Question about KitchenAid KSBS25FK Side by Side Refrigerator
Trying to vacuum coils but can't reach them. Is there an easy solution?
    President:
  • 1,136 Answers
Hi, If you have a portable air compressor, they work great. Your local hardware store should have a long brush designed for cleaning these areas out.I have also used a yard stick with a rag taped to it.
Just some ideas.
Vic
Posted on Jul 03, 2009
My Amana ABC2037DPS Refridgertor is not keeping items cool. Last time the serviceman came out he went into the back and "RESET" the unit. Does anyone know how to RESET the Refridgerator?
Most likely the coils under the refrigerator need cleaning. Unplug the refrigerator and remove the front, vented cover below the door. With a vacuum cleaner and crevice tool clean the coils off. It may also help the clean off the door gasket and apply a very thin coat of Vaseline. (Don't forget to clean the refrigerator edge that makes contact with the gasket.)
Sep 20, 2013 | Amana Easy Reach AFD2535DE Bottom Freezer...
My problem is :refrigerator is hot outside, what can i do?
Unplug for five or ten minutes and do this. Take off the back cardboard protector and vacuum out the dust on the coils and especially the fan being careful not to bend the fan blades. Hardware stores also sell a bush for the coils. It can reach in places the dirt needs to be broken loose. Once you clean the dirt off it will run cooler. Caution, The fan blades are usually thin aluminum. Just be aware they bend easy and can be bent back into shape.
Jan 14, 2013 | managemylife.com
How do I access the servo motor?
I have the same/similar problem. I disassembled the vacuum and discovered that it was not actually the servo motor itself. The problem on mine was little a little sensor.
The motor that raises and lower the height adjustment obviously need to stop when it reaches the highest setting (or the lowest setting) so that it doesn't over-adjust itself outside of the normal range (example an elevator in a building must stop trying to go down when it reaches the lowest floor, and must stop trying to go up when it reaches the highest floor.) In the vacuum there is a little slider and a pair of sensors that 'tells' the vacuum when it hits the bottom or top height. The sensor in mine had gotten mashed up and was not working anymore. Unfortunately the position it was in when it got mashed was all the way up, and worse, because it had been triggered to tell the vacuum that it had reached its highest point, it disable the adjustment motor from making further adjustments.
So I bought a new sensor part ($15) (US) but since Electrolux didn't actually stock them, it took almost three months to arrive. Unfortunately for me, I have since forgotten where all the little pieces and parts came from. I am trying to find a repair manual to help me reassemble it properly, and I'll remain cautiously optimistic about this.
Hope this helps you with some insight in your problems possible diagnosis and resolution.
Jan 24, 2012 | Electrolux Oxygen 3 Upright Vacuum Cleaner...
My freezer and refrig are not staying cold, the freezer is defrosting and ice is forming on the back of the freezer.
Many times a freezer and/or refrigerator
do not work right because of a dirty condenser coil...there are also many other
things that can go wrong.
Sep 08, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
You say clean outside coils and fan motor coils. Where are they?
The "outside" coils that you are looking for on a refrigerator will be found either on the back, or in the case of your Amana, on the bottom - behind the toe space bezel. There are no coils on the back of the fridge.
The coils are usually thin, black grates that contain the refrigerant. Be careful not to damage them when cleaning. Open the freezer door (yours is a bottom freezer type) and simply grasp at the top of the bezel an gently pull away from the frame.
Use a narrow crevice vacuum tool attachment to pull the dust and debris from the coils. Use a flashlight to see beyond the very front. You may also wish to unplug the fridge so that you do not damage the fan if it is struck by the tool while running. You should vac the coils annually or more frequently if the fridge is in a dusty area - or there is a lot of pet hair collecting on the coils. Some fridges also have the fan hidden behind a removable panel on the at the bottom of the back side of the fridge. If cleaning fan blades - you must unplug the fridge before attempting. Vacuum any dirt and dust on visible coils seen near the fan.
Mar 29, 2010 | Amana Easy Reach AFD2535DE Bottom Freezer...
Our fridge temp. will not drop below 43 degrees.
I've been struggling trying to keep our 2 goldens dog hair from the coils of our 8 year old Kenmore side by side with "W" compressor coils, but like everyone else was unable to clean past the first set of coils.
I came up with this solution that worked to get much of the big stuff, hair and bunnies, off of the further back coils. Not perfect but much better than nothing.
Removing the back lower panel I was able to snake a crevice attachment from our vacuum down the right side of the coils (left side looking from back)
Looking from front"
I made a compressed air contraption to blow the dust/hair across the coils using a compressed air nozzle that I added a 10" long tube and a 90 degree deflector
From the front of the fridge, on the left side of the coils, I snaked the compressed air nozzle towards the back and started directing the air stream blowing towards the vacuum crevice tool at the opposite side of the coils.
The compressed air dislodged the hair/dust enough that the vacuum was able to **** it away. Again, not perfectly but certainly much better than I was able to clean the coils in the past.
I suppose you could use a can of compressed air and add some sort of deflector if you don't have a compressor.
I then got to thinking how to prevent the dust from accumulating on the coils, I'm going to try an air conditioner filter. I cut it slightly oversized to fit the front opening then split it in half to make it thinner for more air flow.
7a2fbc41-ef6b-4a4c-8961-a892df9da8ab.jpg 938facae-8d39-4f2b-b07c-82f5e4219751.jpg
Picture taken before making the filter thinner.
For years I had my calendar remind me monthly to vacuum the coils but now hopefully I'll be able to simply change the air filter.
Dec 26, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
The refrigerator/freezer is not cooling it has power just will not cool
Try cleaning the dirt off the coils. First vacuum off all you can. If there are a lot of places the vacuum cannot reach, get a refrigerator coil brush at the hardware store and losen the dirt, then vacuum again.
Dec 01, 2009 | Sub-Zero Refrigerators
Ge frig model 18-25, how to clean grills under the frig, full of dust and cannot reach with vacuum tool. This grill is about 8 inches behind the floor plate on the front of frig.
Go to the nearest home improvement store and purchase a rat tail brush. This brush is made for the exact problem that you are having. Ask an employee where to get a coil cleaning brush for your fridge It os easy to use and once you get the linrt and debris off the coil it is easily picked up by vacuum Good luck on your repairs
Dave
Sep 04, 2009 | Refrigerators
Refrigerator not cooling
you have to get a condenser brush from appliance parts store
Apr 05, 2009 | Kenmore 53092 / 53094 Side by Side...
KitchenAid KSBS25FK Side by Side Refrigerator Logo
138 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
