Question about Vcomm Recovery Commander (804526023624)
Need to uninstall recovery commander ..don't know how
I have tried to uninstall the system suite 8 but it's no where to be found so I can't. I want to get rid of that annoying recovery commander. Every thing I try to do it pops up and I can't x it out or stop it...so I have to sit and wait till it finishes its thing before I can go on with what I'm doing. I really want it gone.......can you help ?
Open System Suite 8, on the left you will see the task menu, open recovery, in recovery open the create a check point task, uncheck all the boxes with a checked next to it, that should disable the recovery commander part of Systems Suite 8.
Posted on Sep 22, 2010
    New Friend:
  • 26 Answers
To do this you must download revo uninstaller
and then uninstall it from . this s/w shows all files i.e also hidden setups and stop annoying start up programs
Posted on Jul 09, 2009
My acer aspire 7551-7422 says operating system not found
Try running the check disk utility to see if maybe it can recover it.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
Jun 03, 2012 | Computers & Internet
Im trying to uninstall lg pc suit but everytime i try it says its still running, but i dont know how to stop it to remove it
The simplest way around this problem is to enter Safe Mode and uninstall it.
1. Restart PC
2. Press F8 until Windows Boot Menu appears.
3. Select Safe Mode
4. After Safe Mode finishes loading, press Win+R to open the Run command.
5. Type APPWIZ.CPL into the dialog box and press enter.
6. Allow Add and Remove Programs to fully load.
7. Scroll down to the LG PC Suite, select it, and then click Uninstall/Change.
8. Uninstall the program.
9. Restart computer.
If you don't want to go to the hassle of entering Safe Mode, then another option would be to open Task Manager and end any process affiliated with the LG PC Suite. Then you should be able to uninstall the program.
Good luck and thanks for using FixYa.
Mar 09, 2011 | Computers & Internet
I want to know on how to uninstall IE8 on my computer i am running a windows XP service pack 3. I just want to install a fresh copy of IE8 . . . . .
Hi josephc_agni,
You cannot uninstall Internet Explorer 8 if it is set as not removable. This occurs if you install Internet Explorer 8 before you install Service Pack 3 (SP3) for Windows XP. If this scenario applies to you, then you must uninstall SP3 before you can uninstall Internet Explorer 8.
To uninstall Internet Explorer 8, follow these steps:
  1. Close all programs.
  2. Click Start, and then click Control Panel.
  3. Click Add or Remove Programs.
  4. In the list of currently installed programs, click Windows Internet Explorer 8, and then click Remove.
    NOTE: If Windows Internet Explorer 8 does not appear in the list of installed updates, try the alternative step given below.
  5. Follow the instructions to uninstall Internet Explorer 8.
  6. When the uninstall program is finished, restart your computer.
ALTERNATIVE STEP:
  1. Carefully select and then copy the following command: %windir%\ie8\spuninst\spuninst.exe
  2. Click Start, and then click Run.
  3. In the Open box, type Cmd.exe, and then press ENTER.
  4. Right-click inside the Cmd.exe window, and then click Paste to paste the command that you copied in step 1.
  5. Press ENTER to uninstall Internet Explorer 8.
Dec 05, 2010 | Microsoft Internet Explorer 8
Every time I attempt to load a new program-Recovery commander starts and I can not load a new program. Deleted program-problem still exists
Try setting your computer back to when it was working correctly. To do this do the following:
Go to start
All Programs
Accessories
System Tools
System Restore
Click Next
Follow the prompts and choose a date from the list when you know your computer was working correctly
This should work for you, let me know if you need further assistance
Please leave rating/feedback if you found this helpful, thanks!
Lori
Oct 17, 2010 | Vcomm Recovery Commander (804526023624)
Recovery Commander (804526023624): recovery commander pops up whenever i try to do an...
For you to Stop it you need to stop the services running for it. Follow the steps below.
Click on Start and then Click on run. Type msconfig. In the System Configuration utility screen click on services tab (Its on the Top). Once you are on that screen check the option Hide all Microsoft services. Then look for Recovery Commander. Uncheck that. Uncheck the Hide all Microsoft applications again. Click on apply. Then click on OK. Reboot the computer. You will System Configuration utility screen. Check the Option Don't show this message again and then click on OK.
Note: DO NOT uncheck any Microsoft Services.
If you want to delete it or remove it from the computer then install Revo Uninstaller (Freeware).
May 17, 2010 | Vcomm Recovery Commander (804526023624)
When I try uninstalling system suite 8 it tells me that network resources is unavailable and ask for an alternate path to the installation package. How can I remove it?
Restart you computer and when it's going to switch on press F8 several times until safemode displays. Click safemode then just follow path by ticking OK or yes. Go to user account that you always log on. Mouse over start menu and click control panel. Open Add/Remove program and uninstall from there suite 8. Then restart.
Jun 22, 2009 | Avanquest System Suite 8: Windows
Sp3 toshiba satellite l20 182
I would start by popping in the XP disk and getting in to recovery console (R at the first screen). Once there, run these commands:
fixboot c:
fixmbr
exit
This will rewrite the boot sector and master boot record on your drive. The "operating system not found" typically only happens when the boot sector is messed up. If that works and Windows loads, click Start -> Run and type
eventvwr
Click System on the left pane and, on the right side, click Source. Go to the "D" section and see if you have disk errors. It's a good bet that if your boot sector gets compromised, you're hard drive is about to crash and disk errors are being logged.
Jan 23, 2009 | Toshiba Satellite L20-S310TD Notebook
I'm tryingto uninstall System Suite 8
on the unistaller screen select the program
try to unistall it them remove the entry
them go to your (hard drive)=(C:\) and open the folder name (program files) select the folder containing the program you try to uninstall and delete the folder containing that particular program
Note: be carefull not to delete the folder name (program files) make sure the folder your deleting is the one containing (the system suite 8)
Jan 11, 2009 | Avanquest System Suite 8: Windows
Space Issues with Avanquest System Suite 9
I'm guessing that before you installed this software you had a lot of space on your hardrive. Have you opted to perform a \recovery backup' or 'system restore', or something like that during the install? If so this may explain why it is taking up all this room.
What this would do is make a copy of everything on you computer into a backup file, effectively greatly reducing your available space.
Dec 11, 2008 | Avanquest System Suite 8: Windows
Vcomm Recovery Commander (804526023624) Logo
983 people viewed this question
Top Vcomm Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Vcomm Computer and Internet Expert? Answer questions, earn points and help others
