Question about LG 24 in. LDS 5811 Built-in Dishwasher
Soap dispensor doesn't open during cycle - LG 24 in. LDS 5811 Built-in Dishwasher
  • 93 Answers
Clean with a toothbrush and water, if stll wont open, replace dispenser
Posted on Jul 03, 2009
Why will the soap dispenser not open up ?
Does it open by itself during a cycle when there is no tablet inside? Have you changed to a different tablet recently? Some tabs are larger than intended for some machines and so put pressure on the lid and stopping the catch from sliding away and releassing the tab. Or it possible that the solenoid valve that operates the dispensor is faulty, Does the rinse aid still dispense?
Sep 20, 2014 | Maytag Dishwashers
Lsoap dispensor wont open during wash cicle
Hi! Most washing machines have some safety regulations that include opening the soap dispensor, this is why you should put the sufficient amount of soap before the process begins. There's nothing wrong or broken to your dishwasher, this is how these machines are made. I hope this will clear your problem. Have a nice day!
Sep 01, 2011 | Whirlpool Dishwashers
Hi . The soap dispensor does not open during it's cycle. What would cause that to happen?
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Nov 06, 2010 | Maytag 24 in. PDC3600A Built-in Dishwasher
Does the soap dispenser open automatically during the wash cycle, ours doesn't open and the dishes aren't getting clean.
does the cycle complete?. if it does and your dispensor is not open, then your dispensor is faulty. try opening it by hand, remove old powder, refill with 2 tablespoons of powder,select fast programme and see how you go. if your cycle is not completing then let us know what it is doing instead.
Apr 07, 2010 | Whirlpool Dishwashers
My soap dispensor won't open during the cycle
at times soap contaminates the electrical connections at the door latch connector and the timer pins.check the wiring Accumulated detergent and other material can interfere with the spring mechanism or halt the pivot action of the door. Use very hot water and a micro-sized brush. You also can use a mix of hot water and vinegar.Most dispensers have a bimetallic strip or switch, attached by screws, which triggers the door release. With the front door panel removed, locate the switch, and push on it gently with a screwdriver until the dispenser door opens. You might simply need to adjust the alignment of the switch.
you will need to open the assembly if you are skilled.if the problem persists after this then Most likely the soap dispenser assembly has to be replaced..hope this helps
Jan 13, 2010 | Thermador DWU244 Dishwasher
Do you have to use the automatic detergent dispenser on the maytag atlantis? Or can I just add detergent to the tub myself when starting a load?
Formerly Maytag Service:
It is actually better for your machine to add the soap directly to the tub, during your fill cycle, than it is to use the dispensor.
Just ensure that your soap or detergentg is color safe, so that direct contact will not damgae your cloths.
Thats the only reason the dispensor was ever made,
so that the soap could be dilutted before contact with fabric
hope this helps
Oct 18, 2009 | Washing Machines
Soap packets don't melt/disolve
sounds as if you amy have a problem with the dispensor door not opening correctly perhaps opening at end of cycle when all water is already released.Ive seen that sometimes the "tabs" or "packets of detegent are too tall and interfere with normal opening of the latch mechanism. manufacture would reccommend using powder instead.
Nov 04, 2008 | Dishwashers
Bosch Slimline dishwasher Exxcel. Detergent dispenser does not open during the wash
take door outer panel off and dispenser is exposed. start cycle and with a multimeter, check power comes to the dispensor during the cycle. if you get power, then the dispensor is faulty. if no power, then the module is faulty
Aug 05, 2008 | Dishwashers
Soap Dispensor does NOT open.
This is almost always a dispenser problem. The dispenser is replaced as a unit. you can reach it by removing the Phillips screws around the inside of the door and lifting up the inner door panel. The dispenser's frame is held in place with tiny (1/8 in or 5.5mm) screws.
Mar 11, 2008 | Dishwashers
Soap dispenser door doesn't open during cycle of my Maytag dishwasher
Kqon, looks like your dispenser has a wax motor. I think the first thing you have to do is remove the inner door and inspect the soap dispensor assy. See if any of the moving parts are broken. This wax motor is 120V so you can run a cheater cord to it to see if it works, but be very careful when doing this. It will expand the plunger and open the flap. If the wax motor operates with 120V applied to it then you want to see if you have power coming from the timer. It will be the tan wire # 27 on the timer harness. You also want to make sure the spring and pin are in place on the dispenser flap. Your part number for the wax motor is 902899. Catriver.
Jan 16, 2008 | Maytag 24 in. PDC3600A Built-in Dishwasher
LG 24 in. LDS 5811 Built-in Dishwasher Logo
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
