Blink 1 time constantly not stop blinking
Cq60 cap lock blink 1 time constantly: inmy opinion:
1) most case due to cpu over heating impact northbrudge with video integrated chips, it lost BGA any point connection inside. so you may try do BGA rework of northbridge ships
2) EC chips icould not initial from bios completly or bios chips lost any data inside, so you need try BGA rework southbridge if which is integrated with northbridge. or try to rewrite bios ships data
cq60 cap lock blink 1 time constantly: inmy opinion:
Hello do you have a black screen? no video appears on screen, from what i have encountered is the cpu is going out. Try hard resetting the computer by pulling the battery and holding down the power button for 10 seconds. Replace battery and reboot. If problem still exists you will need to replace the cpu.
You may try this fix. No guaranties though. Remove the battery and unplug power cable. Then hold down the "power" button for about 10 seconds. After that plug it back in and try turning it on. Again, this may NOT work but it has for others.
SOURCE: Compaq Presario CQ60 touchpad problem.
Boot your laptop. After the laptop shutdow and just at the screen light up, hit f1 or f2 key to enter any setup screen. Then hit F10 to exit. after reboot, your touch pad should come back. It worked for me many times.
SOURCE: Compaq Presario CQ45 screen remains blank... help
Open the Notebook from the back side and locate the RAM. Now remove the RAM and place it again and check, you can even try inserting the RAM in different slot if any used slot is available.
Check out.
SOURCE: i have a Compaq Presario CQ60 scroll touchpad stop working
The notebook model you have is shipped with the Synaptics touchpad driver. Please follow the below steps to enable scrolling features:
1. Open Control panel -> click on Mouse . It will display Mouse Properties dialog box.
2. Under Mouse properties Window click the Device Settings tab
3. Click on Device Settings -> Settings button. This will display the Properties for Synaptics TouchPad on PS/2 port.
4. Follow the steps below to enable the Tapping Feature :
Highlight Tapping in the Left hand side , and Check the Enable tapping in the Right hand box .
5. Follow the steps below to enable Scroll feature:
Highlight Virtual Scrolling in the Left hand side and Check both the boxes in the right hand side.
6. Click OK .
Alternatively you can anble scrolling by reinstalling touchpad driver.
Touchpad driver for Vista:
ftp://ftp.hp.com/pub/softpaq/sp39501-40000/sp39534.exe
Touchpad driver for Windows 7:
ftp://ftp.hp.com/pub/softpaq/sp44501-45000/sp44940.exe
SOURCE: hello my compaq computer screen has no image on
Hello, in www.hp.com you go into support and drivers and write in search yours computer name and model and you will see a long list of fail codes, many of those codes are in a range of CPU- , Graphics- , memory- and BIOS-failures.
Go to the computer store there you bought your computer and reclaim repairs or replacement, IF you not have open(repairing) or misconfigured(wrong BIOS-file) your computer.
SOURCE: Display problem with Compaq Presario
Did you by chance spill liquid onto the laptops keyboard?
