Question about Toshiba Satellite M35-S320 Notebook
XD Memory Card stuck in media adaptor of M45-s331
XD card was inserted but failed to stop part way and went into the adaptor until flush with the outside surface. I Pushed further with a paper clip thinking it would pop out but it only went in further. I have tried tweezers to no avail.
Can I somehow remove the adapter to get at the xD card?
  • 324 Answers
Re: xD Memory Card stuck in media adaptor of M45-s331
This link should help.
If this helps, please take the time to return and mark this as "solved"
Many thanks!
Posted on Nov 10, 2007
0 characters
3 Points
M45-s331 I was replacing the wireless card and I broke one of the terminals that snaps to the card. Where can I either get the terminal or the little harness?
this will be the best link for this part:
Please let me know if this washelpful and if it solved the problem! Also if the information provided washelpful, please click on the appropriate thumbs to make us aware that theproblem has been corrected or that the information provided helped you with theproblem.. Thank you and Good Luck.
Sep 10, 2011 | Toshiba Satellite M45-S331 Notebook
My Toshiba satellite M45-S331 has a set of buttons to the left of the keyboard that control the disc drive (play, stop, next chapter, etc.). They are currently only working with Windows Media Player. Is...
you may need to download a yahoo widget for your itunes that will allow the buttons to control itunes but chances are they are pre programmed only for media player
Mar 26, 2011 | Toshiba Satellite M45-S331 Notebook
I want to learn how to upload pictures from my Cannon Powershot A95 to my Laptop - Toshiba Satellite M45 S331. Does the laptop have a built in card reader?
Does your laptop have a slot on the front or side of it that is the same size as your card
if so insert your card into the slot and see if it comes up with a box giving you the option to view
if it does you can view it with windows explorer then highlight everything you want and either drag it into a folder that you open on you laptop or drag them into your pictures that will be in your documents
or you can highlight them all then right click and send to where ever you choose
if windows does not reconize the card reader then go to the website of the laptop and go to support/downloads and search for the card reader driver and download it making sure that you get the right one for your make model and operating system
good luck
also the cannon camera propably has software with it so that you can load it onto the laptop and upload the pictures that way
Sep 15, 2010 | Toshiba Satellite M45-S331 Notebook
Toshiba Satellite M45-S331 willnot operate on
You have replaced the battery and then it worked.
Try once with power draining (remove the battery and then press the power button for one minute and then again refix the battery) and check.
Dec 10, 2009 | Toshiba Satellite M45X-S331 Notebook
How does the media card reader work on the side of the hp pavilion dv4. It is supposed to allow for a ms/pro but it just kind of falls in. It almost looks like an adapter is supposed to fit in the slot
The Digital Media Slot supports the following digital card formats:
● Memory Stick (MS)
● Memory Stick Pro (MSP)
● MultiMediaCard (MMC)
● Secure Digital Input/Output (SD I/O)
● Secure Digital (SD) Memory Card
● xD-Picture Card (XD)
● xD-Picture Card (XD) Type H
● xD-Picture Card (XD) Type M
Here's how to use the memory card reader:
Jul 14, 2009 | HP Pavilion dv4-1140go Laptop
2nd RAM slot for Toshiba Satellite M45-S331
if its not under the laptop, it can only be under the keyboard.
Jun 18, 2009 | Toshiba Satellite M45-S331 Notebook
Toshiba Satellite M45-S351 BIOS password needs help!
BIOS passwords on Toshiba notebooks have to be reset by an authorized service technician who has the CD available to run the utility.  Their notebooks don't contain a battery reset to erase the password.  It was done as a safety feature to prevent theft from happening and it is a very good one.
If you take it into Best Buy or a computer dealer to get it done, you might have to prove that you are the new owner of the computer before it can happen.
Sep 23, 2008 | Toshiba Satellite M45-S351 Notebook
Stuck Media Card in the Machine
same thing happened here. Hubby was able to remove memory card by inserting a VERY small screwdriver under the memory card and catching on an indentation. He was then able to remove the disk from the slot.
Jun 05, 2008 | Toshiba Satellite M45-S331 Notebook
Toshiba Satellite M35-S320 Notebook Logo
60 people viewed this question
Top Toshiba PC Laptops Experts
Brian Sullivan
Brian Sullivan
john smith
Are you a Toshiba PC Laptop Expert? Answer questions, earn points and help others
