I'm trying to connect the one for all universal remote to my teac LCDV2255HD tv and I'm not sure what the code for it is.
Universal (URC) brands remote codes are at http://www.urcsupport.com/
SOURCE: universal remote code teac sdb
Hello Direct Code Entry 1. Press and hold the CODE SEARCH button until the red indicator stays on, then release the CODE SEARCH button. 2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit. 3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes. 4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand. Code Search (by Brand) Lets you search for a code for a specific Brand within the Code Library for a particular manufacturer. 1. Turn on the device (TV, VCR, etc.) to be controlled. 2. Press and hold the CODE SEARCH button until the red indicator remains on, then release the CODE SEARCH button. 3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks off once. 4. Press and release the numeric button (0-9) corresponding to desired Manufacturer (see table below). Note, pressing "0" performs a full library search same as Device Library Code Search Method. 5. Press the CHANNEL UP button ((or POWER or PLAY (VCR only)) repeatedly until the device to be controlled changes channel. 6. Press and release MUTE to install the code. Note, when all codes under a Brand have been searched the red indicator flashes rapidly for 3 seconds.
Universal Remote Code for Teac Audio with Philips Universal Remote Control model Number
[PHILIPS CL 034]; are:-
0672 0382 0187 0287 0387
