Question about GE Refrigerators
How to replace controller board on g.e. profile side by side. PSS26
    Scholar:
  • 95 Answers
Hi there
as you want to replace the controoler board of your controller board,i wd suggest you that you wont be able to take out the board yourself you dont have any prior experience in this field.
the option you should take is to call the customer care and tell then that u want to replace the board.
they will do it for free if its under warranty.
and if not they will charge for it..
but it is always better as they always use genniune parts.
for long term this decision sould be good to take.
thnx
Posted on Jul 03, 2009
How to remove freezer door from ge profile pss26?
Probably has tub seal leak and got into clutch and rusted clutch if thats the case will need rebuilt
Jul 20, 2014 | GE Profile PSS26NGS Side by Side...
I have a GE profile Fridg PSS26NSTASS where is the defrost timer located
The PSS26NSTASS does not have a defrost timer. The defrost on that model is controlled by the motherboard=> WR55X10942 Board Assembly Main Control On your model if not defrosting it will most likely be caused by the=> WR51X10055 Defrost Heater It also does not hurt to replace the=> WR50X10068 Defrost Thermostat
while inside freezer changing out the defrost heater. Click here=> PSS26NSTASS Freezer Components
In that photo location 230 is your defrost heater and location 240 is your defrost thermostat. Here is a=> PSS26 Service Manual if you don't already have Adobe Acrobat Reader Click HERE I will be here should you have any questions, Thanks Sea Breeze
Feb 16, 2012 | GE Refrigerators
Thru the door water dispenser won't dispense water, but ice maker is working and making ice
That should be a simple fix providing you disconnect power and turn off the water supply. Your model being a PSS26 or what ever size GE still uses the basic partsin that full line or series. The part number for your dual water control valve is WR57X10040
Here is a link to the service manual for all that fall in your models series and styles=> http://appliancepartsseabreeze.com/appliancepartsseabreeze/manuals/Pss26MsRSS.pdf
Here is a link to my web site=>
sea_breeze_11.jpg Here is the location=> Page 17 in PDF
Here are some close up drawings of the wiring with test points Here=>
GE ARTICA PROFILE TECHNICAL INFORMATION
I will be here if you need help, Thanks, Sea Breeze
Dec 06, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
TEMPERATURE CONTROL DOES NOT LIGHT UP
You have a bad main control board ( pt # WR55X10942 ) . Your temp control has lost communication to the main board . This board is behind the refrig , behind the 8X10 panel , and is easily replaceable . All 6 or 7 plugs , fit into their respective places , so you should have no problem . It also comes with instructions .
Aug 15, 2010 | GE Profile PSI23NCR Side by Side...
I have a GE profile side by side refrigerator and it won't stay cold. What is the approx. cost to replace the compressor so it will get cold again?
First be sure it is actually the compressor at fault. We repair a lot of control boards for these fridges that cause the problem you describe. The cost to repair the control board is $80.
Best Regards,
Bruce
www.fixyourboard.com
Jun 21, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
No temperature display on my GE Profile PFS22SIS
I think is just the display board next to the cold control.
Oct 01, 2009 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
Freezer at 21 degrees , refer at 44 degrees, will not get any colder.
If your model number is the Profile/Artica PSS26 model the most likely reason for this is a burned out defrost heater. Look into back of the freezer and tell me if a layer of frost is building up on the rear wall of the freezer compartment. If yes then unplug and remove the rear panel in the back of the freezer to expose the evaporator coil. If frosted over then you need to defrost with a hair dryer or leave a bucket of hot water in the freezer compartment until the ice melts away. Sometimes the defrost drain is frozen over and then the beginning of the frost becomes heavy quickly and temperatures begin to increase in both sides of your side by side. Lately I seem to be here and ge no response from anyone. I want you to a the least let me know if you need my help to resolve this. Sometimes the main control board causes this but not as likely as the defrost thermostat and defrost heater. Sea Breeze
Sep 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a PSS26 ge profile fridge and it quit making ice
The icemaker is bad . You have an electronic icemaker and the internal boards cannot take the freezing and the heat (freezing moisture) . Just replace the icemaker .
Jul 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The ice will not dispense from GE profile sid by
The problem could be as simple as the door switch for the lights because the door switch when closed turns the control panel on. Or the problem may be the control board. WR55X129 Control Board Thanks, Sea Breeze
Jul 23, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE PSS26 NGP Ice maker
Hi Vadim, You should have a steady light showing on the ice maker. If the lead is flashing, it's either a thermistor failure or ejector not home. The reasons why the ejector blades will not home is because of a magnet failure, control board failure or a stalled motor. The feeler arm could also be sticking. The control board contains 2 sensors that are activated by magnets. One magnet is attached to the end of the ejector arm to determine whether the ejector blades are at home. The other is located on the ice sensing arm, lets the control know whether the arm has reached a fully extended position. In a lot of these, I find the magnets broken. I think you can save yourself a lot of trouble by just replacing this ice-maker. Catriver.
Dec 28, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
