Question about Vehicle Parts & Accessories
Remote control not working on Cobra burglar alarm.
I have a Cobra Globe 3900 model burglar alarm fitted to an Autotrail Cheyenne 840 motorhome. It's worked perfectly for three years. The other day, I opened the doors with the remote fob, loaded up for the holiday - but the remote control refused to lock the doors later. I assumed it was the age of the battery so changed it for a new one. However, the problem still persists, although I can still lock the doors with the ignition key. I've looked at the contacts on the doors and lockers - they all seem okay. Any ideas how to get the remote control working again please? Thanks!
Steve Wilcock
  • 137 Answers
SOURCE: Automatic door locks will not work.
you need to take it to the dealer and have them check the bcm for codes.... also have them check to be sure you have the latest software in the bcm.. its possible that you just need a software update... there are several TSB's covering the concern you have..... it can be a very simple fix with software or even a stuck lock switch may need to be replaced... without the proper diagnostic codes being read from the bcm all that can be done is guessing..and that can be expensive...
Posted on Feb 02, 2009
SOURCE: Lost key and alarm remote
first of all always take car of keys and locks of any of your belongings.. as it is very important..
i think you just go through the following link u ll get the answer
<a href="http://www.soundandalarm.com/car-alarms.asp">car alarm installation</a>
Posted on Feb 24, 2009
  • 105 Answers
SOURCE: REMOTE DOOR LOCK 1997 ES 300 LEXUS
Even if the remote is fairly new they can lose their programming you may have to have it re-programed
Posted on Mar 17, 2009
SOURCE: 2006 Mazda 5 keyless remote fob
I am a technition for mazda, and if the lights are coming on to the keyfobs, the batteries are fine. What procedure did you follow?
1. Take key out of ignition
2. Shut all doors
3. Open drivers door
4. Insert key to ignition
5. Cycle between On & Lock 3 times, leaving key in Lock
6. Close and open the drivers door 3 times, leaving the door open
7. The Locks should cycle.
8. Press the Panic button on the remote twice.
Posted on Apr 29, 2009
raygin
  • 322 Answers
SOURCE: Jag S-Type -intermitent fault where the remote fob does not work
This does not sound like a fob fault - but a locking control module fault , either in the hardware or software of the unit. Get it checked at a Jaguar dealers. When unlocking using the key - as soon as the door is opened you should hear a chime sounding inside the car - this is a timer counting down to sounding the alarm. If you put your key in the ignition as soon as you open the door the alarm should not go off and the chime should stop. If it does not this again points to a fault in the locking controller.
hope this helps - good luck.
Posted on Jul 08, 2009
When i try to start me 2008 sonata the alarm goes off and the engine will not turn over. what can i do?
Your Sonata is equipped with a "Keyless Entry & Burglar Alarm" system. When the Burglar Alarm is activated, it KILLS the starting system through the used of a relay called the "Burglar Alarm Relay". This mode prevents engine starting with the key.
Solution #1
Disarm the system with the Keyless Remote (key fob) If you don't have this remote (or its battery is dead) replace the battery & try disarming again.
Solution #2
Enter the vehicle & insert the key in the ignition and turn the ignition switch to 'RUN'. Wait 3 to 5 minutes until the alarm stops. You should then be able to start the engine.
Have a qualified/certified Hyundai Service Technician properly diagnose this issue.
Sep 07, 2011 | Hyundai Motor 2004 Sonata
My 2002 Santa Fe is locked and the remote will not unlock. the remote has a new battery. How can I start the car.
First of all, has the burglar alarm been activated? If so, you can enter the vehicle with the key, put the key in the ignition and turn it to 'RUN' or 'ON" and then wait 3 to 5 minutes for the burglar alarm to stop. You should then be able to start the engine. You still need to have a qualified/certified Hyundai Service Technician properly diagnose the problem with the remote (Keyless Entry & Alarm System).
Sep 05, 2011 | Hyundai Santa Fe Cars & Trucks
Power lock remote control is not working to open and close the doors while burglar alarm light (armed) keeps on flashing. When any door is opened, sound keeps "on" to indicate problem. The...
Check under the hood. Often, there is a small switch that needs to be closed when the hood is shut. This switch sometimes comes loose and when the hood is closed the button is never pushed. Find the magic button and reattach it to it's mount so that the hood will press it when the hood is closed and that should solve the problem. This button works with the alarm system.
May 25, 2011 | 2001 Honda Accord
Cobra alarm
After market alarms are horrible on MB's as they have built in alarms. If you mean the remote your going to have to get the frequency code from the manufacturer or have the dealership program it to control the alarm if the last 1 did.
If you dont know how the system works I would suggest removing it as most systems dont work well with the pneumatic central locking and fail by burning up wiring it is connected to.
May 03, 2010 | 1990 Mercedes-Benz Mercedes Benz Sl Class
Need batery for cobra model L14900
You can purchase a compatible battery on eBay for $13.99:
http://cgi.ebay.com/BATTERY-FIT-BK-71216-Cobra-LI-3900-700mAh-BRAND-NEW_W0QQitemZ270509452146QQcmdZViewItemQQptZ2_Way_Radios_FRS?hash=item3efb9eab72
Or get the original through a Cobra dealer for $19.95:
http://cobra.com/index.cfm?fuseaction=product.display&product_ID=283
Jan 02, 2010 | Cobra Radio Communications
How to reset cobra 3198 alarm
I have the installation and users book for the cobra 3100 series G193 3193 series
if you want a copy email me and I will scan and email a copy to you, It has how to reprogramme remote controls, reset the system from the main panel and how to disarm if required
judd28@tiscali.co.uk
Oct 07, 2009 | 2006 Honda Fit
Hunter Douglas Ceiling Fan Does Not Work
have hunter douglas fan glass globe broke cant find repalcemants i have all the serial no do you no wher i can go to find 91/2 globe
Oct 30, 2008 | Dryers
Vehicle Parts & Accessories Logo
413 people viewed this question
Top Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
