jul 04, 2009
One more try before I trash it. I have a poulan p3314 chainsaw. It is 2 years old. Installed new carb,fuel lines,air filter, and spark plug. Fuel is routed properly. Can't get unit to fire. Any ideas.
Check the gap between the magneto and the magnet on the flywheel, if it is too much of a gap you wont get spark. We are talking .007 inches or less. You need a feeler gauge to set this
Apr 22, 2016 | Poulan Pro 14" Gas Chainsaw 33CC P3314
Mikita dcs6401 chainsaw wont start
How old is ths fuel in the tank? If it is older than 2 months dump it and put in fresh fuel. Use some starting fluid sprayed into the carb and see if it fires on that. It may take a few sprays to pull the old fuel through the lines till the fresh fuel gets to the carb.
Apr 18, 2014 | Garden
Chainsaw wont throttle up dies out;cleaned out carb. relaced fuel lines .
pull your muffler off and see if it revs up, if it does then your spark aresster screen or muffler is plugged, from carbon or mud dobber hornets
May 22, 2012 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
After starting and operating the chainsaw for a short time, it dies and I can't get it started again. Suggestions?
Engines require 3 things. Spark, compression and fuel. And chainsaw need 2-cycle oil mixed with the gas.
Assuming you have the right oil-gas mixture and a fresh batch of gas, and you didn't leave old gas in the saw all summer long since last November.
-Take off the dirty air filter and see if saw starts without filter. Do not run without putting in new filter.
-Check exhaust port for mud dobber home or screen clogged with carbon and dirt
-See if saw fires up after squirting WD-40 directly into carburetor
-Check gas line >>> pull gas line loose and see if gas flows out of tank to carburetor
-Take out spark plug > put finger over spark hole and pull cord >> do you feel suction that says you got compression?
-Put spark wire back on spark plug >>> hold spark plug so threads touch bare metal part of spark plug hole >>> pull starter cord and see if spark shows between plug and saw >>> suggest you not hold metal part of spark plug while pulling cord [you'll understand why]
-If spark plug shows spark, then your saw has spark ... so put in new plug and start fresh.
If your saw has compression, spark, and fuel it should start unless carburetor is gummed up because gas was left in tank.
Here is the final trick. Start the saw while spraying WD-40 directly into carburetor and see if you can keep it going with the WD-40. This might take a helper. If this does not work, then carburetor is bad or gas line is clogged at carburetor. Time to take it to the shop.
Oct 06, 2010 | McCulloch Garden
Wont start been sitting for a year turns over but wont fire cant find how to get seat off or where to drain old gas
you have to use the key and the leaver in just back from the key side then take out the bolt that holds the tank down 12 mm you have 2 hoses going to the carbs one is a vacume line the other is fuel remove from thank then slide tank back and you should be able to drain the gas out of the tank but if you huck up a fuel line to the pitcook and drain the fuel into a pail you wont have to remove the tank pull the spark plugs and put fuel in and trie to start it again you may have to do this a couple of time to prime the carbs
Jul 16, 2010 | Motorcycles
Stopped running after 20 min., repeatedly tried to restart. Have not been able to start it since
This could be caused by several things but most likely it is a cracked fuel line. The lines of these get brittle and break from vibration over time. First I would make sure I have spark by pulling the spark plug and put the plug boot back on the spark plug. Then with you foot holding the saw firmly in place, ground the spark plug on the metal portion of the engine block away from the spark plug hole. Pull the cord and see if the spark plug is firing across the tip. If so, I would look very closely for a broken fuel line.
I hope this helps you isolate the problem.
Jun 21, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan wood shark 1950 wont start spark plug has
Try to squirt a little gas in the carb and see if it pops or tries to run for a short time. The diaphram in the carb is probably old and hard. That would be the first place I would look.
Nov 07, 2009 | Garden
Pulled choke and power swith is on, keep trying to pull the cord and stll won't start,yes it has gas
hi , try this, take the spark plug out. and leave it out for awhile ,to dry out.1 hour,clean plug ,put it back in the machine.then take the air cleaner off, make sure it is clean for later,get acan of aerostart or starter fluid NOW SWITCH ON, CHOKE OFF THROTTLE IN START POSITION''''' FULL THROTTLE ,AQUICK SQUIRT OF AEROSTART INTO THE TOP F THE CARBY AND PULLTHE START ROPE 3 OR4 TIMES NO MORE ,THE ENGINE SHOULD FIRE OR START;;;; if it does not at least fire you may have to try anew spark plug,if it fires but does not start, pu ll the choke out 1/2 way and pull 1 or 2 times only or you may flood it again,giv it another squirt in the carby and try again but dont keep pulling the starter as you will get crankey when ite rope breaks .if it starts let it run for afew minutes stop it replace the air cleaner 1/2 choke pull the starter should go push choke rightin after a couple of pulls start it and go to work.Please if this doesn`t work come back and tell me what happened for we may have to make a couple of adjustments
Aug 12, 2009 | Makita DCS6401 20 20",64cc Chainsaw 2...
New ms230 stihl chainsaw won't start
Sounds like its flooded pull the plug and run pull it a few dozen times to dry it out. then try again
May 26, 2009 | Makita DCS6401 20 20",64cc Chainsaw 2...
Garden Logo
136 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
