Question about Freezers
Compressor very hot. the temp. will not go below 52 degrees.
    Sergeant:
  • 340 Answers
One of two reasons restricted freon line (cap tube) or low on freon either way with the cost of a service call and a new one depends of the size but if you start spending more then 1/2 of what its worth then say better money New One jmho.. Tom
Posted on Jul 03, 2009
How can you keep a idylis chest freezer in garage during winter? temp below freezing
20 years ago guys used to put a 50 watt bulb down in the compressor area BUT the freezers today have been designed with the condenser in the freezer wall and don't retain any heat in the cold weather. Generally what you will experience is the temperature in the surrounding area drops to 10 degrees the freezer goes off and when the area begins to warm up the compressor tries to start with syrup for oil in its crankcase and cycles on its protector until it gets hot enough to warm the oil and allow it to run. Compressor life is shortened and the freezer temp is unstable. A self regulating crankcase heater could be purchased at a local supply house and wrapped around the compressor but I don't know if its ever been tried on a compressor that small or if you might overheat the compressor. ............Can you say garage heater? Its a matter of system design. All of the components for a commercial conversion are out there but a system that small is never considered. Sorry wish I could help more. Hope this helps and good luck.
Sep 30, 2014 | Freezers
Sub Zero 700 suddenly stops after 12 years. Compresser is burning hot.
The compressor will normally be 100 to 110 degrees. I would suspect the thermostat or mouse damage in the freezer area. Also, if you keep it overstocked, to the point of poor air circulation, you could just have ice blockage. Put the frozen food in a styrofoam cooler or a good heavy corrugated box and give the unit a good full defrosting.
Dec 15, 2012 | Sub-Zero 700 Refrigerator Freezer...
The freezer won't run so how us it that the compressor is very hot after several hours?
ice cream is always the last to freeze and a temp of minus -10 degrees is usually required to get it to get hard. if you put the ice cream in the door it will be especially tough to freeze. a good thermometor is a good investment as you can observe the temps. usually ten degrees or 20 degrees is what they run. yes they do cycle on and off as long as they hold temps thats good. the outside of the freezer gets warm because the hot compressed refrigerant is spread through piping near its surface giving up its heat of compression . setting the stat to max will freeze the ice cream eventually but utility bill suffers . good luck
Sep 10, 2012 | Danby 3.6 cu. ft. / 102 liter Chest...
How lpw of a temp. Can this freezer reach..and and if only 0 degree could the thermostat temp control be changed out so it could reach les than 0 temperatures like negative 20 or so?
There are different models made for holding different products. Yours has a 1/3 hp compressor for above 20 degs. It may have 0 on the thermostat and may well pull down that far, but -20 would be out of it's reach. Where as it's sister model is made to freeze to below zero has a 3/4 hp compressor. Larger compressor for the lower temps.
Sep 18, 2011 | Beverage-Air 44.9 cu. ft. / 1271 liter...
True t-49 Freezer not getting below 10 degrees
is his garage as hot as yours?
Be sure the condenser coil is real clean. Best place to start. Freon levels, door seals are another place to look.
Let me know if I can help any further.
Jun 26, 2010 | True 52 cu. ft. / 1472 liter Commercial...
Freezer temperature does not get below 10 degrees
this is something you can do now. Check this 1st:
make sure that the air vents are not blocked and that you didnt overload the freezer with food
there can be other things that will not bring the temp. below 10 (that temp. is not too bad as long as it doesnt spoil the food)
here are the possiblities:
t'stat is set too low
t'stat is not responding to zero degrees (all that means is it is shuting off the compressor too soon to reach zero)
dirty condenser
r-134a freon is a tad low (only takes like 9 oz. if lose 1 or 2 that is enough to affect performance)
the freon is the last thing to check cuase you have to call someone to do that for you...
Well hope this was helpful... check the temp often watch to see if it gets above 20 degrees cause that will spoil you food..
Mar 11, 2010 | Freezers
Normal Operating pressure for true 2 door Freezer R404A Room Under 80 degrees F Box at -10 degrees F
The pressures depend, somewhat, on the expansion device,i.e. a TXV or Cap Tube. Take a pressure reading, then convert it to a temperature. The evap temp should be right at 10 colder than the box temp. Remember, heat flows to cold so the evap has to "Lead the Load" in order to cool. In many cases, the condensing pressure is usually ambient temp, plus 30, then convert to a pressure. These are general accepted practices that have been used for many years.
Hope this helps
Jul 11, 2009 | True 49 cu. ft. / 1388 liter Commercial...
Not cold enough
hi it is thermostat problem better to check it..... thank u.......
Jun 03, 2009 | Kenmore Freezers
Avanti CF61 does not freeze
Bad compressor. check the compressor with the unit on with a volt meter and see what voltage you are getting and also if it way to hot to touch by hand is another sign compressor is bad
Feb 09, 2009 | Freezers
Freezers Logo
172 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
