Question about Epson Stylus CX6000 All-In-One InkJet Printer
IT'S AN EPSON STYLUS CX6600 NOT 6000. I'M SORRY IF I TYPED IT INCORRECTLY. AL
  • Epson Master
  • 13,433 Answers
Don't worry about the model, same instructions
Clean the machine, the rollers also and follow these steps to clear out any paper jams it might have
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jul 03, 2009
How do i print on a CD?
sorry to inform but you dont print on CD.
You print on paper and then paste it on CD :-)
That's called "label" printing.
Feb 13, 2011 | Epson STYLUS R230 InkJet Photo Printer
Compatible cartridges of the same type have been used for at least one year. The same compatible cartridges are no longer recognised
EPSON printers will no longer accept "compatible" carts...they must be epson only...per a court order...cart makers cannot make any EPSON compatible carts...sorry...you can look for "resetters" online...but these may not function sny longer as well...
Feb 08, 2011 | Epson Stylus Multifunction Inkjet Printer/...
How to reset printer Epson Office Stylus TX600FW manually without software
tengo problemas con mi epson tx600fw me sale mensaje de deposito de tnta lleno llame al servicio tecnico de EPSON
Sep 02, 2010 | Computers & Internet
Vista driver for Epson Stylus Photo 1270
I'm sorry to say it, but Epson does not support Vista on the Stylus 1270.
Aug 15, 2009 | Epson Stylus Photo 1270 InkJet Printer
How to get Epson R300 stylus monitor to work in Vista
I have the same problem with my stylus C88. Epson never did provide Vista drivers so I have never found a way to get the Epson software to work with Vista. The print driver does work so you will be able to print but you'll have to clean the nozzle manually by pushing the button on the printer rather than using the Epson Monitor. Sorry.
Jan 25, 2009 | Epson Stylus Photo R300 InkJet Printer
Epson stylus cx6000
I have this printer and it doesn't support printing banners. You will need to purchase another model. Sorry about that.
Oct 31, 2008 | Epson Stylus CX6600 All-In-One InkJet...
EPSON STYLUS PRO 10000
00010014 Pressurization error
Ink supply pressure incorrect
Explanation
The pressure system is determined to be leaking then this message appears and printer is stopped when detection of pressure origin sensor is incorrect at power on initialization or ink supply.
Solution
1. Replace supply pump assembly (including pressure origin sensor solenoid).
2. Check for disconnected air tube.
Aug 30, 2008 | Epson Stylus Pro 10600 InkJet Printer
Printer
i need installer for my epson stylus c59
Oct 03, 2007 | Epson Stylus Pro 4800 Color Photo Printer...
Epson Stylus  CX6000 All-In-One InkJet Printer Logo
117 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
