Water leaking inside it
If the lines to your dispenser are broken or damaged you will need to replace them.
If your drain pan has holes or cracks it will also need to be replaced.
If you experience any clogged drains, they must also be unclogged or replace. If you experience this at the ceiling of your unit it can be attributed to a clog in the freezer section. Remove the divider and let the insulation thaw out and dry.
