Question about Oregon Scientific Oregon Fusion Blade For 42-Inch AYP/Husqvarna/Poulan Pro/Sears/Craftsman La
Poulan Lawntractor 13.5HP throttle linkage missing
I have a Poulan Lawntractor Model # 271470 with BRIGGS & STRATTON 13.5HP 28R707 and Walbro LMT Carb, Had to overhaul Carb. During reinstall can't get throttle linkage to go. I'm wondering if a part has been lost. Looking at parts list I can't see any missing (although choke is different 216 262766 Link–Choke). The throttle (227 691374 Lever–Governor
Control) appears to keep the throttle open, but I can see no way to close the throttle via the cable since they move in reverse to each other. I can run wide open but I would like I means throttle control.
  • 376 Answers
The easiest thing for you to do is look at another mower that has a single cylinder Briggs at how the linkage is set up. They will all be the same linkage from 12 hp- 20 hp.
Posted on Jul 03, 2009
Need a throttle linkage diagram for a briggs & stratton engine model 9S502 type 0620-B1
David, This is what I found in google search for B&S carb. linkage diagram, you can also do a search because there are lots more.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Linkage Spring replacement on Briggs Stratton Quattro 4 HP Murray Lawn...
Repairing Lawnmowers For Profit Part 61 Governor Spring Help
briggs and stratton governor linkage diagrams Google Search
briggs and stratton carburetor linkage diagrams Google Search
Jun 10, 2016 | Briggs & Stratton Garden
Cub cadet 30 inch 1450 briggs and stratton
About 625 results (0.89 seconds) Search Results
    Why wont my engine start - Briggs & Stratton
    www.briggsandstratton.com/.../why-wont-my-engine-st...
    Briggs & StrattonThe most common reason an engine will not start is due to an interruption in fuel ...(such as Briggs & Stratton carburetor cleaner to clean carburetor parts and body. ...gasoline be purchased in small quantities, not more than a 30 day supply. ... that canflood the engine, or cut the air supply enough that engine will not run.Missing: inch ‎major
    Information about the Carter, Kohler and Walbro Carburetors
    gardentractorpullingtips.com/carbfuel.htm
    Information about the Kohler Carburetor, Various Fuels and Fuel Systems. ... (Updated 5/23/15); Repairing Various Older Briggs & Stratton Carburetors. ... If used on a smaller engine, due to the larger venturi, the engine will not receive the ... which converts to 1.181 inches (30 ÷ 25.4 = 1.181"), but actually measures 1.200".
    Notes on the Troubleshooting and Repair of small Gasoline ...
    www.repairfaq.org/sam/lmfaq.htm
    May 19, 2015 - Timing; Lawn mower will not start after the blade hit an obstruction; Flywheel ... on Briggs and Stratton repair; Experience with Briggs & Stratton carburetor .... NEVER attempt to run a gasoline engine indoors. ..... For 2 stroke engines, special oil (not the usual 10W-30/40 type motor oil, nor WD40 or 3-In-One!) ...
    Briggs & Stratton - YouTube
Jan 21, 2016 | Garden
My 17.5 Briggs & Stratton engine runs fine at idle
replace air filter, check throttle linkage position, take to a pro shop and have governer adjustment checked
Sep 04, 2011 | Briggs & Stratton Garden
Why would the engine idle at a very high rmp and the idle control seems to be function but has no effect on the rmp of the motor
check to see that there is no binding or issues where the governor linkage and the throttle linkage interact with each other at the carburetor. Check to see if any of the springs are missing also.It will be evident if so, linkage falling down.
Aug 17, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Walbro Carburetor on Briggs & Stratton Model 28R707
If the float don't float, the needle valve stays open and gas runs into crankcase.
If float floats (has no gas inside) then the needlel is probably worn and needs replacement.
Sep 06, 2009 | Garden
The kohler engine on my poulan pro 42 inch 17 hp is reving way too high the throttle cable does not apear to be stuck
YOUR THROOTLE LINKAGE IS BINDIND WITH THE ENGINE OFF MOVE THROTTLE BACK AND FORTH WATCHING THE LINKAGE ON THE CARB, SPRAY LINKAGE WITH PENETRATING OIL SO IT LOOSENS UP
Jun 26, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Oregon Scientific Oregon Fusion Blade For 42-Inch AYP/Husqvarna/Poulan Pro/Sears/Craftsman La Logo
458 people viewed this question
Top Oregon Scientific Garden Experts
Dennis Key
Dennis Key
Colin Stickland
Colin Stickland
roeb
Are you an Oregon Scientific Garden Expert? Answer questions, earn points and help others
