Question about Mtd 22" Yard Machine Push Mower
MOWER WONT START
I have a briggs n stratton 550 it will run 4 a little while than quits running ichange the sparkplug cause when i check it was so hot that the tip turn white now it wont start i have only mow 3 times
  • 14 Answers
Make sure that you have oil and that the airflow is not blocked,,,take the cover and tank off and look underneath, the flywheel is designed to have fins that circulate the airflow, sounds like the piston has welded itself(from lack of oil or airflow) to the cylinder wall. good luck
Posted on Jul 07, 2009
It starts and runs but gets hot and quits
the only way for an air cooled motor to get hot is from the cooling fins on the head and cylinder to be blocked from straw and mud
remove the cowl on the motor over the fly wheel and clean it all out
Nov 07, 2015 | Briggs & Stratton Garden
Why wont briggs & stratton 173 cc Engine yard man walk behind mower wont start when hot
Try replacing filter element. May swell when hot causing loss of air.
Check with Partstree.com 877-970-2662. They may have an answer for you.
Jul 17, 2014 | Briggs & Stratton Garden
Wrong gas in lawn mower, what to do
if its a briggs and stratton engine with the plastic carb fixed to top of the fuel tank then you will need to replace the diaphragm and blow out the fuel pick up pipe
Jun 26, 2014 | Briggs & Stratton Briggs Stratton...
How do i idle down the engine or govern down the engine on a briggs and stratton 550 series mower model 10T802
that engine uses a fin style governor remove the upper cover and see if there is a nest or something holding the fins movement
Jul 12, 2012 | Briggs & Stratton Briggs Stratton...
I have a brigg and statton mower 550 series its brand new i used it twice and now when i prime it it will start but run for a few seconds then stop what causes this can i fix it?
Hi bilsdrums53...
Sounds like you have debris/trash in your carburetor or maybe water in the fuel tank.
Check and clean your fuel tank.
Clean your carburetor and that should solve your problem
Aug 16, 2011 | Briggs & Stratton Garden
I have a craftsman briggs and stratton 550 series silver edition lawn mower and when i turn my lawn mower on the engine revs and then lets of over and over again like it is about to die but dont... what...
i have a brand new craftsman briggs &stratton silver engine series 5.50 158cc it will start but will not run unless i keep pushing the prime button to give it gas once i stop so does the engine
Oct 22, 2010 | Garden
Briggs & stratton 550 / surges, gas hog
check your air filter. If it's clogged, the engine will spool up to keep from dying, run for about 15 seconds, then it will happen again. If that's it, just clean the air filter. Solved my problem
Jul 26, 2010 | Briggs & Stratton Garden
Troy-Bilt Briggs & Stratton 550 restarting
Troy, Unless you are using old fuel (it breaks down after 1 week) it sounds like you have a faulty spark plug. Replace this first, drain any old fuel and replace with fresh fuel (premium unleaded). A faulty plug will work one minute but then fail like you have described.
Oct 24, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Mtd 22" Yard Machine Push Mower Logo
317 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
