Question about Samsung SyncMaster 2253BW LCD Monitor
L1916HW Westinghouse monitor - buttons stopped working
I was just working online as usual when I noticed a pop-up on my 2nd monitor (Westinghouse L1916HW) that said something like "auto adjusting". I wondered about it but it went away and I forgot about it until I went to turn off the monitor and the buttons didn't work. These are touch sensitive buttons on the right side, not actual push type buttons. I tried restarting my computer but that didn't work. I considered unplugging it to reset but I'm afraid I won't be able to turn it back on. Can anyone help? Thanks!
  • 4 more comments
  • kr2165 Jul 03, 2009
    Thank you but the on/off button currently doesn't work, along with the others. I'm a little afraid to unplug it then not be able to turn it back on. Is there anything I can do thru my computer or the ATI catalyst control center? It's on and working just fine other than the button issue. thanks!
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    unplug the monitor and leave the monitor unplugged for about a minute. Also unhook the monitor from the pc as well. Then turn it back on only, leave it unhooked from the pc and see if you can get the self-test screen to come on.
  • CodeNinja Apr 15, 2012
    This solution worked well for me! Unplugged monitor from power and pc for 1 min, plugged power back in, power button was now working. Turned off monitor using the power button, plugged pc connection back into monitor and turned monitor back on using the power button. All buttons now working!
The Machine
  • 788 Answers
SOURCE: Having problem with buttons they are not working
The monitor thinks the "AUTO" button is depressed continuously. If water or something got into the button membrane and shorted it out it could cause this to happen. You would have to open up the screen to try and clean the buttons but that's not a guaranty.
Posted on Jan 11, 2008
  • 383 Answers
SOURCE: Monitor flickering and adjustment buttons locked
If the refresh rate is not properly set the monitor may have a wavy or an appearance that lines are going down ... This may also cause a flickering affect.
Distorted or skewed image on monitor. Issue: Distorted or skewed image on monitor.
Cause: This issue can occur from any of the below possibilities.
  1. Windows issue.
  2. Loose or defective cable.
  3. Refresh rate issue
  4. Interference.
  5. Bad monitor.
Solution: Windows Issue If your monitor has a proper display until it gets into Windows 3.x, Windows 95, Windows 98, Windows NT, Windows 2000, Windows ME, or Windows XP please see document CH000121 for software or setting related issues.
Loose or defective cable You may receive a distorted image when the cable is loose or defective. Disconnect the video cable going from the back of the computer and verify that no pins are bent, burnt or broken. Once verified re-connect the monitor cable.
Refresh rate issue If the refresh rate is not properly set the monitor may have a wavy or an appearance that lines are going down or across the monitor slowly or fast. This may also cause a flickering affect. Additional information about how to change the refresh rate can be found on document CH000558.
Interference A distorted image can be caused by magnetic or other types of interference. Verify no speakers, fans or other magnetic devices are close to the monitor.
Bad Monitor If the above possibilities have been checked it is likely that the monitor is bad. To verify this it is recommended that the monitor be temporarily disconnected and then connected to another computer. This can be a friends computer, a work computer, and/or a computer at a service center. You can also help verify a defective monitor by connecting another monitor to your computer. Note: Connecting your possibly defective monitor to another computer will in no way harm the other computer.
Good Luck/Please dont for get to Rate.Thank You.
Posted on Jan 17, 2008
myob247
  • 1342 Answers
SOURCE: Samsung prob
Here's a link to a troubleshooting guide
Maybe you should try re-setting it to factory settings.
Posted on Apr 04, 2008
SOURCE: Auto Adjust not working
The monitor is bad.
It's all over the internet... It seems to be a lot (of production line) issue... I am in BRAZIL and I bought one that's behaving the exact same way.
Dozens of forums in Portuguese (our language here, ICYDN) relate the same problem... Also checked English and German... STAY AWAY FROM THE T220.
Posted on Jan 16, 2009
  • 136 Answers
SOURCE: Is there a Win98 driver for a Westinghouse L1916hw
Sorry, there is no driver for this monitor for Windows 98
Posted on Sep 25, 2009
No screen image
Test with known good monitor. Consult a nerd at this point. They can diagnose things quickly. Its usually more obvious then you think.
If still no image, replace video card. You can buy a replacement online. Most likely you have something else going on. For example, You usually hear beeps from a PC if it is doesn't pass post testing during startup. This could also cause no video output. You would need to check PC memory and power supply as those two can cause many performance problems.
Oct 10, 2013 | Westinghouse Electric L1916HW 19" Monitor
Hi!! I have a Westinghouse L1916HW 19" DVI LCD 2ms
One possibility is that it may have dying power supply which may be putting out unstable DC which can cause a lot of strange symptoms.
See pictures here: http://s807.photobucket.com/albums/yy352/budm/Westinghouse%20L1916HW/?action=view&current=DSC00244.jpg
Bad caps are real common problems in all brands of the monitors as you can see in my albums.
Westinghouse monitors are cheaply made to start with.
Mar 20, 2011 | Computers & Internet
Have the L1916HW monitor and it has started popping up the menu screen randomly, and as of today it has turned itself off twice.
today is our locky day!! I found the answer, please take a look on this web http://s807.photobucket.com/albums/yy352/budm/Westinghouse L1916HW/?action=view ****************************************************** http://www.aplusperfect.com/articles/lcd_capacitor_repair How-To Repair a Desktop LCD with Bad Capacitors January 17, 2008 By Jeremy Brock
Desktop LCD monitors fail for a variety of reasons, the most common being bad electrolytic capacitors. If you are willing to invest the time you can fix your LCD for a few dollars in parts. For this demonstration I'm using an IBM ThinkVision 6636-AB1 however the same techniques apply to most desktop LCD Monitors.
Disclaimer:
A+ Perfect Computers, LLC, is not responsible for any damages to your device, person, or property. Computer, Laptop, or LCD disassembly and part installation is at your own risk. This Guide offers only suggestions for taking apart your device. The components inside your device are highly sensitive. Always ground yourself by using an ESD wrist strap or by touching a metal object while handling sensitive electronics.
    Symptoms:
  • No Picture on Screen
  • LCD displays picture briefly then turns off
    Tools:
  • Soldering Iron
  • Desoldering Station or Solder ******
  • Phillips Head Screw Driver
  • Spudger (Available Here and Here)
Nov 25, 2010 | Westinghouse Electric L1916HW 19" Monitor
Hello i have a 19'' white westinghouse lcd computer monitor and it all white, is there anything i can do, i have already checked the green board and capacitators and what not and eveything tested fine, is...
chapp29, You didn't tell me the brand name of the electrolytic filter capacitors that are on your monitors "switch-mode-power-supply / cold-cathode-fluorescent-lamp-ballast" circuit board. How did you measure (check) the capacitors? Are any of the rubber seals pushed out of the bottom of any capacitors? What is the "date of manufacture" of this unit? Will L1916HW work connected to a different "known-good" pc? Will "known-good" monitor work ok when connected to your pc? 12fixlouie
Sep 15, 2010 | Westinghouse Electric L1916HW 19" Monitor
Color is very washed out, contrast very bad even after adjusting. Very hard to see lines. Basically the screen is all washed out!
You can try going into the display functions using the menu buttons and performing a factory reset. Good luck.
May 26, 2010 | Westinghouse Electric L1916HW 19" Monitor
I just rebuilt my system, and I don't have a CD to install the monitor
Usually the monitor manufacturer has a support section on their web site with driver downloads.
Dec 28, 2009 | Westinghouse Electric L1916HW 19" Monitor
The monitor turns on briefly humms and then turns off. Any ideas? Westinghouse L1916hw
Sounds like a bad inverter. Does the screen still show that the power is on? If so, then shine a bright light at it. If you can still see the image, then you have your answer.
-=/ Daft Tech /=-
Oct 23, 2009 | Westinghouse Electric L1916HW 19" Monitor
Westinghouse L1916HW Monitor On-Screen Display keys malfunction
Hi!! I have a Westinghouse L1916HW 19" DVI LCD 2ms Widescreen Monitor and it turns itself off . Sometimes it works without problem for long time or just for 15 mins, and after turn on it several times the problem disappears. Now,when it is working without the problem, sometimes the volume menu appear on the screen without touch the monitor and if you try to close it, appear again.. I am using it with Windows 7. I need help. Now, I have a router wireless close to it, Can it affect the monitor?
Dec 14, 2008 | Computers & Internet
Samsung SyncMaster 2253BW LCD Monitor Logo
661 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
