Letters are repeating continuously..Tried "Ease of access centre" and followed from there without success. Using tablet at present.
Check out your keyboard would be a good idea.. Make sure all your keyboard settings are default. Is it wireless or wired?
If you could be a little more descriptive it would help.
If you have the SideWinder X8 mouse, it may interfere with the internal windows keyboard/mouse controls. Answer for the keys repeated a few times in an hour is below:
If you ever pressed the 8th button, the one left of the thumb buttons, that will set the thumb buttons on a macro.
If you had it on another button before, and pressed it a few times because it didn't work, it will repeat those macro's instead.
To fix this go to start-programs-microsoft mouse- Microsoft Mouse.
Then put the thumb buttons back on the key you wanted. Don't press the macro record key again if you want to keep the thumb buttons on the key your assigned them to. Please let me know if you are not using SideWinder X8 mouse and this solution doesn't work for you.
I hope this helps you.
Key could be stuck on keyboard. Try banging on all the keys (not hard enough to break - just hard enough to unstick). Try a different keyboard.
