Question about Belkin N1 Vision Wireless Router
Belkin N+ modem router (F5D8635) not recognizing Maxtor 1TB HD
My new router features a USB port that can mimic a NAS system: you can plug whatever USB device and it will be available to every computer in the LAN as a network drive. It works fine with a pendrive but, contrary to what's stated in the documentation (which makes no exception for this feature), my Maxtor external 1 TB USB2.0 hard disk seems not to be recognized. No matter if the drive is idle or sleeping: the blue LED indicating that the drive is available remains unlit, though sometimes it lights up for an instant after the drive is plugged. Of course, the drive works perfectly when attached to a computer. It's very annoying because that was the main reason for me to buy the router!
  • Anonymous Mar 26, 2014
    When I attach a Mediasonic Probox to the USB port on my Belkin N750 DB it only recognizes 1 hard drive (there are 3 in the box). Can it recognize any of the others?
    Scholar:
  • 92 Answers
I could not find the F5D8635 model but here is the Firmware update page for the N1 Vision Router.
Try updating your firmware.
Posted on Jul 03, 2009
Belkin F5D7234-4 V5 MODEM LIGHT AND INTERNET LIGHT ARE BLANK. WHEN I RUN A CABLE FROM MY MODEM TOMY COMPUTER, INTERNET WORKS, BUT WHEN I CONNECT THE CABLE FROM THE MOEM TO THE BELKIN WIRELESS ROUTER, NO...
Is this a new router - or should I say did you only have the one computer hooked to the modem until now? Some ISPs use the MAC address of the installed PC to assign the network IP address. Since the Router will have a different MAC address, the modem will not recognize it. ISPs use this as security, but it makes networking impossible. However, most routers have a feature called MAC spoofing, which allows the Router to fake the modem into believing it is the computer originally attached to the modem. On newer routers this is a feature that can be automatically done during the setup wizard. You need to have the original PC hooked to one of the router ports (not WAN or INTERNET) and when the router asks you if you want to use the MAC spoof, say yes.
Oct 23, 2013 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I have a Belkin N+ router and I am trying to use the USB storage sharing feature. I have a WD HDD mounted in an Ultra external enclosure. When I plug the HDD into the router, the storage LED on the router...
it says the HDD is not compatible with the router.... it might be due to the file system in HDD....
At this moment, the Belkin N+ Router and Modem-Router, F5D8235 and F5D8635 work with the FAT, FAT32, and NTFS file systems only.
Versions of the F5D8235 firmware earlier than 1.01.24 may fail to detect a drive that contains a mix of supported and unsupported file systems. This was fixed in firmware 1.01.24, available from the Belkin UK Support Site
We have seen a few compatibility problems with drives not being recognised and we are investigating these to get them fixed.
We have also seen occasions where a drive was not detected by the router or modem-router due to a poor quality USB cable. If a bus-powered drive does not spin up, the first thing to do is to make sure that a good quality cable is used. Even self-powered drives may fail to be recognised when using poor quality cables. Even though the cable may work when the drive is connected direct to a PC, always try a different (good quality) cable as part of troubleshooting drive detection problems.
Tech Support: If you come across a drive that is not being recognised by the Router or Modem-Router, please check on the hidden page http://192.168.2.1/storage_disk.html if the router has detected anything at all. Make sure that the drive works when connected directly to a Windows computer and try a good quality USB cable as mentioned above.
Apr 24, 2010 | Belkin F5D8236-4 Router
Connecting WD Passport external HD with Belkin N+ router
I had this same issue. Found it to be a sequencing issue. Plug the USB into the router with the power off to the HDD. Power on the HDD and you should be able to get to it fine. Also make sure you have the latest firmware on the router.
Nov 27, 2009 | Computers & Internet
I have recently bought a Belkin N+ Wireless Modem-Router (model F5D8635-4 v1). It comes with the USB port and I bought a WD 1Tb drive to connect with it. I added the WD drive (92.168.2.1My Book in my...
  • First off, the WD hard drive was meant to be connected to a computer.
  • Therefore connect it to the fastest computer you have or the one running the network.
  • Make that drive a network drive.
  • Set the router to handle DHCP using the web based interface (192.168.1.1 on a linksys router, check your manual for the IP address belkin)
  • The drive apparently has three volumes on it: X: Y: and Z: (network drives)
  • I would backup the WD drive and reformat in NTFS format
  • I dont believe that these drives were meant to be networked. Therefore you get what you get....
Good Luck
Jeff
Sep 14, 2009 | Computers & Internet
Belink F5D8635-4v1 Firmware 1.00.17 Boot Code Version 1.1.5
Firmware 1.00.23 fixes the VPN issue on the f5d8635 series.
Sep 09, 2009 | Belkin N1 Vision Router
WD My Book 1TB not recognised by belkin modem router USB storage
If I understand correctly ... You have not connected the drive to a computer.
If I am not mistaken the WD My Book has preinstalled backup software installed on it. It very well might also have a power down built as part of that programming. Try attaching it to a computer to verify this.
Assuming the backup software needs blank drive to work correctly I would first access the drive select all and delete anything you find (if you know how to unhide hidden files do that before you select and delete all) ... As a 2nd option I would just reformat the drive.
Hope that helps....
May 31, 2009 | Belkin Wireless Pre-N (F5D8230-4) Router...
Hi
i am fairly certain The WD my book external hard drive needs to have the correct software to be able to use and because routers dont have a CD drive i dont think you will be able to do it.
Apr 27, 2009 | Belkin N1 Vision Wireless Router
I have a work around for this.
In the detail of the Belkin manuals it says you can attach up to 4 USB storage devices via a USB HUB.
I had an old Hub so I Connected the HUB to the router and the Maxtor to the HUB --- It worked :-) It came up in a few seconds.
At first I powered the HUB but later took the power out of the hub and it still worked ;-} However when I used a different HUB it would not work without power to the HUB.
The HUB I use is an old Belkin 4 port Tetra Hub. The newer 7 port Belkin HUB (5 Rear 2 Top) only worked with the HUB powered.
Hope this helps untill Belkin Upgrade the Router sofrtare.
Apr 07, 2009 | Computers & Internet
This is not as complicated as it may sound. You don't need the manager. Bring up the "run" window (XP - Start - Run / Vista Alt-R). Enter the following address [\\192.168.2.1] press enter. The drive will show up. Right click on it and select Map Network Drive. You can then uninstall the useless program from Belkin.
Jan 20, 2009 | Belkin N1 Vision Router
NAS Drive by ADS Tech not recognized on network.
You can log into your router and find out what IP address has been assigned to your NAS unit.
Then start up Internet Explorer Or Firefox and go to the address http://xxx.xxx.xxx.xxx (replace with the IP address of the NAS unit).
That should get you in. Then you will have to set the workgroup and share parameters. Once you have it setup you can always map the NAS unit and use it as a external hard drive.
Dec 18, 2008 | Computers & Internet
Belkin N1 Vision Wireless Router  Logo
604 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
