Can't connect to the itnernet.
I have a problem with my computer or network adapter, Undecided as to which yet, not wanting to connect to the internet. I've tried the obvious stuff. resetting the router/modem, restarting the PC, I've actually reformatted because of this. Yet still when I go to the ''ipconfig all'' there is no Default Gateway. Compaq Presario SR5450F any help would be greatly appreciated.
  • Jamie Stanley
    Jamie Stanley Jul 04, 2009
    Auto obtain IP is on but i don't know how to auto obtain DNS. Also I've gone through the Start Menu, Run, CMD and put in Netsh int ip reset but it says requested command needs elevation or elevated or somethin....wth does that mean and how can I get around it?????
  • 28 Answers
Make sure all your drivers uare upto date!!!
If so you can attempt setting auto obtain IP and DNS. If that works you are good to go. If not then you need to ring your ISP and make sure that u have no fees or if the network is down.
Posted on Jul 03, 2009
How to connect my wii to my dell xps400
Desktop computers are not known for their wireless connectivity, but it is possible to make yours one that is.
Wireless network adapters, which enable your desktop to pick up wireless Internet signals, come in a variety of forms, and are all fairly easy to install.
Once you have one installed, getting online wirelessly is almost effortless.
Choose the network adapter that is right for you.
The easiest network adapters to connect do so via USB, but if you have limited USB ports on your desktop, you may want to try another option.
There are also network adapters that plug into your Ethernet port, but if you want to use that port for a landline connection you have, and wireless is your backup, then this also may not work for you.
If that is the case, you can buy an add-in card, which fortunately for Dell owners is very easy to install.
Dell computers are designed to be opened and have add-in cards installed without the use of screwdrivers; check your manual for details.
Install the network adapter and any included software.
The adapter will usually come with a software CD with a notice to run the CD either before or after you have plugged in or installed your adapter.
Go through the setup steps on the CD, click "Finish" when it is complete, and your wireless network adapter should then be activated and ready to receive wireless signals.
Click the notification that pops up letting you know that wireless networks are available; or, if there is no notification, go "Start > Connect To" and all available networks will be displayed.
Double-click on the logo for the network you want to connect to and enter the security key if it is a secure network.
(If you set the network up, you should have the security key saved somewhere with your network settings.
If you are connecting to a nearby hotspot, you will need to ask the permission of whoever set up the connection and obtain the security key from that person.)
Select "Home," "Work" or "Public Location" when prompted to designate what type of network connection this is.
You will then be asked if you want your computer to remember this computer and start it automatically in the future.
If you plan to use this connection regularly, it is a good choice to check the boxes next to both options so that the connection will always be available and you won't have to enter a security key for it again.
Hope this helps.
Nov 25, 2012 | Dell XPS 400 PC Desktop
Hi i am using the pc sony vaio i have the problem on wireless adabter it was in desable mode and difficutl to active it ,while i am useing the bottom in front of pc on and off of wirless adabtor but i i on...
In Vista, you can either go to control panel, device manager and right click on it and click "eneble"
or go to control panel > network sharing and set up wireless network connection
or
go to task manager (press and hold ctrl . alt . delete for a couple of seconds), until task manager comes up. Then click on the services tab, scroll down till you see "Plug Play or Plug and Play and make sure it's running. If it's not, right click on it then click "enable"
In XP
Open Network Connections
Right-click Wireless Network Connection, and then click Properties.
On the Wireless Networks tab, do one of the following: •
To enable automatic wireless network configuration, select the Use Windows to configure my wireless network settings check box. This check box is selected by default. For information about what happens when you enable automatic wireless network configuration, see Notes.
To disable automatic wireless network configuration, clear the Use Windows to configure my wireless network settings check box.
To connect to an existing wireless network, do one of the following:
Access point (infrastructure)
To connect to an existing access point (infrastructure) network, under Available networks, click the network name, and then click Configure.
In Wireless Network Properties, specify the wireless network key (Wired Equivalent Privacy) settings, or, if the network key is automatically provided for you (for example, the key is stored on the wireless network adapter given to you by your administrator), select the The key is provided for me automatically check box. If you are unsure about whether a network key is needed or which settings you need to enter, contact your network administrator or the wireless network adapter manufacturer.
Important
If a network does not broadcast its network name, it will not appear under Available networks. To connect to an access point (infrastructure) network that you know is available but that does not appear under Available networks, under Preferred networks, click Add. In Wireless Network Properties, specify the network name (Service Set Identifier) and, if needed, the wireless network key settings.
Computer-to-computer (ad hoc)
To connect to an existing computer-to-computer (ad hoc) network, under Available networks, click the network name, and then click Configure.
If you want to connect to a computer-to-computer (ad hoc) network and both computer-to-computer and access point (infrastructure) networks are within range of your computer, click Advanced, and then click Computer-to-computer (ad hoc) networks only.
To configure a new wireless network connection, click Add, and then do the following: •
If the network connection that you are configuring is to a computer-to-computer (ad hoc) network, select the This is a computer-to-computer (ad hoc) network; wireless access points are not used check box.
To change the order in which connection attempts to preferred networks are made, under Preferred networks, click the wireless network that you want to move to a new position on the list, and then click Move up or Move down.
To change the wireless network connection settings for a network that is listed in Preferred networks, click the wireless network for which you want to change settings, click Properties, and then change the settings as needed.
To remove a wireless network from the list of preferred networks, under Preferred networks, click the wireless network that you want to remove, and then click Remove.
To update the list of available networks that are within range of your computer, click Refresh.
To automatically connect to available networks that do not appear in the Preferred networks list, click Advanced, and then select the Automatically connect to non-preferred networks check box.
To open Network Connections, click Start, click Control Panel, click Network and Internet Connections, and then click Network Connections.
When you enable automatic wireless network configuration, you can connect to an existing wireless network, change wireless network connection settings, configure a new wireless network connection, and specify preferred wireless networks. You will be notified when new wireless networks are available. After you select a wireless network, your wireless network adapter will be automatically configured to match the settings of that network, and a network connection attempt will be made.
To configure settings on the Wireless Networks tab, you must be logged on as an administrator, and you must use a wireless network adapter that supports the Wireless Zero Configuration service. If you are unsure whether your wireless network adapter supports the Wireless Zero Configuration service, contact your network administrator or the wireless network adapter manufacturer. For more information about automatic wireless network configuration, see Related Topics.
If you are using third-party wireless networking software, clear the Use Windows to configure my wireless network settings check box.
If you are unable to connect to an existing wireless network and the name of the network that you want to connect to appears under the Preferred networks list, click the preferred network name, and then click Properties. In Wireless Network Properties, review the settings to ensure that they are correct. If you are unsure whether the settings are correct, contact your network administrator or the wireless network adapter manufacturer.
If the Preferred networks list includes both access point (infrastructure) and computer-to-computer (ad hoc) networks, you cannot move a computer-to-computer network to a position in the list that is higher than the position of an access point network.
To provide enhanced security for 802.11 wireless networks and for wired Ethernet networks, IEEE 802.1x authentication is enabled by default. For more information about how to set up 802.1x authentication.
Hope this helps
Dec 12, 2010 | HP Broadcom NetXtreme Network Adapter
My hp mini 110 will not wirelessly connect to the itnernet. it is the same network that my old laptop connected too,but it says it is unable to conncect. now it shows that there is not network available....
Did you see a switch on the side of the HP machine or a key on the keyboard with a wireless symbol? Turn on that switch or press the key to get wireless adapter started. Then try again to search for wireless networks. Please post if the issue persists and I will help on that.
Nov 26, 2010 | HP Mini 1000 Netbook
How to install an wirless adapter to mi desktop
Install a wireless network adapterIn areas that are served by a wireless network, you can connect to a computer network without using a cable, and surf the Internet or connect with other computers. To connect to a wireless network, your computer needs a wireless network adapter.
Many new computers-especially laptops-come with wireless adapters. Before using your computer, check to see if it already has a wireless network adapter.
If your computer doesn't have a wireless network adapter, you can install one.
Install a wireless USB network adapter. Most people prefer this type of adapter for any type of computer, because it's easy to install.
Install a wireless CardBus or CF network adapter. For portable computers, this type of adapter (also called a PCMCIA or PC Card) is easier to travel with than a USB adapter, because it is often smaller and fits securely in the PC Card slot on the side of the computer.
Install a wireless internal network adapter. If you have a desktop computer, you may prefer an internal adapter so that you can use the USB port to connect another accessory.
The type of adapter you install depends on your computer and your level of expertise.
How to determine if you already have a wireless network adapterMany portable computers manufactured after 2000 have wireless networking built in. However, because the antenna is hidden inside the computer, it's not easy to see.
To see which network adapters are currently installed in your computer
1.
Click Start, and then click Control Panel.
69010-click-control-panel.gif 2.
Click Network and Internet Connections.
69010-click-network-and-internet-connections.gif 3.
Under or pick a Control Panel icon, click Network Connections.
69010-click-network-connections.gif 4.
Microsoft Windows XP displays your network adapters. Wireless network adapters are labeled Wireless Network Connection. If an adapter displays a red X, it is disconnected. If the Network Connections window is blank, your computer doesn't yet have a wired or wireless network adapter.
Nov 12, 2010 | Computers & Internet
Resetting the adapter
Use the computer you are on to download the updated driver for the network adapter from the Toshiba Website. After you have the updated driver install it on the computer your having a problem on. Reboot the computer. If the problem is still there and you have a cable connected to the network connection and to the router, uninstall the network adapter from the device manager and reboot the computer. That should detect and install the adapter and resolve the problem. If it doesn't there is a problem with the network adapter and you will need to use the wireless of get a PCMCIA card to use for networking. Toshiba does use a replaceable Network card in some laptops, if nothing else above works and you don't want to get another card to plug in you may want to look into purchasing a new card from Toshiba to replace the old one.
Jul 22, 2010 | Toshiba Satellite A100-S8111TD Notebook
Wants a network key # to activate
Sounds like windows has thrown a wobbly regarding your wireless network connection. Go into network connections and double click on wireless network adapter. Click on wireless network tab at top of box then highlight your wireless network and click on remove. Restart your computer then let windows find the network again. Click on connect then input your wireless key again. This should refresh the connection completely. If you need more help let me know
Jun 09, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Using multiple networks
if you are using windows 2000 or later start the routing and remote access service (make sure to set it to automatic) and that should solve your problem.
Jan 13, 2009 | Intel REALTEK nc-r150201 Network Adapter
No connection to the network
Toshiba Tercra 8200 have a buildin network connection, and a buildin wirless. You don't need additional hardware, just connect the cable from the modem to the 8 pin port in the rear for wired, and if you want ot use the wireless then please post your queation back on the thread.
thanks you
Jan 05, 2009 | Computers & Internet
Wifi issue
Hi!
Check with your laptop's manual or specification sheet if it came with a built in wireless adapter. If it does, then you do not need to use a wireless adapter. All you have to do is to configure the wireless utility of your laptop to connect to your preferred wireless network.
You can also check Device Manager to check if there is a built in wireless adapter. Assuming you are using Windows XP - Go to Control Panel > System > Hardware > Device Manager. Look for Network Adapters. Check if there is anything under Network Adapters that says "wireless" or 802.11A/B or G. If there is, then again you do not need to install a wireless adapter.
Once you verified that there is a built in wireless adapter, just configure the wireless adapter utility to connect wirelessly to you preferred network.
Good luck and have a nice day!
Sep 30, 2008 | Compaq Presario 700 470024-192 Notebook
Problem connecting to the internet using wireless usb adapter
Run this programme, then if necassary clear temp files in tools in your explorer. Start> Run then type ipconfig /flushdns then press enter.(note the gap between ipconfig and the /).
Mar 05, 2007 | GigaFast Ethernet WF748-UI (WF748UI)...
Computers & Internet Logo
David Payne
David Payne
