Question about Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony Bravia stuck in stand by mode
If you hit the power button on the remote the tv goes to stand by mode and will power back up, then go back to stand by.
  • raymond lubecki Sep 26, 2013
    it only blinks red twice
What is wrong when it is in Stand by mode blinking red light 4 times, then pause, then 4 times....
Posted on Nov 10, 2010
    goes in stand by mode and blinks red 2 times
MY tv that goes straight to the screensaver mode like it would on pc. sony bravia kdl32nl140 is the tv.
J, it sounds like it may not be getting any input from cable or satellite, try switching cable and inputs around, try VCR or DVD player. You may need a firmware or software update.
Some forums say to unplug and wait 10 min. then it resets.
Check links below.
Sony eSupport KDL 32NL140 Support
Stuck with initial setup screens on my Sony Bravia 4k Android TV
Feb 21, 2016 | Televison & Video
My 15 month Celcus LCD423D913FHD tv will not turn on. The standby light is lit and will flicker but will not power up the tv. What is the likely problem?
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 20, 2014 | Televison & Video
How to stop sony demo mode
  • Turn on your Sony Braviaicon1.png.
  • Press and hold the Up Arrow button on the remote control
  • Press the Powerlb_icon1.png button on the TV while still holding down the Up Arrow button. The TV will turn off and then turn itself back on.
  • Release the Up Arrow button. Once the TV turns itself back on, it will restore your Sony Bravia to its factory settings.
  • http://www.ehow.com/how_5855646_reset-sony-bravia-tv.html
    May 17, 2013 | Sony KDL 40CX520 40 CX520 Series Full HD...
    Sony Bravia stuck on Bravia screen
    "Bravia Screen". Not sure what you mean. Is it in maintenance mode?
    Option 1.. With the tv plugged in and the power OFF (this is called standby mode) take your remote (make sure it has fresh batteries) follow this sequence on the remote. You have to press the buttons within a second of each other in this order:
    DISPLAY - 5 - VOLUME + TV POWER.
    When the screen comes on hit JUMP right away and it puts you into a little screen for maintenance. Simply turn off the television to exit maintenance mode.
    2. If your remote is bad, ie, new batteries don't fix it, might suggest a new one.
    3. If you can't get a new remote, power on the television using the power button and then hit the menu button. Use the up and down keys to see if you are stuck in some weird screen or something.
    4. If you are connecting something to the television (like a dvd, a playstation, computer, etc) try unplugging everything and test each port individually, using the side buttons as described in part 3 to change the input mode to the port you are using.
    Hope this helps
    Mar 10, 2013 | Televison & Video
    Turn demo mode off on Sony Bravia TV 40"
    Here'show to turn off the demo mode,
    Power ON the television
    (Use remote Commander)
    1.Select "TV" mode (not AV, demo mode can't switch offwhen you are in AV)
    2. Press the "home" button on the remote.
    3. Select "settings"
    4. Select "set up"
    5. Scroll down to "factory setting" and restore them.
    6. When it asks home or shop display select "home".
    Feb 14, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
    When hit power set clicks on and the power lled comes on but the screen does not light up?mod.KDL-40s4100
    is there sound come or your tv goes in stand by mode or not.if not then try to use other inputs. maybe there is problem with only one input.
    is there back light on?if yes and sound come on all in put then you have to update softwear from sony site.
    Oct 18, 2010 | Sony Bravia KDL-40S4100 40 in. LCD TV
    Volume control not working
    Most of the time one of the switches under the control buttons are bad on the control panel of the TV.
    Jul 05, 2009 | Sony BRAVIA KDL-46XBR2 46 in. LCD HDTV
    TV Goes to Stand-by mode
    I don't have a solution, but I have the exact same problem
    Mar 05, 2009 | Sony BRAVIA KDL-46W3000 Television
    Sony BRAVIA  KDL-46S2000 46 in. LCD HDTV Logo
    1,534 people viewed this question
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
