Question about Canon PIXMA iP1800 InkJet Photo Printer
Service error 5100
We have a cannon pixma iP1800 inkjet printer. Anytime we try to print it comes up with "service error 5100" and tells us to refer to the instruction manual. we no longer have the instruction manual. i've tried doing a maintenance check but it won't even print that.
  • 2,404 Answers
Try this to get rid of the error:
Service error 5100 is a carriage home position error.
Turn off and unplug the printer from the power supply.
Remove any paper.
Buy a can of compressed air from an electronics shop or computer store. Use the compressed air (Not a vacuum!!!) to blast out any dust bunnies, paper particles and debris. (Don't do this with the cartridges removed as you're likely to fill the printhead with air!!)
Use isopropyl alcohol and a cotton swab (Qtip) to clean the plastic strip that runs the length of the guide rail (the metal rail that the cartridge carriage moves along), it may be contaminated with ink and debris.
Remove and reinsert the ink cartridges inside the cartridge carriage to ensure that they're connecting properly.
With the power off, carefully slide the print head (carriage) to the center of the guide rail. You should not have to force it! (There will be some light resistance but it should move quite easily by gently pushing on it with your finger.)
Close all the access doors, plug it back in, connect your USB cable and turn on the power.
As it runs through the initialization, the printer should sense that the carriage is out of position and automatically move it back to where it should be.
Good Luck.
Posted on Jul 03, 2009
My printer Canon PIXMA iP1800.with error 5100
Error 5100 is Cartridge Position Error. Try cleaning the whole strip where the cartridge is placed.
Jun 30, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Service error 5100
Hi You can Try 2 things.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 22, 2010 | Canon Pixma iP4500 InkJet Printer
Error 5100
Hi You can Try
Error Code 5100
Solution 1:
Solution 2:
Jan 26, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Printer wont print and comes up with service error 5100
Error 5100 is Carriage error.Possible problems in:
- Carriage unit
- Timing **** strip film
- Logic board assembly
- Carriage motor
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Nov 16, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
My Pixma ip1980 service error 5100
5100 is a Carriage Home Position Error.
try cleaning the plastic strip that runs the length of the carriage, it may be contaminated.
Use alcohol and a swab.
Aug 12, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
CANON IP 1300 SERVICE ERROR 5100
ERROR 5100 means that there is some foreign object blocking your ink cartridge carriage that disables it from moving. It may be a piece of paper or a scotch tape or a staple wire. You may try cleaning also the encoder strip with a moist tissue paper. Furthermore, you may also try cleaning CAREFULLY the contact points of the cartridge holder and the cartridge itself (those shiny bronze pins) with a moist lint-free cloth.
Jul 27, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Error 5100
Error 5100 mean carriage error. Possible problems in:
- Carriage unit
- Carriage motor
Jul 09, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Printer error message
we still cant get it to print!!!!!!~ what is the matter!!!!!
Feb 25, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon PIXMA  iP1800 InkJet Photo Printer Logo
191 people viewed this question
old marine
old marine
