SOURCE: MITSUBISHI TV VS-60607
Do you get any power indicators? it may be a problem in the powersupply area, or something more serious. Start with checking the fuses there.
SOURCE: does the VS-60607 have a digital tuner
No it does not. Only mitsubishis with a digital tuner are the ones that have a DM inside.
SOURCE: I have a mitsubishi vs-60607. The outer screen was
gona be hard
try the old white tooth paste trick
abit of soft scotch/rag with white toothpaste - scrub easly
should get it better
SOURCE: horizontal/vertical hold is off, picture is moving
You better take this fellow to a doctor. You have a stamp size IC with about 250 pins that is bad. Only a tech can replace this or reinstall a remanufactured board into this TV. You may ask the tech to use a freeze spray to find this IC first and then he wil decide how to operate!l
SOURCE: mitsubishi vs-60607 60" screen is
when picture is getting smaller in size or goes away or moves towards one side then hit your TV lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board at some soldering joints crack develops....then due to loose contact picture becomes small in size or disappears ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some time............so solution is ......TV main board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer
