Question about Nokia 6680 Cellular Phone
Cn u gve a solutions about keypad malfunctioning of nokia 6680?
  • code_dhan Jul 03, 2009
    cn u ever been tried the cleaning process??if not yet just clean the keypad board of ur unit using the laquer thinner and brush OR u cn clean that also by using a rubber eraser only...ok?
    President:
  • 1,884 Answers
Ultimate solution is to replace the keypad. BUT, before you do that Open up the front cover if you can and blow hard with your hair dryer. Elase, go to Nokia Care and get the keypad cleaned of all dust. if that does not work then ask Nokia Care to chance the keypad.
Posted on Jul 26, 2009
I have nokia 6680 I I forgot screen lock code when I turn my phone on it asking for lock code so now how I can open it ?
How can you forget a code you set and have been using multiple times a day? The default code is 12345. If you 'found' the phone, perhaps it is still set to the default.
NOKIA 6680 - How to Hard Reset my phone - HardReset.info
www.hardreset.info/devices/nokia/nokia-6680/hardreset/first-method/
Hard Reset NOKIA 6680. First method: Power on your handset. Hard Reset NOKIA 6680. Then please press and hold * key + 3 key + Call button + Power button, until you see Nokia logo. HardReset NOKIA 6680; After that enter your lock code. * The default lock code is 12345; Now your phone will reset and restart.
www.hardreset.info/devices/nokia/nokia-6680/hardreset/third-method/ Hard Reset NOKIA 6680. Third method: Switch on your phone. Hard Reset NOKIA 6680. Next press Menu button and goto Settings -> Phone -> Phone management -> Factory Settings -> Delete data and restore -> Yes Factory Reset NOKIA 6680; Then your device will reset and reboots. That's all. See the Previous method!
www.hardreset.info/devices/nokia/nokia-6680/hardreset/second-method/ Hard Reset NOKIA 6680. Second method: Turn on your cell phone. Hard Reset NOKIA 6680. You should now type this code: *#7370#; Then press your lock code. * The default lock code is 12345; After that your phone will reset and restarts. Success! See the Previous method! See the Next method! How to Hard Rest NOKIA ...
Nokia 6680 hard reset
www.hard-reset.com > Nokia hard reset Apr 3, 2010 - Nokia 6680 hard reset: Press these buttons * + 3 + call + Power on your phone. Before the device is reset, you need to provide the lock code. The default lock code is.
Nokia 6680 Hard reset - How To Factory Reset
https://www.hardreset99.com/nokia-hard-reset/nokia-6680-hard-reset-factory-reset/ Feb 18, 2017 - Nokia 6680 Hard reset and Factory reset. Forgot your android mobile Password or PIN or Pattern, Here you can get recovery solutions for free.
NOKIA 6680 Hard Reset - IMEI.info
www.imei.info/hard-reset-1350-nokia-6680/ Are your looking for a way to make your NOKIA 6680 work faster? Do you wish to clear all of the data on your NOKIA 6680 before selling it to someone else? Well what you need is the factory reset. What is it? Factory reset (aka hard reset) is an operation which deletes all data (including settings, applications, calendars, ...
videos
nokia 6680 hard reset Google Search
Mar 24, 2018 | Nokia Cell Phones
Blank/White Screen
Some good advice from someone who has been looking for this solution for many months, FORGET jumper solutions because you are just wasting your time with this and forget reheating the board as well.
I do not have a diagram to upload but those of you should know where the black bga chip is on the left hand side of the keypad system connector, that is all you have to replace, no jumpers needed. I have just finished my fourth N70 in this way, just change the chip and nothing else.
you can also find the chip on 6680 board.
Aug 01, 2010 | Nokia Unlock N70 N71 N72 N90 6630 6680...
Nokia 6070 key pad 3, 6, 9, # key not working i
Sorry to say this please replace keypad crstal IC,and jumper it will work 100% ....reheat the upper components and the the whole pcb,with care,the keypad ic is same as 6600, 6630, n70, 6680, 6280 LCD IC.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Jul 28, 2010 | Nokia 6070 Cellular Phone
I lock my nokia 6680 and forgot the password
If you do not have flash tools box to read the PM and edit PM from your phone. The best step is to do a hard format key keypads. to do is to be pressed three keys simultaneously, 3, * and keypad Call. to prevent it from loose, tell your friend to press the on / off switch with no release was several seconds. never release it until you find a screen blinks twice in the 4-5 second range. If you can see the screen shows the leader setting the city / country. you can pass each keypad you press the on / off switch. now you have set your lock code nokia factory settings std, std lock code is 12345.
Note: Before you perform this way, make sure you remove the memory card first, also charging the battery at full level. safe to try, and good luck.
Vote me if this is really helpful. :]
Jul 08, 2010 | Nokia 6680 Cellular Phone
6680 no lcd lights
You can replace the LCD screen on the Nokia 6680 if it doesnt light up. A new screen runs about 20 dollars.
Check out the guide at the following link: Nokia 6680 LCD Screen REpair
Jan 21, 2010 | Nokia 6680 Cellular Phone
Cn smeone gve me a registeration key of smartmovie player 4.15 for n79
just go and search google for smartmovie 4.15 + keygen it works
Sep 04, 2009 | Nokia N73 Cellular Phone
Four Keys of my Nokia 6680 are not working
Try to replace your keypad with a new one and check, if it fails take your mobile to a service centre for service..also Dont forget to claim warranty..Thank you!..
Jul 22, 2008 | Nokia 6600
Green key 'jammed'
you should get a new phone....the board sound as if it is faulty....you can also have the firmware reflash.....pls take the phone to a professional mobel tech
Dec 28, 2007 | Nokia 6680 Cellular Phone
Nokia 6680 Cellular Phone Logo
98 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
