Question about Samsung PS42P2S 42 in. Plasma Television
My samsong tv ps-42p2sb stoped working
My tv dose not turn on. the remote signal receiver box & modem is not working when I try to use the remote to turn the tv on.
Thanks,
simon
  • 304 Answers
Since your tv is in warranty call 1-800-Samsung. They will set up a service call to repair your tv.
Posted on Jul 17, 2009
No TV broadcast picture. Is this a tuner problem?
yes it does seem to be a tuner problem , I also wonder what happens when you use the auto channel finder and tuner usually found in the set up section of the menu ? As well as was your TV working before and receiving input via the antennae but has now stopped working in this regard ? I also noted that attaching an analog to digital converter box worked fine , so your TV is capable of receiving a signal via that method , dose the converter box use your antennae input jack or a video jack to send the converted signal into your TV ? if it is using your antennae jack then it may not be a tuner problem .
Jul 19, 2014 | Sony Grand Wega Kdf-50we655 50-inch Lcd...
Pioneer DEH-P5200HD after I replaced a fuse the subwoofer stoped working. I checked the speaker and the amp. Its the radio that doesnt give signal to the amp. Also I tried turning on and off the sub in the...
It sounds like the remote turn on wire from the radio no longer outputs power. You can try connecting the the remote turn on wire from the amp to the accessory power of the radio. Place a 10 amp fuse in line just in case the issue is the amp.
Sep 07, 2012 | Pioneer DEH-5200HD
The remote has stoped working?
Remote testers are available (5 dollars) or you can take to Radio Shack to determine if problem is remote or set.
all sets have a remote receiver usually on front that receives the infrared signals from the remote===either the remote control or the receiver is bad.
Mar 11, 2012 | Westinghouse W4207 42 in. HD-Ready LCD TV
Bought new Vizio 55"
Had same problem - turned off Adaptive Lumina, Backlight control, and Ambient light sensors on the Vizio advanced picture settings and the Dish remote now works. Vizio was emitting an infared signal that interfered with the Dish remote signals with these settings on. TV still works and looks just fine... But best of all Dish remote works too.
Nov 08, 2010 | DISH Network IR Remote Control
My insignia tv shows a NO DATA BASE error on screen. How do i fix this.
Try these tips:
Connecting your Cable box through Coaxial to the TV.
1- Turn on the TV and the Cable Box, secure all the coaxial connectors.
2- Press the "TV" button to be sure you are in the TV mode.
3- You need to set the TV in a specific channel for receiving the signal from the Cable Box, usually they are channel 3 or 4. Please press in the TV's remote those channels numbers and check if you are receiving signal about the Cable Box in any of them.
4- If you do, afterwards remember to continue using the Cable Box remote to change the channels instead of the TV one.
Connecting your Cable Box through RCA to the TV
1- Turn on the TV and the Cable Box, secure all the RCA wires.
3- Press the "Input" button to go to AV1 or AV2 depending where the Cable box is connected.
4- You should be receiving signal instantaneously after you have changed the Input and keep using the Cable Box remote for changing the channels.
Jun 21, 2010 | Insignia LCDTV26 26 in. Television
Samsung ps-42p2sb Tuner never turns on.
  1. Might need a service technican to fix your set might need a new power supply or if you have any electronics backround take the back off and look to see if there are any bulging capacitors on the power supply
Aug 23, 2009 | Televison & Video
Sharp Aquos HDTV Failed to receive broadcast
I too have this issue I beleive what is happening is the integrated tuner is not locking on to the channel because of a weak signal and then sending that error message . I am going to replace the cable from the splitter to this tv and see what happens. I have another new tv just installed from that splitter and it has all chanels. Remember to RE- run the locate all channels after anything is done to the cable splitter etc.
Mar 29, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Digilogic dstb1000
the function light dose not represent a remote command, it simply flashes when it detects a infra red signal of any wavelenth. if the box is not turning on it sounds like a defective nor or nand flash rom. i believe that the box has a j-tag so maybe you re flash it?
proberly not
so inconclusion a defective flash means no os no os means the box wont work
hope this helps
Sep 01, 2008 | Televison & Video
My OSD does not come on
Try plugging a video rca cable into the "monitor" on the back of the mixer (second down or something like that) and then to your tv. This pumps the osd signal to the tv where you can manipulate the menu options.
Think this analogy:
remote = keyboard
receiver = computer
tv = monitor
You need a connection ultimately to the tv for the osd to work.
Aug 12, 2008 | Marantz SR-7200 Receiver
Tv samsung plasma
If it has not tuner/antenna input then it is just a monitor. At that point you will need a cable box,sat box or something to provide a picture scource to it.
May 26, 2008 | Televison & Video
Samsung PS42P2S 42 in. Plasma Television Logo
185 people viewed this question
Jerry Greenberg
Jerry Greenberg
