Question about Epson Stylus CX6000 All-In-One InkJet Printer
Epson stylus cx6600 alll in one roller crimps and stops paper from rolling. My computer says it is working properly. It all started with a paper jam, which I cleared, hit "color" and thus my problem.Ally
  • Epson Master
  • 13,433 Answers
Clean the machine, the rollers also and follow these steps to clear out any paper jams it might have
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jul 03, 2009
Epson wide format printer stops in the middle of a job saying paper jam. But I know it is not paper jam.
I do not know this particular printer but several things might be wrong. Make sure all the paper handling sensors and rollers are clean. Check to see if the next sheet of paper is sticking to the first and blocking a sensor. Check to see if the paper is advancing properly. Sometimes the roller will spin but slips on the paper, if the printer senses that the paper is not advancing properly it will throw a paper jam code. Make sure you are using fresh, crisp paper and the holding tray is at least half full.
Mar 17, 2016 | Epson Stylus Pro 10000 InkJet Printer
Epson Stylus CX6600 wont power up/scan light turns on then goes off.
this may help...
Check that all the access doors and compartments are closed correctly.
Check paper isn't jammed.
Take out the all the ink cartilages and reset them in correctly
Make sure the rollers are set in place correctly, (if there removable)
Hope this helps a bit
Feb 09, 2014 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus CX4800 prints blank pages
Alex_Garton:
I'm not familiar with the Epson Stylus printers, but I'm going to hazard a guess. If the paper does not move at all, the paper pickup feed mechanism is at fault. One of two methods is used to pick up the sheet. Either the front lower portion of the tray is lifted up to force the top sheet into the feed roller, or the feed roller is connected to a drop-swivel to drop the feed roller onto the top sheet of paper. You'll need to look carefully at the feed mechanism to determine if a gear or clutch is failing. If the paper moves into the machine about 1/2 inch and then stops, either the first paper feed roller past the pickup roller may be at fault. Also check to see if the paper sensor between the paper pickup roller and the first feed roller is working properly.
Sep 22, 2012 | Epson Stylus CX4800 All-In-One InkJet...
My cx6600 has a paper jam and can't seem to get it to get it un jammed
if you have kids, then you may have something such as a band-aid or such stuck in the rollers, try using a 8 1/2 x 11 inch piece of poster paper and run it thru the machine to get it (or other things like bottle caps) unstuck.
Feb 21, 2011 | Epson Stylus CX6600 All-In-One InkJet...
I have alot of jamed paper in my Epson Stylus Photo RX595 printer. I also have tore paper jamed in the printer per following the directions in the Epson manual. Please help.
ithink problem come from paper roller, maybe the paper roller is broken, or gear box of the roller is nor connect properly, contact srvice center to fix it
Dec 03, 2010 | Epson Stylus Photo RX595 Series
Printer starts and paper goes in but starts to
hi,
it may be due to the moisture in paper. try new paper bundle .
if problem still continue this problem is due to the feeder assembly problem. clean the roller. then check it for allignment.
Aug 21, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Printer won't print
plzzzzz check whether the ink catridges are compatible to your printer(chk the model number of your ink catridges)
Dec 15, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Build up of ink on rollers , how on earth do i clean this off as my print outs are all grubby mucky looking cheers
Hi, please attempt running several sheets of blank plain paper or try to copy a plain blank paper for 5 to 10 times.
Sep 24, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus cx6600 printer not printing
please remove un necessery data from your system and re install the printer som after it your problem will be finish
Sep 26, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus  CX6000 All-In-One InkJet Printer Logo
215 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
