Question about Poulan Pro 22" Self Propelled High Wheel Mower
After 1 season it ran great ,slowly died now it wont start
I have poulon w/ a 5hp briggs and strstton,,1 yr old. I have a very small yard and the last couple of times the motor seemed to run weaker and weaker , and finally quit and wont start, clean gas , filter . always started on the first pull, now nothing
    Problem Solver:
  • 15 Answers
So many possibilities, so little data... <grin>
When you say "clean gas", do you mean that you added "fresh" gas, or that you emptied the tank, and refilled it with "fresh" gas?
Try this:
a. remove the "float bowl" screw, and put a regular "bowl" or pan underneath to catch ALL of the gas as it comes out.
b. if the gas is totally "clear", then it (probably ain't the gas), but... if it's "yellow", it's old and/or contaminated; alternatively, if there's any water (which may appear as a grey-ish liquid) then it's contaminated; also, don't forget to check the gas from your "storage" can, the same way...
c. re-install the the screw, and put some *FRESH* gas in the tank.
d. pull the spark-plug, and clean (or replace) it.
e. prime it, and crank it, and it should start right up.
Posted on Sep 27, 2009
Briggs & Stratton engine on Sears Self Propelled, 8 years old, backfires thru carb will not start.
Back firing through the carb is an ignition timing issue or burn exhaust valve, i would re check the flywheel key, a loose blade will also give issues.
May 21, 2018 | Briggs & Stratton Garden
Craftsman 22" self propelled platinum series lawnmower died while pushing it. wont restart. ????
A good place to start is taking the air filter off. Then try stArtingvit again. Often a dirty air filter will not allow a mower to stay running. If that does not help. Remove the cover under the carburetor looking for dirt in the cover. Also well the cover is off remover the small pin that holds the float in place. Pull the neddle valve out cleaning it and the other parts with a carburetor cleaner then reassemble
Jul 21, 2014 | Briggs & Stratton Garden
Points gap setting on a Briggs and Straton 5hp.? engine horizontal shaft
.020 but use the right key they are made to shear so you don't get internal damage
Mar 28, 2012 | Garden
My poulon lawn mower will start witht he choke fully on. Once it is running and the choke automatically starts to close, it get about 2/3 closed and the engine dies. I have cleaned the float bowl and...
Sounds like the main jet in the carb is clogged. It will operate on the choke circuit but not on the main circuit. The main jet needs to be cleaned.
Jul 20, 2017 | Poulan "" Push Mower
Hi I have a 22 hp briggs in a husqvarna rider. Started running a little rough at season end last year. This year it started, but ran only about 2-3 min, then would not start at all, put in new plugs (old...
This a common problem after they have set up over the winter. Water has probably condensated in your gas tank and now it is in the gas line. The tank should be drained of old gas and the gas line to the carb should be removed from the tank and blown out with compressed air to remove all old gas/ water. Attach the gas line back to the tank and refill the tank with new fuel. This should take care of the problem. To avoid this next time, just fill your gas tank to the top at the end of the season and leave it full through the winter.
Mar 28, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Cant start 5hp engine it sneezes and backfires
hi,
first try a new plug, make sure you get the right one. did you recently hit something hard in the yard? you may have snapped the flywheel key. its under the cover and then its under the mesh grille on the flywheel. under the big nut on the flywheel is the flywheel key. it keeps the flywheel in time with the driveshaft. they are made to shear off if you hit something extremely hard and will throw it out of time. if it wont start with a new plug and starting fluid then it may need a new flywheel key pin. make sure you always run your lawnmower out of gas at the end of the season so the gas doesent turn to varnish too..
jm
Jan 21, 2011 | Briggs & Stratton Garden
Hard to start lawn tractor
I have 2009 lawn tractor that will not start (from day 1) unless I use a small squirt
of start fluid into the air cleaner area. Nothing else seems to work. The battery will run down before it starts. Once engine is warm it starts great. Love the tractor,
hate the starting problem. Elevation is not a problem in michigan.
Jan 11, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Poulan Pro 22" Self Propelled High Wheel Mower Logo
131 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
