Question about Toshiba Satellite A135-S2386 Notebook
Toshiba satellite a135-s23876
It doesn't turn on. Even on the power button, the lamp is not on.
Among several icons posited on the front raw of the computer body, only one, plug-in lamp, is on. what is the problem and solution?
my email -
  • 134 Answers
Re: Toshiba satellite a135-s23876
If I'm not mistaken there is no reset button ot this Satellite. Try unplugging the charger and removing the battery to reset it. Let me know what happens
Posted on Nov 09, 2007
All of these solutions are complete bs because i have tried everyone and my F"N LAPTOP STILL WON'T BOOT THE F UP!!!! PISSES ME OFF BECAUSE I THREW AWAY ALOT OF MONEY ON THIS PIECE OF ****...
Posted on Nov 21, 2008
    Problem Solver:
  • 9 Answers
Your notebook is good memory etc. but do you ever do clean up the disk and defragment? maybe on your desktop have a running program not shortcut and you notebook have a too much to do in start up.try to delete some components what you are not using more.Good luck!
Posted on Jun 04, 2008
Thanks Alex! I tried your method and it worked for me.
Posted on May 31, 2008
Now my laptop wont start anymore. each-time i push start button, only yellow light on keyboard on. screen black, no boot no window start.. i dont know why.. i hold start button to off my laptop and push again start button but same problem happen. try another way, connect power supply cable but it still couldn'tstart. in other word my laptop looks like in sleep mode. Hope any expert here can help me before i send it to shop for repair. I have removed and refixed the ram, booted from battery and ac adapter. Noresponse. I got a friend to easdh board with alcohol. no response,
Next day I tried and it booted!
But the problem is back after 3days.
My laptop is Toshiba Satellite A135-S2386 15.4" Notebook PC (Intel dual core , 1gig RAM, 80 GB H... PC Notebook
Posted on May 12, 2008
i also had the same problem.
i removed the battery and put it back again... and bingo! it worked...
possibly some issue with the contacts of the battery...
just checkout whether the same solution works for you...
all the best.
Posted on Dec 10, 2007
0 characters
3 Points
Satellite A135-S4467 unable to click with the touchpad
there is a utility called ( alps touchpad) you can enter it from the tray by clicking on the icon ,,,, if not access it from the control panel ,,, this program controls tapping and clicking .... enable buttons clicking that should do it ,,,
Mar 07, 2012 | Toshiba Satellite A135-S4527 Notebook
Satellite a135-s2386 will not boot when power is turned on black screen
Does it make a beeping sound when you turn it on? If it does try this: Turn it off and take the battery out for about 2 minutes. Put the battery back in and press the power button to turn on. Immediately tap the F8 key on your keyboard. This should bring you to the advanced boot options. Choose last known good configuration.
If that doesn't work you may also try choosing system restore in the advanced boot options and follow the instructions. Note that a system restore brings the computer setting back to a previous restore point and will removes all changes after that chosen date.
I hope this helps. Cheers,
Sep 12, 2011 | Toshiba Satellite A135-S2386 Notebook...
Is the keyboard on the toshiba satellite a135-s4427 backlit and if so how do i activate it
The Toshiba Satellite A135 series stock keyboard is not backlit, and that model only supports one type of non-backlit keyboard, which is interchangeable with several other Satellite series. Here is some extended info on the keyboard for your model:
Jul 13, 2009 | Toshiba Satellite A135-S4427 Notebook
I have a Toshiba Satellite A135 and not sure if blacklight or something else
Your backlight lamp, (Bulb), or the Inverter is bad.
1.General instructions, and photos, for replacement of a typical laptop backlight,
2.Instructions for completely disassembling a Toshiba Satellite A135 laptop. The reason I included this is twofold.
A.It shows, and tells exactly, how to remove the LCD screen from your laptop.
B.It shows you that the following information in link 3, on how to replace an Inverter in a Satellite A105, will work for your Satellite A135.
(At the bottom of this page you will see Page1:: Page2:: Page 3:: Page 4
You are on Page 1. Just click on the white Page2, and so on, to continue)
3.How to replace an Inverter in a Satellite A105,
FIRST! Always remove all power! AC adapter, (Charger), and battery.
Second! Observe anti-static guidelines!
Third! This ain't tough! It just looks hard. Once you see how simple this is, I'm sure you'll agree with me.
May 28, 2009 | Toshiba Satellite A135-S2276 Notebook
No power at all even if i press the power button
Most likely the only thing wrong is the power button. Try to either replace the power button board or use a wire to short circuit the two points under the push button to turn the machine on.
Jan 31, 2009 | Toshiba Satellite A135-S2266 Notebook
Toshiba Satellite A135-S4666
try to eject whatever is in the DVD (you will see a tiny hole near the eject button, straighten a paper clip and push it in the hole) then try again
Nov 24, 2008 | Toshiba Satellite A135 Notebook
My computer wont come on
If the power indicator works when the power cord is pluged in you might call toshiba then...if nothing happens, however, a power unit brake-down does happens from time to time...
May 13, 2008 | Toshiba Satellite A135-S2386 Notebook
My toshiba satellite a135-s2276 won't turn on
A coworker used to work for Toshiba and said that this is common for the Satellite A135 models and under warranty the fix was a motherboard swap for a newer/updated motherboard. Otherwise the unit is unusable.
Jan 24, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A135-S2386 Notebook Logo
207 people viewed this question
Top Toshiba PC Laptops Experts
Brian Sullivan
Brian Sullivan
john smith
Are you a Toshiba PC Laptop Expert? Answer questions, earn points and help others
