Question about Sharp AL 1631 Copier
Scanner not moving at all
my copier is not printing at all. i read the post previously written and i checked the scanner lock and no matter which way it is turned the scanner does not move at all. Is there an easy way to fix this???? Please help soon
  • geniosity Nov 25, 2007
    hardly moving scanner. moves by hand. rail lubed.scanner starts to move slightly and then returns home( moves about 1/2 inch) and then shuts down lock isn't the problem cause I got it apart to see whats goin on. could it be the motor or a driver somewhere or maybe the pcb?
  • 62 Answers
Take off the glass 2 screws on left side of the machine and try to move the scanner by hand if it moves the you need to oil the scanner rails.If not try to locate what it is stuck on.
Posted on Nov 12, 2007
  • Sharp Master
  • 1,113 Answers
Can I have more info, is machine in ready state?
What happens exactly?
What is display telling us?
When/how did problem start?
Posted on Nov 10, 2007
Error light flashes screen reads caution machine trouble than change to service call 101 h
Scanner motor malfunction, check the scanner lock switch, normal use when moving the machine so scanner does not break, or you have a bad scanner, which is located under the big glass with the very bright light that comes on when you scan or make a copy..
As for the paper check to ensure you have the correct media selected not metric but inch, check your driver setting also inch not mretric no A3 or A4 that metric
May 20, 2014 | Konica Minolta magicolor 2490MF Laser...
How do I resolve the error 'failed to initialize selected scanner'?
Lift the lid as if you are going to make a copy of a document.. then whith the lid up turn the printer off still with the lid up turn the printer on and watch the scan lamp .. the light that moves when you make a copy. Verify that it lights up and moves back and forth. If it does not move back and forth the scanner lock may be in the locked position.. let me know
May 03, 2014 | Toshiba E-studio 233 Multifunction Copier...
Scanner & Printer Features are missing in the system setting.
Print scan card not in unit? ( a SD card on left rear under a cover)
Feb 05, 2014 | Ricoh Aficio Mp171spf Copier,Fax,Net...
We have an Sharp AL 1552 photocopier. The letter L is flashing on the display screen. can not use copier whilst this is showing what does it mean and how can we rectify it?
This problem can be cause by a few different things but just check to see if unit is locked or that it want servicing. 1) If this is a new copier that you just recently unboxed or moved it for one location to another, check to see if the scanner unit is locked. To do this lower you height whilst standing in front of the machine and turn the scanner lock to unlock position. 2) if the copier unit is one that was previously being used the scanner unit may possibly need servicing. Have a service service and lubricate scanner unit.
Apr 05, 2011 | Office Equipment & Supplies
When you lift the lid on the copier and look at the glass you can see a metal cable that is vibrating and making a lot of noise. What should I do?
Sounds like your scanner is locked up. Here is the text from a service tip I have posted here on Fixya. It should help you out.
L1 or L1-00 indicates Scanner movement failure. The scanner is the part under the glass that lights up and moves back and forth. So if you lift up the feeder so you can see the glass, turn the machine off for a few seconds then back on. Watch the movement of the scanner. It should move right and inch or two then back to the left. If all goes well the copier should come to ready. Lay a piece of paper on the glass and press the print button to watch the scanner movement. If it binds up or does not scan correctly there are 2 possibilities.
1) your scanner lock is engaged and is preventing the scanner from moving. Check the clear plastic dial located under the far left upper side of the copier, near where the paper exits the machine. Make sure it is in the unlocked position.
2) Your scanner rail is dirty and dry. This rail can be seen under the glass towards the back of the copier. The scanner rides on this rail. It is very common for these to get dirty and for the grease to dry up causing the scanner to freeze up on the rail. The glass must be removed and the rail cleaned and lubricated.
Just power off then on the copier to reset.
Good Luck and Thank You for using Fixya.
Oct 26, 2010 | Sharp AL-1655CS Copier
I cannot unlock my scanner? Dell 1815dn
The scanner has a manual lock (a blue sliding switch on the base of the scan bed inside of the printing output slot.)
This prevents the scan head from damage when the printer is moved.
Look and reach inside the paper outlet and pull the latch (located on the left) towards you.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Jul 26, 2010 | Dell 1815dn All-In-One Laser Printer
My printer will not print
I have a feeling Your Scanner is Locked, Their is a scanner release switch , make sure the scanner swithc hasn't been moved, these move in away that they could accidentally lock the scanner when you remove paper and stuff.
Mar 06, 2009 | Office Equipment & Supplies
Samsung SCX-4720F reads "SCANNER LOCKED" and won't copy or scan.
the lock is underneath the scanner where the printed paper gets delivered. when you reach in to get a printout you more than likley have pushed it into the lock position. Once you unlock that blue button by pulling towards you, switch off the printer and again switch on the printer.
Jan 06, 2009 | Samsung SCX-4720FN All-In-One Laser...
My printer will not print. It is a Hewlett-Packard all in one psc 2175v model, it just comes on and makes a clicking sound and then it reads, scanner failure and recommends that I turn it off and then on...
On some models there is a scanner head lock to keep the scanner head from moving around and breaking when transporting. Check to make sure it's not in the lock mode.
Apr 24, 2008 | Office Equipment & Supplies
Scanner not wanting to move
Scanner lock is enabled. Scanner lock is located below scanner where pages come out after printing near the left side. turn it a quarter turn and turn copier off and on again. Should solve problem. If not, then scanner could be dragging on a loose mylar under the glass that guides the ribbon cable. To fix this, you would have to remove the glass.
Nov 25, 2007 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
