Question about Homelite Mighty Lite Lawn Trimmer
The same when i give it gas it shuts off . What kind of spark plu
When i give it gas it shuts off i replaced the spark plug took off the muffler and cleaned out the screan
  • 1,041 Answers
Check the fuel lines for cracks/breaks. If they are o.k., then:
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance on replacing fuel lines, just let me know.
Jim
Posted on Jul 03, 2009
  • Jim Parker
    Jim Parker Jul 06, 2009
    Did this solution solve the problem?
    Jim
  • Jim Parker
    Jim Parker Nov 26, 2009
    Thanks for the rating.
    If you should have any questions about
    "Drywall Finishing/Patching", or know someone who does, put your
    questions to Category:"Tools- Building & Power- HAND TOOLS" at
    FixYa.com
    Thanks Again,
    Jim
Poulan 38cc wont start
quick check would be to pull muffler from engine check the screen if the screen is ok start engine if it starts without the muffler the muffler needs to be replaced.if it still dont start do pressure and vaccum checks on carb.
Jan 28, 2013 | Poulan Garden
Chainsaw wont throttle up dies out;cleaned out carb. relaced fuel lines .
pull your muffler off and see if it revs up, if it does then your spark aresster screen or muffler is plugged, from carbon or mud dobber hornets
May 22, 2012 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I have a Echo PB-260L Blower. It starts fine then gradually loses power sometimes completely shutting off. I have replaced the fuel filter spark plug air filter and have cleaned the screen.
Check the exhaust port upstream from the muffler and make sure it is not restricted with carbon. Mine was less than half way covered over with carbon. Scraped out carbon, checked muffler and screen(ok), back-blow the fuel line harness including the fuel filter and fuel tank vent and took carb apart and blew out all passages, not replacing anything and now runs fine. Would not rev past high idle before. Be sure gas is FRESH and mixed at 40-50 to 1. Hope this helps.
Jul 14, 2010 | RTO Echo 25.4 Cc Backpack Leaf Blower -...
No spark at the plu
Generally gap is required for the plug, this is due to less power from the wire, kindly call the electrician and check the spark strength and the plug model. Then you come to know whether the problem is in electric side or mechanic side.
Kindly rate my help+++ Thank you.
May 09, 2010 | 1991 Suzuki GSX 1100 GM
Husqvarna 125L quit running, it runs then shuts off
You likely need to replace the muffler,this is a common problem and if the engine can't get rid of the exhaust it also will not take in more fuel,happens a lot with anything with a spark arrester in the muffler.
Apr 18, 2010 | Husqvarna 28cc Gas Line Trimmer
Troy-bilt gas edger trencher won't start. Spark
Remove spark plug and pour 5mls or one teaspoon of premixed gas in the engine. Depress trottle to full with choke on "run", pull starter about 10 to 12 times If it starts and run for a while and then shuts off your carb needs servicing. If not remove muffler and look for a spark arrestor screen. This could be plugged up with soot. If it is, replace and this would have been your problem. While the muffler is off slowly pull starter rope and examine the piston if gas and oil oozes backwards as the piston moves to the top then the piston and rings need replacing.
Oct 25, 2009 | Garden
Car keeps shutting off
I can solve part of your problem. I would check the crakshaft position sensor. These are located behind the harmonic balancer. This will caues the engine to shut off when the engine is at opperating temperature. As for your fluctuating fuel needle, I have a question for you. Do you use Shell gas at all? If you do then their detergents in the gas has eaten away at your fuel sending unit and it needs to be replaced. Only use Esso, PetroCanada (if you are in Canada) or Chevron gas if at all possible. Shell has had dealer bulletins about GM and Dodge not using their gas. The check engine light is usually a faulty O2 sensor but replace the CP sensor first.
May 27, 2009 | 1999 Oldsmobile Alero
torque converter switch is bad.
Aug 03, 2008 | 1999 Oldsmobile Alero
Homelite Mighty Lite Lawn Trimmer  Logo
406 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
