Question about Kyocera Mita Office Equipment & Supplies
The wheel at the end of the drum broke. mita machine #kt47. do I have to replace the drum? at least i think it's the drum,its the roller with wires attached at each end. the machine code # 199307
    Sniper:
  • 66 Answers
It sounds to me likeit is your fuser unit.
Depending on the model you can either replace the fuser drive gear or replace the entire fuser unit.
Get your local service agent to look at it
Posted on Jul 09, 2009
My dryer MAKES A lOUD THUMPING NOISE IN THE DRUM. BELTS ARE NOT BROKE
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
Oct 05, 2014 | Dryers
When I press the start button it sounds like the machine is going to explode it makes a very loud racket and I think the wheel is out of wack is there anyway to put it back on track
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch.
Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt.
Remove the drum and belt and this will expose the drum rollers, idler arm
pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the
idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go
to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots
or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably
only need lubrication. Lubricate the shaft of the rollers with a good grade
of machine oil such as 3 in One oil.
Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Dec 29, 2010 | Whirlpool LER4634J Electric Dryer
Hi I think the belt that turns the wheel in my dryer is broke everything else woks including the motor and there is no burning smell so I think it's the belt. My problem is that I cant find where it goes I...
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley or a faulty motor.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Oct 17, 2010 | Dryers
The belt that rotates the drum broke. How do I remove the Back to replace the belt ?
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Oct 04, 2010 | Kenmore 64902 Electric Dryer
I think the belt broke
Oct 03, 2010 | Dryers
Belt broke... we need to see how to put a new one on...
Sep 29, 2010 | Frigidaire GLER104FSS Electric Dryer
How to replace a dryer belt on a roper dryer
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT. If you have to replace your drum belt and if you have a front loading machine. Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum. Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn. While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good luck, I hope this helps Please do not forget to rate me Thank you
Apr 08, 2010 | Roper REX4634KQ Electric Dryer
Drive belt broke
If you have to replace your drive belt and if you have a front loading machine.
First you will need to unplug your dryer from the electric.
While you have the drum out, I would also recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you problem later with the rollers getting noisy, and also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Good luck,
I hope this helps
Oct 06, 2009 | Dryers
Drum roller is broken on Kyocera Mita 1020D.
There is no repair for this all you can do is replace the unit
Mar 30, 2009 | Kyocera Mita FS-1020D Laser Printer
Mita dc 1860 copy machine
Check Drum from scratches,check cleaning blade.Also check Heat roller.
Nov 15, 2007 | Office Equipment & Supplies
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
