Question about Dryers
Dryer is not hot. there is no heat coming out
It is a GE dryer. Model number DBXR463GB0WW. The dryer is not hot. It runs fine but there is no hot air. Need to know what part to order
  • 1,000 Answers
A couple of quick things to look at.
1, Make sure the gas valve is on and there is a gas supply.
2, If the vent duct is not clean or restricted, the vent sensor will not allow the burner to ignite, also make sure the burner exhaust vent is clear. Any restriction of the air inlet or exhaust will cause the burner to not function.
Let me know what you find and we can go from there.
Good luck.
Regards,
Posted on Jul 03, 2009
Ge dryer dcvh515efoww runs on air dry, but when set on any heating cycle, it runs for a few minutes and then it turns off on 00
it is over heating you might have unplugged a wire to the thermostat when you had it apart or the thermostat has went out.
Mar 21, 2014 | GE Dryers
GE DRSR495EG electric dryer turns on, will not heat, motor works and is hot, but no hot air.
Well it is not the fuse. Because you say it runs but don't heat. It probably is the heat element. The only way to know is to check it. (how to restring a heating element)
4521e8e.jpgee2d15e.jpge03afc1.jpg69c6326.jpg49483dc.jpgMore Here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 02, 2010 | GE Dryers
I have a Kenmore electric drier # 110.60912990 It runs fine, but no hot air. What should I check. I checked the outside vent and air is coming out. I check the circut breaker and it is fine.
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 03, 2010 | Kenmore 64942 Electric Dryer
GE Dryer Model #DWSR483EB2WW Dryer tumbles,
Does it get hot when you start the dryer, and never gets hot again when its running? The solenoid wire might be opening due to heat, the solenoid is responsible for opening the gas valve, and booster valve. The wire is located in a round plastic sleeve with two electrical contacts sticking out.
Dec 11, 2009 | GE DBSR453EBWW Electric Dryer
My dryer dosen't dry my clothes
Check the exhaust tube for obstructions. If this is a gas dryer it needs airflow coming and going through that tube. This is always the cheapest, easiest first step.
Sep 05, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer is running, but no heat
Sound like you need to replace the heating elament you will need to take your model number and make to repair shop for replacement parts or have a repair person come out and fix it for you . thanx for using fixya
Jun 16, 2009 | GE Profile Harmony DPGT750EC Electric...
Model DBSR453GB1WW bought around 2004/2005 - Dryer runs but will not heat up?
This model uses an ignitor, you can replace the ignitor for about $80
May 12, 2009 | GE DBSR453GBWW Gas Dryer
GE Profile dpsr473ewoww timer doesn't work and heat level is low
We should address the heat problem first. If your dryer complaint is "heat seems low" or taking "too long to heat", this is commonly confused for other problems. When in fact, you may really have a "ventillation problem". Do you feel (with hand) alot of hot air pressure coming out the back of the dryer or house vent-line (for dryer)?
I would disconnect and clean the dryer exhaust vent/duct (at wall and machine). Then, while leaving the vent-line disconnected temporaily, test and run your dryer. You may see an signficant improvement.
Does it heat up better?
Do you feel alot of hot air and pressure coming out the back of the dryer?
When connected; do you feel alot of hot air pressure coming out of your house dryer vent?
MaintenanceUniverse.com
Feb 01, 2009 | GE Profile DPSR473EW Dryer
Heating
The most common cause of heater failure is the thermal cutout/thermal fuse/temperature cutout(any of a dozen names for the same thing from different manufacturers) a device on the exhaust ducting near the fan housing. on over temperature, when the air temperature is hotter than the normal range set by the thermostats, these units melt out,
they are not resettable, they are replaced, ~$8 each, except where manufacturers are gouging
they look usually like this 2543d18.jpg or this d733938.jpg conduction good, open circuit fail
common to many dryer models the local parts guy will have them to suit, even if they are labelled with a different make or model
Oct 05, 2008 | GE DBSR453EBWW Electric Dryer
Dryer problem
What brand of dryer is it? Model number? The lack of heating could be a number of things. Be sure the vent tube isnt clogged or pinched. The other options are bad element, bad thermostat or bad thermofuse. Depending on what type it is would also depend on how to make the repair, how to get to the parts, etc. Get me a little more information and we'll get you heated up. Jim
Sep 08, 2007 | GE DBXR463GB Gas Dryer
Dryers Logo
148 people viewed this question
Top Dryers Experts
Marvin
Marvin
