Cars & Trucks Logo
Posted on Sep 08, 2014
94 Jeep Cherokee TPS - back feed
I have a 94 jeep cheroke SE with the 4.0 and aw4 transmission. Last week the jeep started shifting only when it hit 4500rpm. I tested the TPS and had 5 volts input and 4.6 volts output at all times. Even when the TPS is unplugged. I have replaced the TPS and PCM with no change. The jeep still idles high and shifts at 4500 rpm. I'm at my wits end. I'm also getting a code 24 from the computer.
Richard Egli
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 79 Answers
  • Posted on Sep 08, 2014
Richard Egli
Contributor
Level 1:
New Friend:
Cheetah:
Answers
79
Questions
0
Helped
15936
Points
85
You are still getting high or low voltage at tps? What is the voltage and do you have a unstable idle? Put you + lead on terminal 3 and - lead on terminal 1 turn ignition on and check voltage to be at approximately 5 volts. You can also back probe with it connected at center wire and ground probe to a good ground at engine. Turn ignition on it should read between 0.20 - 0.90 slowly manually open throttle it should rise all the way to 4.5 voltd at full open. If its bad change tps if no 5.0 volts from pcm on first test check connections at pcm. The center tps connector supply wire comes from pin 22 and connection 3 ( which is 5 volt supply ) comes from pin 6. You should be able to back probe pin 6 turn ignition on and have 5 volts. If not 5 v brain has problem.
  • Richard Egli Sep 08, 2014
    You are still getting high or low voltage at tps? What is the voltage and do you have a unstable idle? Put you + lead on terminal 3 and - lead on terminal 1 turn ignition on and check voltage to be at approximately 5 volts. You can also back probe with it connected at center wire and ground probe to a good ground at engine. Turn ignition on it should read between 0.20 - 0.90 slowly manually open throttle it should rise all the way to 4.5 voltd at full open. If its bad change tps if no 5.0 volts from pcm on first test check connections at pcm. The center tps connector supply wire comes from pin 22 and connection 3 ( which is 5 volt supply ) comes from pin 6. You should be able to back probe pin 6 turn ignition on and have 5 volts. If not 5 v brain has problem. Call me if you need more help 5419427218 my name is Richard hopefully well get You back on the road.
5 Related Answers
Anonymous
  • 6982 Answers
  • Posted on Dec 16, 2008
SOURCE: 1993 JEEP GRAND CHEROKEE AUTOMATIC TRANSMISSION
Likely you have a shift control module malfunction. Module is probably on the right side fender in the engine compartment. Check to see if you have one (some do and some dont... go figure...I've got a 91 & 95... I have about five different diagrams and NONE apply to my vehicles)
Anonymous
  • Posted on Feb 11, 2009
SOURCE: 94 jeep grand cherokee will not shift into overdrive
My 97 Jeep Grand Cherokee was doing the same thing. I changed the TPS ( Throttle Position Sensor) Now it is great goes into overdrive fine. It is really easy to change.
Ronnie Wilson
  • 1596 Answers
  • Posted on Sep 22, 2009
SOURCE: Change transmission fluide in 1999 Jeep Cherokee
Flush is Recomended Here as Changing Fluid can get Messy
Anonymous
  • 5081 Answers
  • Posted on Oct 11, 2009
SOURCE: shift indicator light 1999 Jeep Grand Cherokee
There are two parts to it, a voltage resistor, and the EL panel itself.
You need to remove the console first. There are 2 screws under the front rubber pad, two under the cup holder, two in the bin. Remove those six first, take the storage bin out, then slide the rear cupholder out, remove the two screws under the cup holder, and one in front of it.
There are a total of 6 flat screws, and 3 self tapping screws you have removed.
Put the parking brake on, shift the tranny to N, and the transfer case to the middle position if equipped.
Remove the entire console. Slide the shifter beezel as far up vertically as you can. There are 4 clips you ned to remove to do it.
You will see a blue and black wire running into the back. Follow those wires to the resistor. You will see a transparent EL panel attatched to the resistor by two clips.
Usually, one or both of these clips has come loose, causing the light to work intermittantly. Clip them back on, and turn on the headlights to confirm that the light works correctly now.
Re-install everything in the opposite order.
raj somaiya
  • 5370 Answers
  • Posted on Jul 08, 2011
SOURCE: 2004 Jeep Cherokee 4.0 getting Error code P0505, I
Yes its possible that PCM, is issue, but its not possible that PCM is issue.--------- Do you notice the difference after replacing the idle, was the idle high or low before replacing the IAC valve? And did the idle problem solved after replacing the IAC valve.----------- The check engine light will need to be reset with a scan tool, or you can wait and the computer will reset after the computer has seen that the problem is gone for a certain amount of starts. This is assuming that the IAC was actually the problem, there are other causes that can cause this code to set but if the idle was to high and now it is good the problem is likely fixed. some times it takes approx next 100 or 50 drive cycles to automatically reset the code.------------
But if you still notice the idle problem, even after replacing the IAC valve, then other possible causes for this same error code P0505 are:---
  • Stepper motor Coil 1 or 2 circuit is open or shorted to ground.
  • Stepper motor Coil 3 or 4 circuit is open or shorted to ground.
  • Stepper motor coil circuit(s) shorted to system power (B+).
  • Stepper motor is damaged or has failed.
  • PCM has failed.
  • ----------- But yes if all checked ok, then it faulty PCM.----- It has to be replaced by dealer.This will help.Thanks.Helpmech,.
    I have a 94 jeep cheroke SE with the 4.0 and aw4 transmission with tps backfeed of 4.2 volts
    have you tried starting in low and shift manually? aw4 transmission , is that all the time 4x4
    Where is the location of shift solenoid on a 2000 Jeep Cherokee?
    Its inside the pan and behind the trans filter assembly within the transmission,,, about 14 bolts to drop the oil pan ,, 2 hold the trans filter in place,,
    Here are the instructions on the jeep forum website AW4 Solenoid replacement write up no 56k JeepForum com
    94 jeep grand cherokee limited wont drive
    sounds like a bad transmission. did you check the transmission fluid level,and if you need to add any transmission fluid use only chrysler plus 4. this is my link to my garagehttps://www.facebook.com/TedsRepairs
    1helpful
    1993 Jeep Grand Cherokee, Takeoff and excelleration are normal, shifts 1-4 are fine, shifts erratically about 15 min after hitting highway speeds then stops going into overdrive. i noticed the torque
    you need to have the bands adjusted in the transmission.. jeeps are known for this issue... takes maybe an hour to adjust all the bands and can be done by just removing the transmission pan and adjusting... if you feel this is something you can do let me know and i will give you a step by step walk through on how to repair..
    1helpful
    1helpful
    Will a 91 jeep cherokee trans fit a 94 jeep cherokee
    it should, on the 4.0 they are all the aw4 tranny.
    1993 Grand Cherokee AW4 transmission issue
    have you tried a rolling shift? leave trans in drive and try moving 4x4 lever. it works on mine!
    2helpful
    3answers
    Transmission shifts late 89 jeep cherokee 4.0l Auto
    discovered a service bulletin on my Jeep on "Alldata.com", which indicated "A/T - Throttle Position Sensor".I don't subscribe to the site, so I could only see this header. I thendid a search on Throttle Position Sensor and found a number of sitesthat described numerous transmission problems attributed to this sensor.I tookthe Jeep to a Chrysler dealer near me, and purchased the part for$69.00. I installed it myself, and the Jeep shifts beautifully, betterthan when I bought it.
    A. The TSB you are refering to is number ATRATB324A, dated 1/1/1996 witrh the subject "A/T - AW4 Throttle Position Sensor (TP)".
    TheTransmission Control Unit does, indeed, use an input, among others,from the TPS to determine shift times. So if there is a problem withthe TPS, it will effect transmission shifting. In fact, it is not allthat uncommon to see a TPS cause a transmission problem.
    If the transmission works fine after the TPS is replaced then I would only recommend thata routine flush be done to it and perhaps treat it to a new filter.
    http://autorepair.about.com/library/faqs/bl070g.htm
    9helpful
    2answers
    2answers
    94 Jeep Grand Cherokee Transmission Problom
    1994 is the same as 1997. parts are interchangeable
    Top Jeep Experts
    ZJ Limited
    ZJ Limited
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Thomas Perkins
    Thomas Perkins
    Are you a Jeep Expert? Answer questions, earn points and help others
