Question about GE A730 Digital Camera
When I turn the Camera on I can hear the lens trying to come out, but it cant make it out at all, helllllpppp
I had the same problem with mine - I sent it back to California,and the tech guys were super helpful - turned out I was using cheap dollar store batteries, which the camera didn't like - if I use Energizers it's fine
Posted on Jul 19, 2009
  • 126 Answers
You have a bad lens. Your best solution is no solution. Today's camera in the under $200 price range as a rule are not worth repairing.
Posted on Jul 03, 2009
Lens wont go in
I had the same problem, my workaround was:
1. turn on the camera, you will hear some beeping as the lens tries to raise from the body of the camera
2. wait until the camera turns off
3. pull the lens gently until you hear a 'click'
4. turn on the camera again, it will work normally (hopefully)
Another interesting thing, you can switch on the camera in "play mode" only, by holding down the play button on the back while pressing the power button. In that way, the lens will not raise and you can copy the images.
May 24, 2010 | Polaroid i735 Digital Camera
I have a fuji A100 10.0 megapixil digital camera. am getting zoom error message and cant get camera to do anything..can you help
Owners manual says "zoom error" indicates a camera malfunction. But, try this, gently grab the lens, pull it out as far as it will go until fully extended. While keeping it extended turn the lens to the right until you hear a click. Once you hear the click, release the lens and turn the power button on and then back off again. This should take care of the problem. A word of warning. ALWAYS make sure your fingers do not touch the front of the lens when you power on the camera. Even the slightest bit of obstruction seems to make the problem reoccur.
Also, sometimes you may have to try several times until you finally heard the click, so please don't give up on it, just keep trying. This will work and it will save you a lot of time and money having it fixed.
Mar 19, 2010 | Fujitsu Cameras
Camera wont turn on and lens wont go in and i just put new batteries in
Lens of the Camera doesn't retract:
Before trying any of the suggestions, make sure that the Battery is
fully charged and in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes,
then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry compressed
air (20 lbs) set the tip between the lens turret and the camera body
and turn on the air while moving the tip around the lens. It should
remove all dust and sand. Turn the camera on and it should function
fine.s
3) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and
take a look at the spacing between the lens and the lens housing. If
you notice that the gap is not even all the way around the lens, the
problem should be easy to fix. This type of a problem usually occurs if
the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try
powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts
again, do the following.
(a) Turn the camera off.
(b) Take the camera in one hand and with the other gently take one part
of the lens and gently move it round in a circular movement. Do so with
both sections of the lens. You will hear a "click" as it pops back in
place.
(c) Power the camera on.
Another version of this fix would be to pull and twist on the largest
ring of the lens while turning the camera on. Listen for a "click". If
at first the focus seems to be off, turn the camera on and off and take
lots of pictures, close ups and distance. Focus should slowly start
improving.
Dec 02, 2009 | Kodak EasyShare C913 Digital Camera
My camera wont turn on.
If the lens is stuck inside the camera and you hear a motor noise - changing batteries will not help. This has happened because the lens barrel is jammed inside the camera. Unfortunately, you will not be able to repair that issue. If the lens is stuck outside the camera, slightly tilted, and you hear a motor noise; you might be able to save camera. First, only use good batteries (stay away from alkaline batteries - waste of money), go with Energizer Lithium or Duracell Power Pix (you will get your moneys worth and have less problems with the camera). Second, very GENTLY, pull the lens barrel up and in the opposite direction of the tilt (to make the lens barrel straight), you will hear a slight click sound - DO NOT PUSH ON THE LENS BARREL!!!. Put in the new batteries and the lens should retract.
Oct 06, 2009 | Polaroid i733LP Digital Camera
Jammed lens
If your camera is still under warranty, the best thing you can dois to take it to the nearest official repair shop and Olympus Digital Cameras shouldfix it for free.
If your camera is out of warranty, or if Olympus refuses to repairit for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try some ofthe methods listed here to repair it yourself. These simple methodshave helped a lot of people fix their cameras.
Before trying any of the suggestions, make sure your Olympus Digital Cameras has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes,then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and drycompressed air (20 lbs) set the tip between the lens turret and thecamera body and turn on the air while moving the tip around the lens.It should remove all dust and sand. Turn the camera on and it shouldfunction fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but veryoften in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Olympus Digital Cameras and fixing the E18 error. (NOTE: Try this only if your camera is no longer under warranty!)It is a great guide with pictures and it can be found here.
There are 2 other guides, one Bulgarian and one Estonian with the take apart procedure for Canon cameras.They are not in english but have a lot of pictures which help with the process.
- Bulgarian guide
- Estonian guide
Hope this may help you;
Regards,
Jan 29, 2009 | Olympus FE-280 Digital Camera
Lens Problem
The lens mechanics need to be repaired by a qualified professional,
possibly just lubricated. Get an estimate first to make sure its worth it.
Martin
Nov 05, 2008 | Olympus Stylus 700 / 700 Digital Camera
It wont turn on, And the zoom is extended.
I had exactly the same problem. Lens stayed open, when powered on you get three beeps and nothing. I found when I pulled the lens out a little harder it gave a little click. When I powered on it worked perfectly.
Nov 25, 2007 | Samsung Digimax S800 Digital Camera
Lamp light
Does ur camera ever say "lens error"? It sounds like what I typically hear as a lens error and the only way to fix that is to send it into repairs.
Nov 21, 2007 | Casio Exilim EX-S600 Digital Camera
GE A730 Digital Camera Logo
112 people viewed this question
Top GE Cameras Experts
Steven Wander
Steven Wander
jjanesic
jjanesic
Level 1 Expert
Are you a GE Camera Expert? Answer questions, earn points and help others
