Question about Johnson Minn Kota Mk 25 & Mk 35 On Board Maintainersstyle: Mk 35
Battery charger minn kota 3 bank charger says check connection on battery 3 all connections are tight. anyboby have any info that would help explain. thx
  • Johnson Master
  • 3,498 Answers
I have seen the threaded terminals on batteries where the threads do not go all the way down the terminals far enough to actually provide enough threads to tighten down wires!...whew..
Make sure the charger wires terminals are actually crimped on the wire and not the insulation..seen that too.
Posted on Jun 06, 2017
  • 157 Answers
SOURCE: proper batterie hook up on minn kota 70 thursh
Hello raventrans. I suggest you contact www.minnkotoamotors.com/index.asp and ask for est#406, Dave.
Posted on Oct 19, 2008
SOURCE: I need Minn Kota Power Drive operators Manual
I'm installing a Minn Kota Power Drive 70# on my Crestliner Fishhawk. I understand the 24 volt system. however the boat has 2 black, an orange and a red wire running to the batteries. I know black to neg. but where do the orange and red wires go.
Posted on Jun 28, 2009
SOURCE: i have a minn kota deckhand 35 that wont wind up.
Solution- Take the cover off the Deckhand 35 by Minn Kota. Inside is a motor drive. Remove the cover plate held in place with 4 screws. inside are nylon gears, most likely broken. The gears can be replaced with a Minn-Kota Deckhand Gear Repair Kit.
I found mine on the web at Northland Marine.com it's about $24.00 for the kit, plus shipping.
Good Luck!
Posted on Jul 13, 2009
SOURCE: what size battery does a minn kota 565 5 speed
12 Volt
Posted on Jul 17, 2009
  • 122 Answers
SOURCE: How many amps does a minn kota 80lb thrust motor draw ?
max is 56amps on 24v system
Posted on Jan 31, 2010
I've tried this charger on 3 batteries and always get "check connection" light, and flickering "battery charged" light. I've pinched clamps and connections are very good...I've left...
Smart chargers will fail to charge completely discharged battery. Simple charger w/o electronics will. Try connecting two batteries together with charger. ALL in parallel. + to +, and - to -.
Mar 03, 2018 | Minn Kota MinnKota MK110P Marine Portable...
Hello, I have a Minn Kota 440 4 Bank Charger. I recently heard it spark when I plugged into my 115V AC power source. Since then I have no charging light indicator and no actual charging occuring. I tried...
Hello Brad / Colee
The voltage converter in the charger has gone out (violently). Do not use this charger in your craft anymore. There is no longer any kind of guarantee of isolation, and galvanic corrosion may be accelerated if the boat is sitting in the water and you try to charge batteries.
Replace the charger. Your craft and your lives aren't worth the risk. You can try contacting Minn Kota to see if there might be some kind of warranty assistance.
Aug 29, 2010 | Garmin Minn Kota MK 440 On-Board Charger...
ONLY THE check connection light comes on. There is
I am having the same issue with My Mk 210 charger and have tried contacting Minn Kota two times for help? Have you had any luck finding the solution ?
Jul 27, 2010 | Garmin Minn Kota MK 440 On-Board Charger...
Minn-kota wiring battery charger 4 bank trolling motor e-drive
call the 800 number for minn kota on the head of your unit for questions or technical data. they will send you a copy of your manual also if you dont have it. i am not sure what your question is so ask them to save yourself time.
Jun 01, 2010 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Burning out fuses on trolling motor at battery
not enough info. I went the the min kota website, they show four maxxum 80's at different voltages.is it a 12v 24v or larger? without a year model I'll have no reference to what wiring schematic Is the fuse connected inline with the trolling motor? what size amp fuse are you burning up? well I can give you some troubleshooting tips. tools to buy (1) amp gauge. if you are unfamilier with amp gauges make sure you get instruction book with gauge or you could burn yourself. Toubleshooting(1) Remove cover off minn kota trolling motor. black cover ontop of unit were the foot control wires go into.turn over foot control remove cover (2) check for corrosion. any exposed terminals should be cleaned.(3) go to your batteries and clean all connections. make sure the batteries are fully charged.(4) take amp gauge and test positive wire for amp draw as you tun on trollling motor and run it through all speeds. if batteries are in the rear away from trolling motor get a 2nd person to control trolling motor. if the trolling motor is more than a 12v system you will have more than one positive lead to test.GOAL. What your trying to find out is how many amps the trolling motor is really pulling. and at what speeds. under a load in the water and out of the water.how many more amps than the fuse raiting? newer trolling motors come with inline breakers not fuses so I'm guessing your using 30 amp fuses. again without more info i can only guess.
Oct 29, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Wiring diagram for a minn kota mk220 2 bank charger
First. the +/positive/hot wires go to the respective/separate +positive/hot side battery terminals.. and the -/negative/ground wire go to their respective/separate -/negative/ground battery terminals.
The wires from the charger are "paired out".. meaning the + and - pair must go to the same battery. .. you can't mix and match.
Feb 27, 2009 | Johnson Minn Kota Mk 25 & Mk 35 On Board...
Johnson Minn Kota Mk 25 & Mk 35 On Board Maintainersstyle: Mk 35 Logo
312 people viewed this question
Top Johnson Boating Experts
kj henriksen
kj henriksen
Lawrence Oravetz
Are you a Johnson Boating Expert? Answer questions, earn points and help others
