Question about Epson Stylus NX400 InkJet Printer
Chip resetter for NX 400?
I have managed to drill a hole in my NX 400 cartridges and refilled them (T069120 Black and T069220 Cyan) but I don't know where to buy the chip resetter for them. Any idea where I can purchase one that will work on these cartridges and not the older types?
Thanks in advance!
SOURCE: lexmark z845 resetting or refilling?
I have an z845 and all injet refills are the same...
1. buy an injet refill set from an office supply store, I found mine at Staples. There are more expensive ones you can but online (premium and photo quality inks) but the expense isn't much, just the time in getting them, if you can wait, go for them, unless you don't do photo glossy prints or iron transfer t-shirts, then color matching accuracy might not be as important.
2. open your pack, assemble your syringe, open the inks but leave the seals on, just poke the syringe through when you start to refill.
3. carefully pull the sticker from the cartridge, you don't have to replace it they say, but it's good to keep in on later to stop splashing.
4. use the included drill bit to widen the three holes in the top of the inkjet cart. (no drill bit, use you own, and you only need one that's slightly bigger that the syringe, the one I got was a quarter inch and very stupid)
5. **** up 3-4 cc of ink from a color bottle and stab the syringe all the way to the bottom of the cartridge in the hole of that color, it will resist because it's foam latex, make sure that there is no more resistance when it is fully at the bottom, and squeeze in carefully in case it's not actually empty.
-don't follow directions if they say to "fill it up to overflowing then **** out the excess", lexmarks leak when over half full. 8 is a full cart, 3-4 is probably safe.
-fully clean out the syringe between each color by sucking up water 3-4 times and blowing it out again.
-put the sticker back on seal your inks, clean the syringe and your ready to go.
-clean the metal contacts and then the print heads with the clear or pink solvent, wipe off with a dry cloth and reinsert into the printer.
Easy as pie.
Posted on Aug 03, 2008
Joed911
  • 4338 Answers
SOURCE: What is a chip resetter?
The resetter actually resets the Reset Ink Counter not a chip. It resets the ink level (ink metrer) . You can use the resetter tool.
Download the mptool from this site:
http://printer1.blogspot.com/2008/03/resetter-printer-canon-mp-series-mptool.html
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Oct 26, 2008
SOURCE: epson stylus cx9400fax series printer
There is no chip resetter for this model at this time. However, one is to be available in the near future. So for now you must purchase new/refilled cartridges.
Posted on Jan 27, 2009
SOURCE: Chip resetter for Epson R270, Samsung SCX4200, Scx4300
hi kaushal
GO TO HIS PAGE .
http://www.ssclg.com/epsone.shtml
sajad from iran.
Posted on Mar 14, 2009
  • 9 Answers
SOURCE: kodak 5300 chip resetter
are you dump
Posted on Jan 20, 2010
After refilling the hp1055 cartridge, how to reset to make it print
You will need to replace the original chip with one of two different types. 1st type is a one time use chip or the 2nd type is a resettable chip. Either will work for the refill. Another way is to get a CISS for this machine. It depends on how much you are printing.
Feb 24, 2013 | HP Hewlett-Packard HEWC4891A Designjet Ink...
Need KODAK #30 ink refill kit and chips or chip resetter
Kodak # 30 ink cartridge was made just for Kodak to help them get out of the red ink they are in. read the link below and see what they have done.
http://blog.atlanticinkjet.com/general-cartridges-posts/the-latest-printer-ink-from-kodak-inkjet-a-shift-from-the-cheap-ink-approach.html
Feb 12, 2012 | Office Equipment & Supplies
BOUGHT NEW CARTRIGE FOR MY NX 415 AND THEY AREN;T REGOGNIZED!
If the cartridge is not the same code as the previous used by the printer, then it will not be compatible. Your printer has been replaced by Epson Stylus NX415 All-in-One
  • One 69 Black Ink cartridge (T069120)
  • One 69 Cyan Ink cartridge (T069220)
  • One 69 Magenta Ink cartridge (T069320)
  • One 69 Yellow Ink cartridge (T069420)
  • Therefore, ensure that the catridge follows the above code (69).
    Best regards.
    Jun 10, 2011 | Epson Stylus NX400 InkJet Printer
    We just? replaced the cyan toner with a OEM cyan and two days later it says it needs to be replaced again
    A lot of printer cartridges have microchips which make them unusable once the machine believes it to be finished, mainly to discourage refilling. maybe the chip has malfunctioned or the cartridges were used already and refilled or something. there are chip resetters , perhaps you should speak to the supplier, they may refund or replace or reset the chip for you.
    Dec 20, 2010 | Konica Minolta magicolor 4650DN Laser...
    HOW DO I REPLACE THE INK .I BOUGHT THE INK BUT FOR GOT HOW TO PUT IT IN
    In order to replace the ink..please follow the following steps
    #1
    Spread out a piece of newspaper where you plan to work. Remove the supplies from the refill kit. The Lexmark 44 will have one bottle of black ink, one thumb drill and one syringe. The Lexmark 43 will have one bottle each cyan, magenta and yellow, three syringes and one thumb drill.
    #2
    Remove the label from the ink cartridge. The black refill hole is at the top of the ink cartridge. Use a toothpick to check the color of each fill hole on the color ink cartridge. Generally, the magenta is at the top of the cartridge, the yellow is at the left center and the cyan is at the right center.
    #3
    Use the thumb drill to open up the fill hole to fit the syringe needle. Place the tip of the thumb drill on the fill hole and twist until the hole opens up larger. Do this for each color hole on the color ink cartridge.
    #4
    Fill each syringe with 7 ml of color ink (one for each color) and 15 ml of black ink. Insert the syringe needle into the bottle of ink and pull the plunger upwards.
    #5
    Place the tip of the syringe needle into the fill hole. Slowly press down on the plunger. If the ink seeps out while filling, stop filling the cartridge and wipe up the ink with a paper towel. Some cartridges may not need the full amount of ink. Repeat this step for each of the colored ink fill holes.
    #6
    Replace the ink cartridge in the carriage of the printer. Run one to three test pages to cycle the ink and check the printing. Use any document with color on it for the Lexmark 43 and any document with black text for the Lexmark 44.
    Thanks
    Oct 06, 2010 | Lexmark X9575 InkJet Printer
    Don't know exactly where to drill a hole to refill Epsom T0711 printer ink cartridge. Can you help?
    Thanks for using Fixya.
    You won't need to drill hole anywhere.
    Visit this link to get all the instructions required to refill the ink in Epson T0711 cartridge.
    But remember you would need a chip resetter gun to re set the chips on the ink cartridges after you refill the cartridges.
    Visit this link to buy Universal chip reseter if you don' t have.
    Good luck and have a nice day.
    Jul 05, 2010 | Epson Stylus Multifunction Inkjet Printer/...
    Don't know where the refill hole is? Epson stylus c120 ink refill
    The Epson 68 cartridges cannot be legally refilled at this time. There are two chips that monitor the ink levels. Once the ink gets below 25% the inner chip deactivates the outer chip so it cannot be reset. Any replacement chips you can buy are technically violating patent law. To refill these you would need a chip resetter and always refill it before it gets below 25%. I own a Cartridge World ink refilling store and I would not recommend refilling these yourself unless you enjoy getting ink everywhere and possibly still not having the cartridge work (btw there is no "refill hole" you make it yourself, thus the messiness).
    Feb 05, 2010 | Epson Stylus C120 Color Printer InkJet
    Need to reset ink cartridges without spending money
    Check with a cartridge refill supplier. They might sell you the same chip resetter they use. I know they do here. They even sell it in a kit with the inks.
    Apr 21, 2009 | Office Equipment & Supplies
    Shows replaced cartridge as empty
    The cartridge chip needs to be reset to "full"; for this you need a chip resetter - this should have been done by whoever refilled the cartridge for you. You can get your own Epson chip resetter very cheaply on E-Bay.
    Please rate this solution if it is of use to you
    Feb 21, 2009 | Epson Stylus C43SX InkJet Printer
    Refill clp-315
    No need to drill holes. If you turn the cartridge with the drum facing away from you, on the left hand side, you should see a small block elliptical cover with a couple of divider on it. That is the cover for filling the cartridge. The problem is there is no available reset chip yet for clp-315.
    Feb 21, 2009 | Samsung CLP 315 Laser Printer
    Epson Stylus NX400 InkJet Printer Logo
    514 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
