Question about Mantis 2-Cycle Tiller
Mantis tiller won't run at high rpm
When you start to till it goes blah and won't go up to speed.
    Scholar:
  • 115 Answers
Check the carburator, it sounds like a main jet is clogged or the carburator is dirty. Is the air filter clogged? Is the motor under strain?
Posted on Jul 04, 2009
Chainsaw problems
You are running it too lean and running too hard. doubt if it will last anytime at all before the piston freezes up. Dont forget to mix oil with the gas at the proper mixture, take to the saw shop and have them adjust it as I see you don't have it adjusted properly. The high and low jets need adjusting. Turn the high speed jet counterclockwise until it starts to cackle when it is running at top speed. Then when idling give it full throttle for an instant. Does it instantly have power or does it go blah. If it goes blah and does not engage quickly with power then turn the low speed jet on the carburetor to the left as you keep trying this. Only turn it a fraction at a time like say 1/8 of a turn at a time then try it again. Once you have full power when you engage the throttle, I mean it has to be instant then turn the low speed 1/8 turn more. Recheck the high speed jet by giving throttle for full speed. Do not let it scream, you must adjust the high speed jet til it starts to cackle. That way it stays in control and will not scream unless you are in wood cutting under a load. By the way the low speed jet should also be adjusted to give you more power when you are cutting as you first hit the throttle and not bog down. Do not get confused with the chain stopping and hung up so it wont turn, I am talking about the engine and it powering the chain when it is free to move in the wood when cutting. Anyhow don't run your saw to the point of a red muffler. If you want to use your saw again. It's not good!
Dec 23, 2013 | Garden
My Renault trafic 1.9 has no power starts fine but won't rev. It eventually starts to rev and goes to about 1500 but that's about it. I've cleaned the egr valve and cleaned out the air filter and I'm now...
check the maf sensor and the boost pressure sensor also check the boost pipe fitting where it goes into the inlet manifold they block up and also the fitting on the vac pump blocks up resulting in no vac to the turbo control solinoid also turbos are rubish on these seize or shear turbo shafts ect blah blah blah i could go on
Aug 06, 2012 | Cars & Trucks
Kenmore Elite HE4t Washer won't start
Hello Ameliafaith,
E-Z job...
If you take your model on line... to SEARS
(I don't ordinarily recommend)... BECAUSE THEY COULD ACTUALLY ... decode your ABREVIATED part number...
110. blah blah blah... (45986??)
The other sites actually have helpful VIDEOS...
But I already wasted enough time on this floundering with your
erroneous number (wrong no.)...
You will see these parts are reasonably priced and
very popular.. meaning they INDEED FAIL ... alot.
Go here:
Washer Door Lock Assembly Part Number 8181700 Sears PartsDirect
Carnac the Magnificent
Jun 07, 2017 | Kenmore Elite 45986 Front Load Washer
Acer Aspire 7540 won't connect to wireless or ethernet
Ensure the Acer software is installed along with the system and boards drivers.
Jan 10, 2018 | Acer Computers & Internet
Kodak easyshare m583
I have never seen a camera where the display actually contains the words 'blah blah blah' . Are you sure that you have read them correctly ?
Oct 07, 2017 | Kodak EasyShare M530 Digital Camera
Can u plzz tell me the details about this number 9866740989.. we dont no the person who is calling from this number, we just wanted to know the details about him
https://www.donotcall.gov/ register that number with this site,, its a telemarketer and they won't stop until you add that number to the link I sent to you,, if you try and call it back, its going to say ,, unused number because they block incoming calls, its used for outgoing only and usually say some garbage about you've won blah blah blah,, Its a scam, if your phone service has the ability to block numbers do that , you can check this link for other numbers that may call you also
http://800notes.com/AreaCode.aspx/1-986
Aug 18, 2011 | Home
Laptop shuts itself off when trying to connect to the internet
if you have a dialogue box appearing with a countdown timer appearing saying windowshas encountered a problem and will shut down in blah blah seconds then you have a virus on your pc
to disable the shutdown (only if the above applies)
click start > control panel > administrator tools > services
when the services manager window opens scroll down the right window till you locate Remote Procedure Call (RPC) Locator
double click on it
click on recovery and change all three cdrop menus to take no action
then restart the pc
once restarted update your anti virus and do a complete scan of your pc
Feb 25, 2011 | Dell Precision M65 Notebook
My air compressor won't restart
minimum pressure check valve is bad , does the compressor when it shuts off bleed air out at the pressure switch , if so does it continue till it starts back up , if so the unit is trying to start under a load. You have a bad minimum pressure valve usually located where the air line goes into the tank.
Jul 27, 2009 | Air Tools & Compressors
Wont start"Windows error recovery"
Hi again,
Sorry but I cannot help you because I am not an expert of Windows Vista, I could help you with Win Xp but not with that.
I hope someone else is reading your post and will help you.
Sep 23, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Mantis 2-Cycle Tiller Logo
477 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
